Question about Water Water Heaters
Turned off power at breaker to water heater to fix a water leak under house. Turned power back on and no hot water..do I have to hit reset or something?
  • Water Master
  • 20,997 Answers
If it is a Gas Water Heater, you need to relight the pilot. If it is electric, I have never seen a reset on a tank. There is just the single or double element and a thermostat.
Check the breakers again, sometimes they look closed but they are slightly away. Pull the breaker on the heater all the way off and then all the way on until it clicks.
Posted on Dec 18, 2016
  • 2 more comments
  • Michael Sanford
    Michael Sanford Dec 18, 2016
    Very helpful..thanks
  • Andrew Taylor
    Andrew Taylor Dec 19, 2016
    My pleasure. Is it gas or electric and did the advice fix it?
  • Michael Sanford
    Michael Sanford Dec 19, 2016
    It is electric. Checked breaker...problem solved.
  • Andrew Taylor
    Great. Thanks for the feedback. Sometimes if the breakers are used as a switch or are old, they will get lazy and not snap back properly.
3 Suggested Answers
  • 760 Answers
SOURCE: i have a 50 gallon
If you're having to reset the breaker, then most likely you have a bad heating element. Usually the bottom element burns out first, however if you had the water off, and the level dropped in the tank, the heater might have come on without water in it. This will cause it to overheat and burn out. Now when you turn the breaker on, the current is going to ground, tripping the breaker. If you are handy you can replace them, but be sure water heater electric is off or disconnected, and then drain water below the element level. While you're replacing one element replace them both.
Posted on Oct 13, 2010
heatman101
  • 43501 Answers
SOURCE: The breaker for the reliance electric hot water
If your electric hot water heater is not working...check out this tip about electric hot water heater problems
Electric Water Heater not Working
heatman101
Posted on Jan 12, 2011
Just replaced all my hoses did everything i needed to work on a heater and all went well until I turned on my breaker and the top of the tank where the wires are connected started to smoke
it definitely needs to dry out when dry you need to test the components --thermostat--the element [s] --if damaged repair or replace most reasons hot water heaters are replaced is because the tank leaks or rusts out --the components are easily replaceable and inexpensive
Oct 28, 2016 | Water Water Heaters
Model 71-52DB 50 gal. water heater stopped heating
Press the reset button located on upper thermostat
Following link has troubleshoot for electric water heater
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 13, 2012 | Rheem Water Heaters
Water is over flowing and coming out over the top of my hot water heater, i shut the water off and turned the temp down and turned the water back on after a few hours and water still is over flowing over...
If pipes are leaking, then that can be repaired.
If tank is rusted out and water escaping from the tank, then turn off the water plus power to the heater for safety, and then replace water heater.
Rusted water heater can be welded for repair, but remember that hot water is under pressure and tank can rupture any time.
Safest course if to replace heater.
Open following link for leaking water heater checklist:
http://waterheatertimer.org/Leaking-water-heater.html
Jul 27, 2011 | Whirlpool Water Heaters
I have a 50 gallon electric water heater..trying to fix a leak elsewhere in the house we had to shut off main valve,turned back on no hot water,,reset breaker and reset button worked fine,but no today no...
Oct 13, 2010 | Whirlpool Water Heaters
Water heater not working after turning up heat
Did you turn the breaker completely off, then back on? When a breaker trips it is in a middle position, and nust be turned off to reset it, then it can be turned back on.
Mar 14, 2010 | Stiebel Eltron TEMPRA 24 Tankless Water...
Water heater makes a constant hissing noise with power on or off?
You have a water leak under the house, but need to know if it's a gas heater or electric. check the Pop off valve on top of the tank it has a short handle and should go threw the floor pull up on the valve and let it sit back down, if it stops the high pressure pop off valve is leaking, you can buy it and replace it for 5 or 10 bucks, if that does not stop it look under the house. Also use a broom stick and put the round end at the wall and the other end near your ear and check the wall and floor for the noise the closer you get the louder the sound. Hope this helps. If you look under the house and see water you know you got a leak in the pipes or the tank itself.
Jan 05, 2010 | RELIANCE ELECTRIC WATER HEATER
Electric Bosch tankless water heater wont heat water.
Here is the run down>
Water too cold Neon light on:
Cause:
1). Water flow is too high-adjusting the water flow as follow; open fully both inlet and outlet shut-off valves at the heater, then turn on fully the highest flowing hot water faucet closest to the outlet connection. Adjust the outlet shut-off valve until the water flow from the hot faucet corresponds to the approximately 3.6gal/min at 105 degree.
2). One of the power supplies is not on-check the breaker box, there should be three ganged breaker, each corresponds to each of the heater power supply.
3). The power supply voltage has dropped-reset the breaker in the breaker box.
4). Temperature dial is turned too low- temperature adjustment is made using the dial on the bottom edge of the unit. The adjustment is between approximately 95 and 135 degree F. Turning the dial clockwise increase the temperature settings.
5). The inlet water temperature has dropped-readjust the temperature dial.
Attached link is for Bosch hotwater heater installation. This should give you idea as to what to look for.
http://www.boschhotwater.com/Portals/7/TechManuals/AE115_AE125_English.pdf
The following link is Basch Hotwater troubleshooting Q&A, this should also give you some help.
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/PowerStarModels/AE115AE125/Troubleshoot/tabid/632/Default.aspx
Please post back on this thread, If you still having problem.
Jan 27, 2009 | Bosch PowerStar AE125 AE125 Whole House...
Water Heaters Logo
46 people viewed this question
Top Water Heaters Experts
vince
80stech
D. E. Hev
Are you a Water Heater Expert? Answer questions, earn points and help others
