Question about Kitchen Ranges
How do you change the clock on a Modern Maid gas over/range from 24 time to 12 hour times?
  • 12 Answers
SOURCE: 24 hour-12 hour time
Press Set - hold (top Left button) -When the sec start flashing go to the bottom left button press it 3 times -When the hour flashes press the bottom right button 1 time -Press the top left 1 once with
Posted on Jul 05, 2007
SOURCE: 24 hour clock
Press and hold the time button til it flashes 12H.
Posted on Dec 11, 2007
  • 29 Answers
SOURCE: How do I get my Timex WR50M watch out of the 24 hour (military) time and back to a 12 hour clock?
Hold down the adjust button bottom right then press the mode button top left you will notice the a or p that stands for am/pm will disappear & reappear. If you have an a or p on your display then you are out of military time.
Posted on Mar 12, 2008
SOURCE: change the time setting from 24 hour to 12 hour AM PM
Check this
Go to start>settings
Go to the system tab and the regional settings icon
Go to the time tab and it should be hh:mm:ss tt for 24 hour clock
Let me know how that works out for you
Posted on Mar 06, 2009
  • 52 Answers
SOURCE: clock in 24 hour mode
On first generation Bose, press "Alarm Setup" and "on/off" button to toggle between military and 12 our time.
Older model documentation:
Posted on Dec 04, 2010
How do I convert clock from 24 hr display to 12 hr display on my GE profile gas oven with digital display?
Here are the instructions for changing the clock from 12 to 24 hour and back.
12-Hour, 24-Hour or Clock Black-Out
Your control is set to use a 12-hour clock.
If you would prefer to have a 24-hour
military time clock or black out the clock
display, follow the steps below.
Press the BAKE and BROIL HI/LO
pads (on models, use
the upper oven controls) at the same
time for 3 seconds, until the display
shows SF.
Press the CLOCK pad once. The
display will show 12 hr. If this is
the choice you want, press the
START pad.
Press the CLOCK pad again to
change to the 24-hour military time
clock. The display will show 24 hr.
If this is the choice you want, press
the START pad.
Press the CLOCK pad again to black
out the clock display. The display
will show OFF. If this is the choice
you want, press the START pad.
NOTE: If the clock is in the black-out mode, you
will not be able to use the Delay Start function.
Oct 04, 2017 | GE Kitchen Ranges
How do you change the time from a 24hr clock to a 12hr clock. For example clock says 19:50 instead of 7:50 pm on a Brookstone 5-in-1 Sensor Clock.
Selecting 12- or 24- Hour Mode While in the Time screen, press or to select either 12- or 24-hour mode. If 12-hour mode is selected, PM displays for the afternoon/evening hours. AM does not display for the morning hours
Apr 06, 2016 | Brookstone Audio Players & Recorders
Change 24 hour clock non military time
You could select the 12 Hour clock mode instead of 24 hour as it may be set at now.
Also it needs to be confirmed if the audio system fitted to your vehicle supports 12 hour clock. Please check the two documents below after turning to the section on Clock setting. The menus to set this could vary depending on which audio system you have.
Aug 29, 2014 | 2007 Land Rover Range Rover Supercharged
How do I set the 24 hour clock back to 12
Press 0 (Set up options) and then 4. Then press Auto Set (on the right of the clock) to change the setting. Then press any touch pad except Cancel to exit the setup menu and save the change. (Alternatively, press 0 and 9 followed by Auto Set and another key to return all features to the Default. 12-hour time is the default for the Jenn Air range.) Jenn Air has the manuals for most of their products on their support site, . I looked at the manual for the JES8850AAB which is available here: The information on setting the options is on page 12 (page 13 of the PDF). Note you'll need Adobe Reader or a similar program to access the manual.
I hope this helps.
Jul 08, 2014 | Jenn-Air JES8850 Electric Kitchen Range
How to change from 24 hour time to 12 hour time
The change from 24 hour to 12 hour display is semi hidden. I found the instructions and followed the set up, this change follows the settings for minutes in the sequence, so right after you set minutes on the clock push up or down and that will change the 24 hour clock.
Mar 07, 2014 | dr. Tech WF-1070T Home Wireless Weather...
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
oven can be changed from Fahrenheit (°F) temperature to Celsius
Oct 26, 2012 | Wolf Range Ovens
The digital clock seems to be set to 24 hr insted of 12 hr time
No Problem here ya go
To change the clock to 24-hour format:
1. Press and hold the CANCEL and Delay
pads for three seconds.
2. Press the More+ or Less - pad to select
12 or 24 hour.
Jan 14, 2009 | Maytag MER5552BAW / MER5552BAQ /...
Kenmore Range clock issue
That works, to change from military 24 hour to 12 hour format press and hold the clock button until it beeps and changes the displayed time, e.g. from 20:01 to 8:01. This worked on my Kenmore Elite Range. If you get the dreaded F1 error, you'll likely have to replace your clock timer board.
Apr 02, 2008 | Kitchen Ranges
Clock format
24 hour mode is all there is. Time to learn military time.
Feb 11, 2008 | Protron PD-DVR100 DVD Recorder
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
