Can you help me make the reverse sensors work on my reel to reel Akai GX230 D.
The sensors used to work and the machine could work non stop
  • 319 Answers
SOURCE: akai gx 747 dbx reel to reel need repair and service zip 95624
What problem(s) are you having with unit?
Posted on Apr 23, 2008
Grubhead
  • 5017 Answers
SOURCE: akai gx-625 reel to reel tape deck has no sound
This could be a head fault? Another possibilty is the preamp stage. You will need to look for something that would take out both channels. Such as an IC.
Posted on Sep 11, 2009
Grubhead
  • 5017 Answers
SOURCE: lights on bottom row fast farward,stop,fast
Do these controls still function? If they do it looks to me that it might be bad connections, that might need soldering. They don't look like they are bulbs from a picture I can of it on flicker, more like LED's.
Posted on Jan 05, 2010
Testimonial: "Thanks they are led.s i will check the connections.The controls function perfectly the unit worked perfectly except the lights."
dunnbiker
  • 8546 Answers
SOURCE: I have a vintage akai 4000dsMk2 reel to reel. Not
It all depends on what's wrong it and if it's worth the price to fix it to YOU, doesn't it? Only a tech can look at it and tell you the cost to fix it.
Posted on Feb 10, 2010
  • 9 Answers
SOURCE: I need akai part number ms244708 for a 4000d
If you look around you will likely find many many Akai 4000 series reel decks for sale..some for parts.. Akai 4000 series decks used basically the same mechanism and same parts... 4000d, DS, DS II, DB, Incidentally, the Akai 1700, 1710, 1722, 1731 used the same basic mechanisms as the 4000. .
Posted on Jun 08, 2010
How do play both sides if what looks like a reel to reel tape that has a side 1 and side 2 ? My Akai 1722II does not have auto reverse . Thanks
You take the spools off and put the right spool on the left and the left on the right.
The link also explains, but i started on reel to reel in the late 60s. :>)
how do play both sides if what looks like reel to reel tape Google Search
Good video here
Reel to Reel Basics
Apr 25, 2017 | Akai Audio Players & Recorders
Can you help me make the reverse sensors work on my reel to reel Akai gx230d
Use a foil tape at the end of the reel. If that does not trigger it then play a tape and touch the two sensor contacts with a paper clip. If it still does not reverse then there are circuit failures in it and off to some Technician it goes. Or you can download the schematics from Hi Fi Engine and do the job yourself.
Dec 28, 2016 | Audio Players & Recorders
AKAI REEL TO REAL MODEL 1700 OPERATOR'S MANUAL
Here you are Andrew. That is a blast from the past!!
Service Manual and Owner's Manual!
Akai 1700 Manual Stereo Tape Recorder HiFi Engine
Jan 23, 2016 | Computers & Internet
Manual for Akai X1800Sd reel to reel
Hi
I have managed to find 2 site for you for a manual for this machine. The first only offers a service manual here
AKAI 1800SD Service Manual free download schematics eeprom repair info for...
and seems to be more advanced than you need as it seems to deal with a lot of dismantling and settings.
The second offers both a Service Manual and an Instruction/Owners Manual here:-
Akai 1800SD Manual Reel to Reel 8 Track Tape Recorder HiFi Engine
Unfortunately you have to register and create an account for this one so it isn't quite as convenient, but its the only one I could find with an Instruction Manual.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Oct 12, 2014 | Audio Players & Recorders
Reel to reel will not play
You do not mention the brand or model number which to answer the question effectively is needed- different machines are designed in different ways. The function of the fast wind and the play mode only differs in that in play a capstan is involved that regulates the speed and the reel motors just do the take-up of taper and a little back tension for the supply reel. You may have either a sticky Pinch Roller linkage or a non- rotating capstan shaft that might point to a loose or broken capstan drive belt. There are also the condition of the Pinch Roller surface and the surface of the Capstan shaft that can be glazed or rubber hard and non-compliant. The rubber Pinch Roller can be re-rubbered, the capstan shaft can be reconditioned and the Capstan Belt can be replaced. Capstan bearings and motor bearings need oil once a year as well. I hope this helped to some extent- I have been working on decks now for better than 40 years.
Dec 12, 2012 | Audio Players & Recorders
Lights on bottom row fast farward,stop,fast reverse not working on akai gx-77 reel to reel
Jan 01, 2010 | Audio Players & Recorders
Oct 24, 2009 | Audio Players & Recorders
AKAI STEREO RECORDER 1722 reel to reel
so what was the answer? can the akai 1772 take 10 inch reels as well as 7 inch? please
Jan 08, 2009 | Akai Audio Players & Recorders
Akai Gx-77 reel to reel tape dech
Gx 77 is working now I have solved my prbblem with my friend. where I will get big flat belt for rewinding spool/
Nov 14, 2007 | Audio Players & Recorders
44 people viewed this question
 Grubhead
Grubhead
