No picture on 94 32" phillips. The fuse is good.
Slow to turn on Phillips flat screen tube big screen
That is a common issue with the last generation of the phillips big screens, the best answer for this is one that i got at a meeting with phillips service several years ago. On philips the tv will not show a picture till the tubes are balanced out, simular to sony, but in a phillips if the white balance is not correct the picture and sound will be muted till all three tubes have warmed up enough to produce a good white balance. As the set ages the tubes become weaker and this procesess takes longer.
May 07, 2010 | Philips 43PP9202 43" Rear Projection...
NO PICTURE OR SOUND ON MY PHILLIPS MATCHLINE LCD TV 15PF9936 PLEASE HELP!!!!!!!!!!!!!!!!!!!
make sure it has power at the outlet,then suspect a blowed fuse or dioed or flyback,etc.
Feb 13, 2010 | Televison & Video
Downloading photos from computer to phillips 8ff2fpb photoframe
Your PhotoFrame does not have internal memory acording to the Phillips data sheet, therefore you need to load your pictures directly onto a memory card (one from your camera will proabably work.) If that isn't convenient, you can generally get a good price on a SD memory card which is supported by your PhotoFrame.
If you wnat to transfer pictures from your PC to the memory card and have a card reader, you can transfer the pictures in Windows Explorier from your PC to the memory card and then plug the card into your PhotoFrame. If you do not have a card reader, plug the memory card into the PhotoFrame and connect it to your PC using a USB cable (you may have to buy one as acording to the Phillips data sheet it is not supplied.) When the PhotoFrame is pluged in it will appear in Windows Explorier as a new hard drive, and you can copy your pictures to it.
I hope this helps,
Mike
Jan 03, 2009 | PANDIGITAL (DPF802) Digital Picture Frame
Phillips 60PP920217F big screen TV
does anyone know why the picture does not come on .Is there any fuses that might of gone bad?If you know respond to this ?thanks
May 15, 2008 | Televison & Video
Turns on but no picture or sound.
please check the connection wire/cable that gives power to your tv. if no fuses are blown. it may be a capacitor problem.
Mar 30, 2008 | Philips 50P8341 50" Rear Projection...
Phillips 17 in, tv/vcr combo
the problem should not be the fuse if its the sound problem, i am having the same problem with the same tv and im an electronics tech and i have yet to see whats exactly wrong. but if you do want to try a new fuse its a 4A 250v fuse but the base where the plug connects into. if i find what the exact problem is i will come back on and tell you of my findings.
Mar 10, 2008 | Philips 14PV225 14 in. TV/VCR Combo
Power but no picture
does it have a menu come up on the screen yet?
Nov 21, 2007 | Televison & Video
My 42 inch plasma wont turn back on after power cut?
We purchased a phillips plasma 50" in july 06 and it cut on and off 5 or more times a day I called phillips customer service they told us it was due to the cable company they came out and changed the tv jack gave us a new box and tested the lines said everything was ok. The problem still kept happening got back to phillips and they sent us a flash drive to update the info in the tv. still kept happening told us it was due to tv being sensitive to power flutuations. well we are now 5mths out of warrenty and the power board blows up! phillips will not do anything to help the person I spoke with admitted we were given bad advice the bill was estimated at over $500 so if I were you if its still under warrenty make them send someone out to look at it, Reading up on phillips tv complaints this seems to be a common thing By the way phillips customer service sucks dont rely on them to help you much. good luck
Jul 02, 2007 | Philips 42PF7320A 42 in. Plasma HDTV
No Picture
I replaced about 10 electrolytic capacitors and a PWM controller IC (MC34067P). Fortunately, i found an almost identical schematic diagram in the internet, so i started troubleshooting. To make it short, i replaced most of the electrolytic caps and mylar caps in the Preconditioner stage and VsVa Power supply stage. And finally the PWM Oscillator IC (MC34067P). You have to make sure that the Preconditioner stage is running ok, with an output of 380 to 395 volts DC. There are two fuses on the board (in my 32FD9954), one is for the mains AC located near the mains connector coming from RF filter (two wire connector- large wires), the other fuse is in the middle of the board. You measure the DC voltage on this fuse on the middle of the board and it should be about 380volts or above. The real culprit is the PWM IC. Initially i replaced the MOSFET (STY34NB50F) in the Preconditioner, then the caps, then finally the IC. Then it worked!!! I put back the old MOSFET, it's not damaged, so now i have a spare one. Just replace the electrolytics near the PWM IC (2.2u, 4.7u, 100u, 1000u) I think the design problem is that the IC is nearly located to the heatsink which generates lots of heat. The IC deteriorated in time and the electrolytes in the capacitor evaporated due to the excessive heat inside the case. I'm thinking of incorporating 120cm computer fans at the back to suck down the heat. Happy troubleshooting. I have the necessary diagrams if you need it. regards, Valerio
Oct 31, 2006 | Philips 17PF8946A 17 in. EDTV-Ready LCD...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
