Honeywell TH8320U1008 I am having trouble setting my thermostat. It is on some hold that I didn't set. How do I release that and set it to what I want . Right now it is set at 78 but it is 85 in my house. It is stating that I am on a schedule, but I didn't set that.
    Problem Solver:
  • 12 Answers
Simply push cancel. That clears the hold feature.
Pushing hold once gets - permanent hold.
Pushing hold twice gets - days of permanent hold. So you can set it if you are going away on a temp and at the end of the days it goes back to normal operation.
Posted on Jul 23, 2009
Trying to set temp on honeywell t-stat
I believe what your experiencing is the 75 degrees is the hold temp position...the display then reverts back to the actual room temperature...it doesn't mean the set temperature changed back to 65 degrees. Try to reprogram the thermostat schedules, and try not to use the hold function...just the temporary hold. (which is bumping the programmed temperature up or down until the next programmed period)
Dec 09, 2013 | Honeywell Programmable Thermostat Heater
My honewell th8320 is reading error 126 or 626
Look in the manual that came with the thermostat it will give you the problem for each code.
Nov 11, 2009 | Honeywell Electronic Programmable...
I REPLACED BATTERIES ON MODEL # TH8320U1008 THERMOSTAT, AND AM WONDERING IF I NEED TO SOMEHOW RESET SOMETHING TO GET THE A/C UNIT TO TURN ON. I GET A CLICK SOUND AS IF THE AC WILL TURN ON, BUT IT DOESN'T....
Go to instuctions and find procedure to go to Advanced Settings. I think it is #170 to identfy the system you have if heat pump go to 190 and set to A/C Mode 0
Jun 27, 2009 | Honeywell Electronic Programmable...
Replacing thermostat: tstatccshp01 with th8320u1008
Hook up o to o/b, then in the installation programming set the change over valve to energize in cool. Then hook up w to aux. Good luck.
Jan 21, 2009 | Heating & Cooling
Manual Thermostat replcaement with Programmable Digital unit.
Hopefully there are markings on the old t-stat as to what terminal is what.
on the honeywell 8000 use the heat pump labeling and then the standard wiring would be
R- red
AUX-white
Y- yellow
B- O/B
C- black
G- green
There should not be a bare wire, it probably just has the insulation stripped back way too far.
You should probably open the furnace and compare the terminal label in the furnace to the wire color. normally yellow and blue pass through the furnace and are wire nutted to wires going to the outdoor unit. In the furnace the white wire will connect to the w or w1 terminal. also, you will need to set the Honeywell stat to have the following parameters.
170-7
190-1
200-0
other parameters that I did not specify, you may read the manual and make your own decision but I recommend factory settings for the other parameters
Jun 14, 2008 | Ruud UBHC Air Conditioner
Wiring a Honeywell VisionPRO TH8320U1008 Thermostat
the thermostat will to any temperature but will not shut off
Nov 25, 2007 | Honeywell CT3600 7 Day Electronic...
Heating & Cooling Logo
348 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
