Question about John Deere Garden
John Deere LT 155, why is small amounts of oil dripping into the carburator air intake thru the oil breather hose connected to the intake
    An user who is expert in 3 categories / brands.
  • John Deere Master
  • 924 Answers
Could be a valve issue or timing issue. flywheel key may be sheered a little bit causing incorrect firing.
Posted on Dec 18, 2016
John Deere LT 155, why are small amounts of oil dripping into the carburetor air intake thru he oil breather hose connected to that air intake chamber
the breather hose is the means of allowing the compression by pass gasses to not build up pressure in the sump and it exits into the air inlet system near the air cleaner
for oil to be dripping there indicates
1--excessive oil in the sump
2-- worn rings allowing excessive blow by and boiling the sump oil
3-- incorrect oil used in the sump ( too thin) try a 30w -50 grade
Dec 18, 2016 | John Deere Garden
There is a open ended pipe that runs above engine oil intake, the other end has a hose connected to it? mines leaking fluid thinking gas
Catch what is dripping and see if it smalls of gas, oil or water. Whatever it is I doubt it should not be open ended and should have a hose attached to it that goes somewhere.
Sounds a bit like an Oil Breather Pipe at that diameter.
Take a look at these.
Oil Breather Pipe Bing images
Jan 05, 2016 | 1997 Dodge Grand Caravan
My lt 133 john deere mower has gas in oil and back fires. runs 5 min and stops.
It's going to need a carb kit to fix the problem. Make sure your gas cap is venting ok, because gas expands in the summer and can force gas to pass thru carburetor and flood the cylinder then passing down into the oil. Depending on the age of your mower, the carburetor may have a gas shutoff solenoid on the bottom and this may have malfunctioned. Another is a bad float or needle valve which a carburetor kit would fix. A needle kit with bowl gasket may be all it will need. Hope this will help.
Jul 19, 2014 | John Deere Garden
John deere lt155 lawn tractor shuts off when it gets hot while mowing, could this be electrical?
I had a similar problem lasy year.
Try this:
As soon as the machine seems to be stalling, loosen the gas cap.
If the engine continues to run, clean the gas cap vent hole(s).
Jun 26, 2011 | John Deere Garden
My John Deere stx46 riding mower acts like it becomes starved for gas after using for hour or so. Fuel filter is new, gas line new, coil pack new. Ran fine last year. Filter will be emtpy when dies, then...
Try loosening the gas cap a little...... there is a normally a small breather hole in the top or underside just above the seal which allows a small amount of air to enter into the fuel tank. Sometimes this breather hole gets clogged..... stopping air from entering into the fuel tank as fuel is used. Eventualy enough vacume pressure accumulates inside he tank causing a vapor lock. If you loosen your fuel cap slightly.... this should prevent the problem your experiencing. If it does... try soaking cap in deisel fuel or heating oil overnight, remove and allow to dry prior to re-installing. If the problem persists after a good soak, only option is to replace fuel cap. GOOD LUCK!
May 14, 2011 | John Deere Pto Clutch For Stx38 And Stx46...
When you drive it you can smell oil when it gets hot
Either oil is dripping on ur exhaust pipe and u smell it burning! Or Ur blowback oil/gas is the one ur smelling at, usually on top of ur engine valve cover there is a breather outlet connected with hose and goes thru the air claner housing! The hose might have cracks or been disconnected, check on that! Hope that might help you!
Nov 10, 2010 | 1998 Ford Escort
Need wiring diagram for lt155 john deere riding mower
need wiring diagram for john deere lt 155
Aug 26, 2010 | John Deere Garden
John deere 1010 dozer
Always a filter but it might be an oil bath type.
Apr 26, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Oil leak out of a breather hose
a small amount of oil from the crankcase vent hose under hard acceleration is most likely normal.American bikes don't leak oil,they mark their spot!
Sep 28, 2009 | 2004 Triumph America
Oil dripping off egr valve
I had the same problem, but its not oil. it is coolant. running to the heater. just check for cracks on the little piece of hose on the egr. tri it...
Nov 18, 2008 | 2001 Suzuki Grand Vitara
Garden Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
