New heater gives E4 code when full of fuel. - Heating & Cooling
How to get into bottom section of dishwasher to find a leak
i had the e4 code today. fixed it, thank god.
Sep 09, 2016 | Dishwashers
My Teka DW7 57 FI VRO2 dishwasher shows the error code E4. I press the program button, i select the washing program i want, but on the display the error code "E4" is being blinking. How do I fix it please?
The E4 Dishwasher Error. According to the manufacturer the E4 error will be given if the vent for overflow when water level exceeds the set level overflow water triggers the lower float, terminates operation and gives E4 warning.
Clean the level sensors.
May 15, 2016 | Dishwashers
My SoleusAir portable air conditioner has an "e4" code.
Here are the SoleusAir error codes...
e2 Room temperature outside of working range of unit (too cold).
e3 Faulty coils - Repairs needed.
e4 Internal frost in the unit - Defrost.
e5 General failure - repair needed.
e7 Reservoir full - Empty the reservoir.
If the unit is freezing up (frosting) you may want to check (clean / replace) the filters.
Sep 13, 2014 | Heating & Cooling
The Thermal fuse of the defrost heater in my freezer is tripping.
what is your controller? replace fuse if needed,review your control parameter and find the e4 means.
Dec 05, 2012 | Refrigerators
I have a kirby lester KL15 pill counter that gives an E4 error code, any help would be greatly apprecicated.
Tablet dust or residue on detector windows. Clean glass detector windows thoroughly.
Sep 12, 2012 | Office Equipment & Supplies
We are trying to find out what an E4 on a Celiera
Does anyone know what does that means
Mar 30, 2010 | Heating & Cooling
Monitor 2400 Kerosene heater service
Check your filter in the fuel line outside if you have one. Also check the strainer in the fuel sump.
Feb 02, 2010 | Heating & Cooling
Heayrt won't fire e4 can't hear fan runnung
I am not sure if you have gotten this issue corrected, or not, but the first thing I would try to do is to reset the heater computer system. This sometimes corrects and EO4 error code.
What you will do is open the right hand side door and find the POWER toggle switch, turn that off. Then find the CIRCUIT BREAKER for the heater and turn that off as well, then wait about 15 to 20 minutes. After waiting, you will turn the CIRCUIT BREAKER on first, then the heater. Try and start the heater up.
If the EO4 code comes back, there may be an issue with the heater. If the code does not come back and the heater starts, then the error code was what I call a "computer hic-cup".
Jul 04, 2009 | Pentair MINIMAX NT TSI IGNITER
The washeer machine give a error code E4
A code of E4 means that there is to much suds or the pump is blocked. use less detergent and get detergent with he in the title. turn to off and try to restart the drain to correct problem.
You will find the code in the manual. If you do not have let me know I will send you one here.
Good Luck And Please Rate FixYa!
Dec 19, 2008 | Washing Machines
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
