Question about Timex Watches
Timex T78587. The pin holding the metal strap to the time piece has snapped off. Is that repairable?
  • Timex Master
  • 18,201 Answers
Take the watch to a jeweller or you can fix it yourself. That pin in the watch is removable. Use the tip of a jewellers screwdriver to push the ridge inwards. You should be able to fold the end of the strap back around it. If not, they will sell you a new strap and fit it.
Posted on Dec 18, 2016
How to set the time on timex WR30M watch?
hi Janet.
You may also need to change the time when traveling or to adjust for daylight saving time.
  1. What to Look For. Locate the MODE button, the SET/INDIGLO button and the START/STOP button on the side of your Timex Indiglo WR 30M.
  2. Setting the Hours. Press down the MODE button until "TIME" appears. ...
  3. Setting Minutes and Date
How to set the time on timex WR30M watch Google Search
Dec 13, 2017 | Timex Watches
My Mum's Timex watch has lost the winder Please can you help.
Yes I can. Send it for repair.
REPAIR form instructions ' Timex Canada English ' Wear It Well
  1. Cached
  2. Similar
Warranty & Repair Watch Repairs and Attachments for Timex Retailers If you are a Timex retailer looking to buy a strap/band or wanting to have your customer's ...
Support ' Timex Canada English ' Wear It Well
  1. Cached
WATCH AND LEARN ... How to Change Your Watch Strap. Can you tell me what it will cost to repair my watch that is no longer under warranty? Repair charges ...
  1. Cached
WATCH REPAIR FORM PLEASE FILL IN (PRINT LEGIBLY). How to Prepare your Repair Request. Warranty Information. Name: Date: Address: Appt / Suite: City:.
Timex ' Warranty
  1. Cached
Please note that Timex may, at its option, repair your watch by installing new or thoroughly reconditioned and inspected components or replace it with an ...
Customer Service - Timex
  1. Cached
Customer Service. Check Order Status Ship Your Timex Return Your Timex Find Watch User Guides Warranty & Repair Frequently Asked Questions ...
Timex watch Google Search
Dec 28, 2016 | Timex Watches
Watch strap that holds face of watch separates and face falls off
mcdevito75 here, Besides online with Timex for another original strap, you can also look for a small watch repair shop in your area for a replacement strap.
Jul 05, 2010 | Timex Ironman Triathlon 50 Lap Digital...
Is it worth trying to replace battery of my heart rate monitor
You certainly have had good service out of the battery. It is best left to a watch repairer to replace the battery.
Feb 10, 2010 | Polar F4 Heart Rate Monitor Watch
The resin straps on either side of my heart
Where can I take my son's Marcel Drucker to get the crystal face that was broken in pieces?
Sep 06, 2009 | Ironman 90 Timex Heart Rate Monitor Watch...
How do you unlatch the metal piece that holds the battery in?
If you see no screws holding the contact (you say metal piece), follow all the way down to that contact in to watch movement and you will find the point where it is hooked on to a tiny plastic hook.
Take fine pointed tweezers and pull the contact leg outwards. This will release the contact and the battery.
Rate me, please.
Apr 03, 2009 | Timex Watches
WV-57H Watch - how do you replace the strap? I have a new strap for this model and can't work out how to take the old one off and fit the replacement. Thanks
If you look at the watch from the side, you'll see that there's a two-part metal piece on the underside of the watch on each side.  The metal piece is a spring-loaded pin going through the strap which is holding on a larger metal piece.  You need to get another small pin (or an eyeglass screwdriver might work) so you can poke in the end of that spring loaded metal piece, which will allow you to slip off the larger metal bracer.  Then you can poke the spring-loaded pin entirely out of the strap and it will be freed entirely.
To help you visualize what you are doing, the spring-loaded pin operates similarly to a toilet-paper roll - you need to compress the pin so you can slip off the larger metal bit, then take out the pin, which will free the strap.
Oct 30, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Can not open the band to put it on
Take a thin bladed knife and slide it between the watch strap and the buckle part of the watch body. The pin which holds the strap to the watch is spring loaded like a toilet roll spindle. Very gently twist the knife blade to release the pin from the body.
Be warned, getting the pin back into the watch can be very fiddly.
May 05, 2008 | Timex 27191 Wristwatch
Timex 1440 Sport watch needs a new strap
Hi I have a 1440 sport watch , somehow I got it into 24 hr mode vs regular time. Can't seem to figure outhow to get it out of this.....HELP :)
Mar 22, 2008 | Timex 1440 Nylon watch
Screen goes blank
I put a new CR2025 battery in my T5e671 Timex and it solved the problem.
The screen no longer goes blank at any time.
PS:Timex manual says "remove battery strap" to replace the battery.
But it doesn't say HOW.-& I couldn't google an answer to that.
Here is how:
The metal strap goes across the middle of the battery and then goes over the edge of it on both sides.
At both edges the metal strap goes over a nylon tab.
One of those nylon tabs is notched, if you put the end of a paperclip in the notch, you can release the metal strap edge that runs under it.
Oct 14, 2007 | Timex Ironman Triathlon 51931 wristwatch
Watches Logo
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
