Question about Polaroid Televison & Video
I got a used polaroid monitor for my computer. How do I set it up for use
  • yadayada
    yadayada Dec 18, 2016
    Just plug it in and turn it on
  • Polaroid Master
  • 20,460 Answers
Plug it in and switch it on. If drivers are needed, Windows will find them.
It has to be a monitor as a television (the category you posted to) is a different technology and won't work.
Posted on Dec 18, 2016
When I play videos the sound from the monitor is fine. However, the auxillary jack in the back of the monitor makes static when I pulg in the outside speakers, but their is no sound from the video. I...
The auxiliary connector could be an input as your Polaroid monitor instructions would indicate. There may be no provision for external speaker connection.
Nov 26, 2013 | Polaroid 15'' HDTV Monitor FLM-1511
I want to use the 23" Polaroid LCD as a monitor.
use your VGA or a DVI input and set your tv to pc mode thru the tvs menu. you should not have to instal any drivers at all. your tv as a monitor will display all text and images as a monitor the same as it does as a tv
Jan 04, 2011 | Polaroid TLX-02311B 23 in. LCD TV
Polaroid FLM-1511 Monitor
right click on your desktop / display properties (mine is nvidia display properties)
There should be settings there to set up multiple displays.
You may need to find display properties from control panel
Jul 18, 2010 | Polaroid 15'' HDTV Monitor FLM-1511
Use as a computer monitor?
The Polaroid TLX01511C 16" Class (15.4" Diagonal) is capable of receiving audio and video signal in ATSC and NTSC systems. With the host computer, use as the display terminal and connect the 3.5mm (diameter) audio cord to your computer’s audio main board so you can listen to music from your host computer through the Polaroid TLX01511C.
Mar 02, 2010 | Polaroid TLX-01511C LCD TV
Polaroid monitor picture is shifted to left about an inch
Hi you may try
1)to key the auto(adjust) button at TV monitor keyboard if not ok,
2)to change display pixels density from PC display setting because TV monitor could not support the display pixels you using and sync.the picture on well.
3)also you may adjust monitor screen H position(it maybe not convenience for back TV).
Dec 21, 2008 | Polaroid Computers & Internet
Having problems getting signal when hooking up our Polaroid 32in HDTV to computer to use as monitor
Are you using a video cable or the s series. Can you use the Polaroid as a monitor? Remember you do have to tell the monitor to be a TV.
Aug 01, 2008 | Computers & Internet
I am trying to connect my laptop to the Polaroid LCD TV, as i would like to use the TV monitor as a computer monitor (my laptop monitor is broken). So I connect the correct wire to correct places, however...
The simple patch that I found (same problem) was to start by using any old monitor that I could borrow to set up my Dell Laptop.
After getting the Laptop booted on a regular monitor I right clicked on the desktop and went to properties then to the settings tab.
Here I found the dual monitor settings (#2 will usually be dis-abled by default.)
Click on #2 monitor and set the resolution to the lowest number (800 x 600 works well)
Then I clicked on "make this monitor my primary monitor"
As soon as I clicked apply the PC Windows screen appeared on the Polaroid TV screen
Earlier I had set the secondary monitor as "extend this screen to this monitor"
This also worked but I had to "drag the current screen to the right all the way off the
"borrowed monitor" until it appeared on the TV screen. The mouse pointer will be there also.
At first it took a little getting used to but in a few minutes I was up and running.
Hope this helps your situation
David Flournoy
Waxahachie Texas
Mar 10, 2008 | Televison & Video
Televison & Video Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
