Question about Water Water Heaters
Siemens heating thermostat & receiver not working properly
I've got a Siemens RCR10/433 Receiver & RDH10RF room thermostat. I've got hot water but they're not turning my heating on. I have changed the batteries in the thermostat. The lights on the wall receiver have gone out.
tborn6
  • 700 Answers
SOURCE: alpha boiler - wireless programmer failing
it sounds like the problem may be in the boiler and not the controller itself. Do you kno which is are the two wores that are the r-w for the thermostat take and purt them together and see if the boiler stays on or shuts off like it does with the thermostat. If it does then replace the reciever. If it doesn't then you have another problem. Good Luck
Posted on Jan 07, 2009
SOURCE: Siemens central heating control
I have a Siemens "Radio" Room Stat - the receiver has switched itself off. How do I restart it. I have pressed the restart button and the reset - nothing happens except for red light flashing and then off. I do not have the instructions. Where might I get them?
J W-K
Posted on May 01, 2009
SOURCE: no hot water when heating tempreture reached
I have a triton opal shower.
I turn shower on low pressure and cold water. then no low pressure and piping hot water for a very short time then low pressure and cold water.
I've changed the solenoid and the little black plastic ball.
Help !
Posted on Mar 21, 2010
SOURCE: woke up to no hot water changed out both heating
Water heater can test for power, but is only receiving 120V instead of 240V.
Test that upper thermostat is getting 240V across top two screws of thermostat.
http://waterheatertimer.org/Test-electricity-to-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 29, 2011
SOURCE: 50 gal. reliance electric heater.
Water heater is fully repairable.
Replace thermostats.
I usually replace both thermostats to save checking which thermostat is bad.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If problem continues, there is a very small possibility that one of the elements is shorted to ground.
Read full troubleshoot:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Other notes:
Electricity to heater, and the circuit breaker are good.
TP valve is good. Water heater is not leaking and therefore not rusted out.
Add a comment for more help.
Take a moment and rate answer for accuracy:
Posted on Sep 20, 2011
Testimonial: "Thanks, I thought it was the thermostat but not experienced with plumbing so wanted to ask. Will replace them. Thanks again."
I have hot water but can't get heating to come on
you don't say what type of boiler you have, but as a guide...
Three port valve may not be operating.
Heating Pump may not be operating.
Room thermostat incorrectly set or not working.
Start with the room stat as it controls the valve and the pump..
More information about your system is needed to help you further..
Apr 17, 2017 | Water Water Heaters
Ideal Logic + Combi C30 not firing up.
Isconnect from the hive ,it has been known the hive thrmostat fails on ideal boilers.
Mar 22, 2017 | Water Water Heaters
Hi i have a wireless room thermostat i wish to fit to my potterton boiler can anyone advise me thanks
in general-
wireless thermo has 2 units - room thermo and furnace rcvr.
if thermo is battery powered no wires to connect - if not needs 24V connected - then why do they call it wireless?
rcvr connects to same 4 wires as current therm except at the furnace - 24v power and 2 control lines
I can't remember the color code except red/black is +24v/common
but I have found them messed up by "professional" installers so u need to verify before connecting or go by the terminal labeling.
Dec 09, 2014 | Water Heaters
Why when my siemens RDJ10RF room thermostat has the arrow asking for heat does my boiler not fire up so i don't get any heating.The water heats up ok though?
You have a triple aquastat that maintains a temperature level needed to provide hot water. but you are not getting the thermostat to operate the central heating. The thermostat is a switch that operates by temperature. if you have tried raising the thermostat and the system did nor kick in try jumping the thermostat terminals in the aquastat . if that works then the problem is either in the thermostat or the wiring to the thermostat. also with a electrical tester." while the thermostat is jumped" test the c1 and c2 terminals to see if power is going to the circulator. If not then you need a new aquastat. if you have power and the pump is not moving water replace it.
Oct 11, 2014 | Water Heaters
Whirlpool hot water heater puts out overly hot water
1) Make sure factory-supplied insulation and cover are reinstalled over thermostats, or cooler room temperature causes thermostat to under-approximate tank temperature, and this causes overly hot water.
http://waterheatertimer.org/images/Tank-with-insulation-2-600.jpg
2) Replace both thermostats.
Sticking thermostat can seem to act normally when tested, but when left alone it sticks, causing runaway overheating.
More resources:
Oct 03, 2012 | Water Heaters
Woke up to no hot water changed out both heating elements and both thermostats meter says wiers are hot checked breaker its got power still no hot water any suggestions
Upvote the help.
May 28, 2011 | Reliance & 40 Gal Electric Mobile Home...
I have a rheem hot water tank when you turn on the hot water it comes out nice an hot but not even 30 secounds after that the water cools off and it stays as just warm water. I hear the gas kick in to heat...
Could be your thermostat but it might be your inlet dip tube. Your water heater has a plastic pipe that carries the cold water to the bottom of the tank. When you open your tap, it takes the hot water from the top of the tank, the cold goes to the bottem and gets heated. If this tube breaks, or comes loose, it will short circuit the cycle. The tank is hot but as soon as you start using water, cold water comes in at the top and mixes with your hot water, giving you just warm water. If you have room above your tank, you can remove the union on the cold side , screw out the pipe nipple, and look inside and see if there is a tube. If not you can buy one from home depot or lowes for just a few dollars. Also a water heater should be partially drained annually to remove any solids from the bottom, which will allow better heat transfer.If you find bits of plastic when you do, then you know where your dip tube went. Also if you've had a hot water faucet stop up and it looked like plastic there it is.
Jun 21, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Alpha boiler - wireless programmer failing
Jan 05, 2009 | Water Heaters
J W-K
Oct 18, 2008 | Water Heaters
Water Heaters Logo
49 people viewed this question
Top Water Heaters Experts
vince
80stech
D. E. Hev
Are you a Water Heater Expert? Answer questions, earn points and help others
