Siemens, RDH10RF, thermostat, not turning my heating on
The batteries ran out in my RDH10RF room thermostat. I changed them & now it won't turn on my heating. The connector to it on the wall's lights have gone out. Do i need to reset it? If so, how do i do it? Help me pleeeeeeeze as winter's setting in.
  • Heating & Co... Master
  • 1,919 Answers
You likely lost the settings when the batteries died. Sound like you have to reprogram the tstat as to your application. Like switch heat type FROM GAS to ELECTRIC.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Posted on Dec 18, 2016
How do I turn my Siemens RDE100 underfloor-heating off? It is in a bathroom which gets little use and electricity is too expensive to waste in this way.
Turn it off at the thermostat
Heatwell Thermostat Programming Video for Siemens RDE100 ...
? 14:49
https://www.youtube.com/watch?v=Z7NSZaTW90A
Oct 13, 2013 - Uploaded by Kiwiash Ash
Programming instructions for the Siemens RDE100 series ... Siemens RDE100.1 thermostat ... How do I turn ...
[PDF]RDE100.. data sheet - Siemens Download Center
https://www.downloads.siemens.com/download-center/download?A6V10399978 Nov 21, 2017 - The RDE100.. is used to control the room temperature in heating sy. Typical applications: Apartments ... Siemens. RDE100.. Room thermostat with Auto Timer, Option External Input ..... underfloor heating (only for. RDE100.1).
[PDF]RDE100.1RF operating instructions - Siemens Download Center
https://www.downloads.siemens.com/download-center/download?A6V10410001 Apr 18, 2017 - The RDE100.1RF consists of a wireless room thermostat RDE100.1RF which operates in ... Select Auto Timer mode for the heating period, and.
May 20, 2018 | Siemens Heating & Cooling
Siemens thermostat rdh10rf
If this is battery operated it could be the batteries at fault.
Apr 17, 2014 | Heating & Cooling
Why won't my lg ductless heat pump regulate the room temperature?
After I have been reading up on your unit it appears that the thermostat is not operating correctly. I found this real basic information on installation for your unit. This link I am giving is pretty basic instal schematics. But seems to be something about your thermostat needs to be dialed in or is not working properly.
http://www.premsales.net/docs/GE/GE%20Minisplits.pdf
I hope this helps some. Mike
Oct 21, 2011 | GE Quiet-Aire Ductless Mini Split System...
I just put in this new thermostat, I believe all the wiring to be correct i have one extra wire (brown) that should be a common wire used to keep the display lit. when I turn the unit on cool ( with the...
Heat pumps require specific heat pump thermostat. If you are trying to install a thermostat that is generic forget it. A heat pump is a diff animal than a central unit. Get the thermostat that matches your system. A generic won't cut it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 13, 2011 | Heating & Cooling
Thermostat sensor is not reading correctly
No you need to change your t,stat. Go to home depot or Lowes and get one easy to install Any problems please get back to me I will walk you thru. Rus
Oct 29, 2009 | Honeywell Electronic Programmable...
Improper Termperature Readings during AC run
personally i'd just replace the thermostat, but try pulling the front panel off and look on the circuit board and see if there is a jumper for F/C or any other settings. you may try changing its position. you can also remove the batteries for 15 minutes and see if it resets itself. the only other thing it could be is a wiring issue.
May 29, 2009 | Heating & Cooling
Heat pump auxiliary heat does not turn on
Turn up your outside thermostat in the outside unit.
You should have about 3 degrees difference in one stage to the next. So I would change the thermosat with one that has three stages of heat.
Nov 25, 2008 | Honeywell TH4210D1005 Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
