Question about Waterco Pool & Spa
How much sand goes in a waterco 8600 sand filter
    Scholar:
    New Friend:
  • 66 Answers
Leave 10"-12" empty space above sand (freeboard).
Posted on Feb 12, 2017
I have a waterco pump and sand filter and can't get a high flow thru the pump to operate the creepy crawly
see if it works on recirculate if it does change sand or backwash if suction based and you have multiple inlets close the ones not being used if it is connected to a pool return close the other return valves or plug them while cleaning
Sep 14, 2015 | Waterco Pool & Spa
How do I replace the sand in my waterco t400 pool pump. Is there a manual available
Replacement of the sand is easy but there are a couple of things you want to do first.
Make sure you have a good shop-vac, get gloves, and purchase the proper sand.
This sand filter calls for #20 silica filter sand. (this will be available online, at your pool store, or at any water treatment facility).
Here is the link for this filters manual, and for the brochure (which has good pictures)
http://www.waterco.com.au/CMS/uploads/brochures/ZZB0512_Thermoplastic.pdf
http://www.waterco.com.au/CMS/uploads/Manuals/Sand_manual_829006.pdf
The manual has step by step instructions on filling and starting the filter.
The only part it doesnt tell you about is how to empty the old filter media.
To start this:
1. turn off circulation pump
2. Bleed any pressure or vacuum from the system using the bleeder valve, or just rotate the multi-port valve.
3. Open the drain valve at the bottom of the filter if there is one (some dont have one)
4. remove the collar between the multiport valve, and the tank. (this should be 2 phillips head screws)
5.Remove the multi-port valve.
you now have access to the sand.
6. Remove sand by whatever means (either a scoop or a good shop-vac with a thick hose)
be sure to be carefull once you get 2/3 of the way down the inside of the tank. There are LATERALS down there that are most likely brittle from chlorine.
Once sand is removed check and clean the laterals at the bottom of the tank.
Clean and flush the filter body and follow the directions in the manual to fill and start-up the filter.
If this helped, please vote positively for me.
Nov 01, 2010 | Pool & Spa
How much sand goes into a waterco t600 sand pool filter
Hello. 265 pounds of sand required. Here is the link
http://www.aqua-man.com/row_num.asp?ic=51945&froogle=1
please rate my answer as very helpful. thanks. Joe
Mar 31, 2010 | Garden
Pool & Spa Logo
385 people viewed this question
Top Waterco Pool & Spa Experts
Andrew Taylor
Andrew Taylor
Jay Finke
Jay Finke
Are you a Waterco Pool and Spa Expert? Answer questions, earn points and help others
