Question about Kitchen Appliances - Others
Element spring on cousinart rice cooker won't go down. So it won't lock in cook position. Any fixes suggestions?
SOURCE: Sticking of cooked rice inside pan
Buy a rice cooker with non-stick inner pot.
Posted on Sep 26, 2007
SOURCE: rice cooker vs a crocpot/slow cooker
I have both and use both for different things. The rice cooker cooks faster than the slow cooker. What the Crockpot does really well, the rice cooker cannot do. For example, with the crock pot, you can buy less expensive cuts of meat and because of the slow cook method, they will be tender, juicy, and delicious. You can make soups, stews and casseroles in a crock pot and the great thing is that you can turn it on low, go to work, and when you come home, dinner is done. You can cook the same types of things in a rice cooker but you can't leave it all day. You CAN saute', fry, etc,. in your rice cooker which you can't do in a crock pot but for dense veggies and tougher cuts of meat, stew beef for example, there's no comparison. I have an Oster Rice Cooker and Steamer which I use nearly every day. I cook rice, obviously, casseroles, veggies, spaghetti and meatballs, all kinds of side dishes and soups in it. I use the crockpot several times a week but more often in the Fall and Winter when I make soups, stews, chilis, roasts and BBQ. Oh my gosh, you have to try BBQ Ribs in the crock pot! They melt in your mouth. Go to Yahoo! Groups. You'll find all kinds of great info for both your rice cooker and crock pot. I have one of the fancier, more expensive crock pots because I take it to work with me one day a week for lunch. The lid seals and it comes with a carrier. If you do most of your cooking at home, you can spend a little less and get a good one. I recommend getting one that has at least 3 heat settings though. Different foods require different temps. Happy Cooking!
Posted on Nov 07, 2007
  • 48 Answers
SOURCE: toggle lever will not stay on "rick cooking" option
well your rice cooker needs to be replaced.. if you still want to use it, then have it fixed by a technician coz it needs electrical expertise to handle the wirings inside it..
Posted on Jan 23, 2008
  • 19396 Answers
SOURCE: Wolfgang Puck 7 cup rice cooker instruction manual missing
Here the standard manual : WOLFGANG
However you can read and print recipes online from their website , click below:
Rice Cooker Recipes Cookbook : Recipezaar
Rice Cooker Creations Cookbook
Posted on Feb 27, 2009
SOURCE: Need directions for Comet stove top rice cooker
Fill the bottom to the line with water. Put two cups of rice in the top and two cups of water. Put on stove top on high until lower water is boiling, turn to medium heat. For white rice check after about 20 minutes, if water is assorbed and rice is tender, fluff with a If it needs a few more minutes of cooking, no problem.
Brown rice will take about 45 minutes.
I have used my stove top cooker for at least 35 years...ordered it with box top and some money from Comet Rice.
Posted on Apr 22, 2009
Rice always overcooked until become black. Is it the thermostat problem....?
Maybe, but look inside the cooker with the pot removed and check the button in the center....make sure that it will spring back up after you push down on it. If it is stuck in the down position the cooker will stay on high cook and not go to warm....
Check if something is stuck in it and get it out if there is anything there so that the button will freely move up and down...
If that is working well then it could be the t-stat...
Jan 26, 2011 | Salton RA14 14-Cup Rice Cooker
Aroma rice cooker ARC 978 - all control panel lights stay on when pluggged in. How do I reset??
Unplug the rice cooker and the remove the cooker kettle. Push the steel button in the center of the rice cooker to loosen the spring. Plug the rice cooker without the kettle, the cook function must not be functioning. Plug it again with the kettle and push the cook switch to see if it working properly.
Nov 08, 2010 | Aroma ARC7031G 6Cup Rice Cooker
My rice cooker, its not responding. Panasonic SR G06. power is ok , but its just dont want to cook! why??
check replace the micro switch of your rice cooker it is the switch that is connected to the cook and warm button....check for the heating ellement it is the coil that heats to do this open the bottom cover of your rice cooker you can see a round shape fillament examin whether this fillament is not brocken and is connected to the power source
May 20, 2010 | Panasonic SR-W06NA 3-Cup Rice Cooker
Tiger rice cooker (model JAT-A55U): Rice is not completely cooked
This one has several options to cook different types of rice, white rice, brown rice, sweet rice.... Press the menu to see the correct setting you need for what type of rice you are cooking before pressing the cook button.
Sep 02, 2009 | Tiger JAT-A55U 3-Cup Rice Cooker
Tiger rice cooker
There is a sensor that regulates how hot the cooker gets and shuts it down to the warm setting when it senses that the heat is too high...meaning that all the water has cooked guess is that the sensor failed and as far as I know it is not replaceable.
Here is a tip that I wrote about rice cookers and the amount of rice and water needed...
How much Rice and Water go in the Cooker
Jun 25, 2009 | Tiger Corporation JAGS18U 10-Cup Rice...
The preassure switch may be not working right.
It may be corroded, etc.
Unplug the unit and push it back several times, try to see if the spring is working, etc.
Apr 02, 2009 | Hitachi RD5086P 8.3-Cup Rice Cooker
E01 Error
The rice cooker lid has to be closed and the dial knob has to be in the lock position (turing on the pressure lamp) before cooking can start. There are two tiny wires sending signal to the main controller to indicate that the cooker is in lock position. The wires are vey tiny and they can break over the years as a result of opening and closing the lid many times. When these wires are broken, the main controller cannot detect the lock position and will give E01 Error.
Feb 02, 2009 | Panasonic SR-PRA18N 10-Cup Rice Cooker
Rice Cooker promaturely pops up before rice is cooked
try adding a little less water, And letting it sit about 4 min to make sure the steaming has stopped
Oct 21, 2008 | Zojirushi NRC-15 8-Cup Rice Cooker
Toggle lever will not stay on "rick cooking" option
Nov 30, 2007 | Tiger JNP-0550 3-Cup Rice Cooker
Kitchen Appliances - Others Logo
55 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
