Question about Bosch Saws
I have a older bosch jigsaw. It was working great then all the sudden it makes a grinding noise and the blade will not move. Any ideas?
  • Bosch Master
  • 20,966 Answers
They are a good make. I had all Bosch power tools in the UK. Remove the screws, split the case and have a look. Something has come adrift or broken.
USA
https://www.boschtools.com/us/en/dl/dealerlocator/dealersearch/#ServiceNetwork
Canada
http://www.bosch.ca/content/language1/html/3310.htm
Posted on Dec 18, 2016
  • 3 Answers
SOURCE: blade wont stay in Bosch 1882VS jig saw
From your description I cannot say for certain, but it sounds as though you are not locking the blade correctly, or the blade lock mechanism is broken. You can tell if the blade-lock is working by clicking it. It should make an audible "click" that you can feel. Also, you can pull on the blade ( with the saw UN-plugged of course!) and feel if it is properly seated. If you are operating the blade-lock according to the instructions and it still doesn't lock positively, see a service center before you use the tool again. A broken blade-lock could be dangerous.
Posted on Apr 10, 2009
SOURCE: Changing the blade in a bosch pst 65 pae corded jigsaw
Pull up the knob on the front at the top of the machine and push the yellow bit forward. Theoretically you should turn the knob anticlockwise three turns but it doesn't seem to make any difference on my one. Then take hold of the blade, ease it forward and turn through 90 degrees. You should then be able to pull it out. Replacement is, as they say in all the best manuals, a simple reversal of the procedure. When you are turning the knob clockwise this time it's supposed to click in place but my one doesn't do this and still seems to work.
Best of luck
Gavin
shameerariff
  • 89 Answers
SOURCE: Replace the blade on jigsaw Bosch # 1587 AVS item # 0 061 587 683
YOu can download the user manual in the following links
http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000000/r00061v-1.pdf
https://www.boschtoolsservice.com/Order/IPL/IPLDetails.aspx?tn=0601587651&mn=1587AVS&init=1
The blade can be replaced by unscrewing the screw found on the shaft.
Posted on Jul 28, 2009
  • 548 Answers
SOURCE: bought a jigsaw a bosch pst 54e how do i change
In the handle directly over the blade is a deep hole. You insert a long thin bladed screw driver into this hole all the way down. Twist slowly and it will locate with a screw. Undo the screw and then twist the remaining piece of blade 90 deg and pull. Replace new blade in the opposite way. Twist it so that the cut is to the front and then tighten up the screw. Do not tip up the unit while doing this as the screw might drop out and you might loose it
Posted on Sep 24, 2009
Testimonial: "thanks.did the trick.use you again thanks"
SOURCE: Changing the blade on my Bosch GST 2000
lift knob on top twist 3 times anti clockwise remove blade by twisting it 90 deg insert new blade turn 90 deg,turn knob on top clockwise until it clicks press down and you are ready to go
Posted on Jul 01, 2010
Does any one out there know how to put a blade in a Bosch 1581VS jig saw?
video here
How to Replace a Bosch Jigsaw Blade - YouTube
? 1:30
https://www.youtube.com/watch?v=YzpExustLD0
Sep 8, 2011 - Uploaded by toolsandmachinery
Mike will show you the simplicity of changing a blade with the Bosch twist-lock Jigsaw
here is the manual for the 1584
Bosch 1584VS Manuals
Apr 19, 2017 | Bosch Saws
Poulan riding mower grinding noise
Sounds like bad gears in transmission.
Sep 07, 2017 | Garden
Change blades bosch jigsaw
The one shown in the picture uses a very long and thin, flat blade screwdriver. There is a set screw that puts tension on the blade when the screw is tightened. Bosch sells the correct screwdriver or you can buy a long one and grind the sides down a bit. That's what I did.
May 17, 2012 | Bosch GST80PBE JIG SAW FOR 220 VOLTS
I need to use my late husband's jigsaw but can't get the old, bent blade out. How do I do it and which blade do I replace it with? I need to cut a few cms off the width of a kitchen worktop. I...
Hi Jen,
It depends on whether you have an older or newer model jigsaw. Bosch makes the newer ones with a button you push that will release the blade.
On an older jigsaw, look at the handle from above the jigsaw directly in line with the blade. You should see a screw in the top of the handle. Use a screwdriver and loosen this screw, don't remove it, and when the screw is loose enough, you'll be able to pull the blade out. When you put the new one in, slide it in the slot until it seats.
A rule of thumb is to use the blade with the wider gap and larger teeth on wood, the smaller teeth on metal. Most blades will say bimetal on the metal cutting blades.
Now, the courser the teeth the rougher cut you'll get. So, if you want a nice cut, don't use the blade with the largest teeth. Move down to the next largest.
I don't have a Bosch, so am not sure which codes are for which blades, but you can't go wrong if you go by the size of the teeth.
You didn't say what material the worktop is made of. If it's wood, the second largest toothed blade should be fine.
If you've never used a jigsaw before, I could suggest a couple tips that would help you get a nice job done.
First, put a piece of painters tape or masking tape over where you will cut, draw your line and go easy. The tape will keep the blade from giving you a roughed up top edge.
When you get near the end of the cut, hold a piece of scrap wood flat against the back edge to prevent tearout.
Also, let the saw do the work, don't push it.
Hope this helps, If it does, I'd appreciate a 4 thumbs up, Thanks,
Handie Andie, "woodworker by night"
May 24, 2011 | Bosch Garden
DROPPED MY BOSCH 1590EVSK JIGSAW, REPLACED BENT BASE, BUT BLADE IS STILL NOT PERPENDICULAR TO BASE. CAN'T SEE ANY ADJUSTMENT METHOD TO ALIGN BLADE PERPENDICULAR TO BASE PLATE. HELP
The socket-head screw that holds the sole plate on is also the alignment screw. Loosen it a little and the sole plate will swivel left and right. There are graduation marks on the base to help with alignment but I always use a square to verify the alignment. Tighten the screw and check again that it didn't move and you are ready to go.
Aug 20, 2010 | Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
My bosch jigsaw keeps saing sideways!!!
Most Bosch jigsaws have a handle on the top of the main handle that you need to pull up and rotate counterclockwise to allow the screw to accept the blade. Insert the blade and rotate 90 degrees into position then tighten the handle and press back down into place. In the beginning it may seem like you are going to break the handle pulling it up but rest assured it will get easier as it gets used.
May 10, 2010 | Bosch T-Shank High Speed Steel Jigsaw...
could be the yoke inside that is loose, unplug the tool and lock the blade in and see if you can turn the blade by hand. also make sure that you are using the right shank blades and lastly is the locking mechanism fully engaging the blade. Let me know the model number if none of these help and I will look at an explosion for you.
Mar 18, 2010 | Bosch T-Shank High Speed Steel Jigsaw...
Blade wander
a jigsaw is for cutting wavy lines if u want a straight cut use a rip saw with fine blade but you still can use a jigsaw must have sharp blade there is a blade u can get now from screwfix with a triangle spine on the back off the blade to prevent it twisting works fine (also do not push hard on the powertool let the blade do the cutting less likely to wander hope this is of help
May 30, 2009 | Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
Milwaukee jigsaw with blade change problem
a new tool will cost you about 170. You could look for a used on on craigslist.
Apr 21, 2009 | Milwaukee Tool Milwaukee Orbital Jig Saw...
Saws Logo
79 people viewed this question
Top Bosch Saws Experts
Tim Venetis
Craig Butler
Craig Butler
Are you a Bosch Saw Expert? Answer questions, earn points and help others
