Question about Tablets & eReaders
How do i switch from laptop to tablet on the transformer k010?
  • yadayada
    yadayada Dec 18, 2016
    Please read the user manual.
  • Stephanie Lankford
    Stephanie Lankford Dec 18, 2016
    I would if I had one, that's my problem..
Sylvania tablet. Why won't it turn on?
First check the output of the transformer with a voltmeter. Should be 9 volts.
If that is ok, then it is likely the switch, and that is not likely to be easy.
Jan 15, 2016 | Tablets & eReaders
My ASUS tablet is constantly 'restarting'. I allowed the battery to die and then plugged it in to switch back on and it is still 'restarting'. Any advice?
Could be a couple of things. Tablets and laptops will spontaneously restart if they overheat - this is most often caused by a failed or clogged CPU fan. You can also get restarts from bad RAM, a bad main board, or failing/failed hard drive.
One suggestion - go to the manufacturers website and see if they have a specific hardware test utility you can download for your device. That might help you pinpoint where the fault is.
Good luck.
Mar 08, 2015 | ASUS Transformer Book T100
Asus transformer book T100TAF is constantly 'restarting'. I allowed the battery to die and then plugged in and switched on and it is still 'restarting'
I don't have one of those but suggest you actually remove the battery completely. Then reinstall it after a few minutes to hpefully reset it.
My asus transformer pad isn't charging ?
IF cable is not an fault, try to replace the power adapter, even if fails try in the desktop or laptop rear USB ports. Hope this may helps U
Feb 28, 2014 | ASUS Transformer Pad TF300 10.1" 32GB...
I cannot connect my mifi verizon hotspot device to my transformer tablet tf300
Delete any other 'mifi verizon' connections from the 'wifi and networks' then restart (switch off for 10 secs by removing power cable) on both mifi and tablet and try agiain.
Jun 01, 2013 | Tablets & eReaders
ASUS Tablet TF101 Wont Charge
batteries do not last forever get it replaced by a computer shop
Jan 05, 2018 | ASUS Eee Pad Transformer TF101A1 Tablet...
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
