Question about DISH Network Televison & Video
I need the channel number for AMCHD on dish network
  • DISH Network Master
  • 16,621 Answers
Do i need to program my remote to change channels on the dish network
Hey knapshak, Tommy Faust with DISH Network here. It would need to be programmed to the receiver in order to change programming. You can do that by following the steps below.
1. Access System Information screen from your main TV.
2. Note the number on the bottom of screen next to Remote Address.
3. Hold SAT until all buttons on top light up then release.
4. While SAT is blinking enter a number between 1-15 and press # (Different from number listed)
5. Press record 3 times and the number should change, try the remote and see if you can change channels.
You can also check out this link for more information:
http://www.dishnetwork.com/SupportSection/remote-setup
Tommy Faust
DISH Network
Mar 19, 2011 | DISH Network IR Remote Control
My remote won't let me channel down past a certain channel, I can type the numbers in and it will go but if I try to arrow down channels it goes about 5 channels and then starts back over where it started,...
mp_383
What channels are you able to receive? When you press the Select button on DISH remote, which light on the top of the remote lights up? The Sat button should light up when you are in satellite mode. If any other button lights up, press and release the Sat button and then try changing channels. If this doesn't work, we may need to troubleshoot with you. Please call us on 1-800-333-3474 and speak with Tech Support. I hope this helps.
Ray Calo
DISH Network
Mar 08, 2011 | DISH Network 135899 Remote Control
My Hd channels are saying complete signal loss then later they are available again, then complete loss again. Can switch to non hd channels but want the Hd. What do you suggest
Hi edhayes27 my name is Mike Houston of DISH Network Executive Office. This posting in FixYa shows you have the 311 receiver; this receiver will only show SD channels. We do have the VIP 211 which will show in HD and SD channels. If possible can you verify the model number of your receiver, which indicates you
Jan 12, 2011 | DISH Network 311 DTV Receiver
Cannot get a clear picture with dish network I have a Clear picture when using DVD
Sometimes the input/channel for the DISH Network and the DVD are different, and if using the same for both, then you will get an unclear picture on one. If at TV1, the tv will need to be on channel 3 or 4, and possibly an input such as video 1 or 2. The DVD player may be on a different input, such as video 3, or even just on channel 3 only. If at TV2, the tv needs to on channel 60 or 73. When using the DVD, try putting the tv on channel 3 or 4, that is normally the channel that the tv needs to be on. Also, make sure that the DVD player is not on while you are trying to watch just the dish.
Becki Barned
DISH Network Customer Service
Dec 03, 2010 | Apex Digital LD4088 LCD TV
I have a samsung lcd 650 series tv and a dish network remote. I can use the remote to change channels and control power and volume to my TV. I cannot change the picture size and the picture on most...
We would be happy to help get that fixed. It sounds like you may be in the incorrect screen format. Press the * located below the number 7 on the DISH Network remote control. Cycle the formats to determine the screen format that fits best.
We hope that this fixes it for you. Thanks so much for choosing DISH Network!
Phillip Chang
DISH Network Customer Service Department
Oct 27, 2010 | Samsung AH5900092W Remote Control
Can't use remote to change dish channels batteries are working fine
Hello my name is Michael Hurst with DISH Network. Sounds like your remote may need to be reprogrammed to the DISH receiver. You can press the Menu button on the receiver and that will get you to the System Info screen. Once you have this screen then press and hold Sat button until all the buttons on top of the remote flash red. Let go of the Sat button and pick a number between 1-15. Once the number is selected then press # and then Record. Watch the remote code number on the System Info screen. If this doesn't work then unplug the reciever from power outlet for 10 seconds and perform the step again.
Jul 03, 2010 | DISH Network IR Remote Control
My dish remote wont connect to the dish reciever
If you have a single mode receiver, you need to open the panel in front and push system info.
A channel number will appear near the bottom of the list of information... it may be between 1 and 15. Push the record button on your remote control. (the black button with the red dot). If the channel number changed, then your remote and receiver are not on the same channel. Assume your channel was #1. when you first pushed sys info. You need to program your remote to #1. On your remote, push the Sat button until all other top buttons light up. enter the digit 1 and then the # key. Press the record button 4 times. You have to make sure you have the correct color key inserted in the remote control. If you have a dual mode receiver, one remote key will be green, and the second channel remote will have a blue key. Go to the Dish network website tech portal ...Google will help you find it, for complete instructions from the horse's mouth.
May 03, 2009 | DISH Network 311 DTV Receiver
Hooking up a tv
Hi first of all are you using scart leads to plug into each device here is how it should be set up ok
1. Scart lead from dish network into vcr
2. then other scart from vcr into tv
3. Now ti recieve the signal from the dish network you need to have the telly on the right av channel so that its picking up the signal from the vcr.
you can test this by changing the channel on the vcr controll or direct via buttons on vcr.
If the channels change then your on the right av channel.
Now when your on right channel on telly you need to now make sure dish network is on and on a channel or press the tv guide button just so you know what your looking for when the picture comes through.
You need to press av on the vcr controll this will then pick up the signal from the dish network via the scart lead as av is the channel for scart lead.
say if you was recording from dish net to vcr you would put the vcr on av to pick up the signal so press av on vcr controll this should then allow you to watch the dish network with no problems.
Let me know if you still cant and ill assist you further if it dont work tell me what you have done so i know how much you have done ok
Feb 10, 2008 | Toshiba TheaterWide 46HM94 46" Rear...
Televison & Video Logo
23 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
