Question about Uniden Lands Phones
Uniden G37xx system paired to Samsung Note 3 which has a very annoying buzzing after recording phase. how can I disable this?
Existing Uniden cameras won't pair - nothing has been moved, but we lost surveillance and cameras wont pair
Check the camera power supply. If this is an IP camera, you may want to make sure that the camera didn't change the IP address.
Sep 07, 2015 | Uniden Video Surveillance System Uds655
Pairing at&t to uniden
Please note we do not test our products with third party accessories/products.
Jun 22, 2015 | Uniden Radio Communications
How do you set up voicemail; on a uniden dect 6.0?
Which exact model Uniden DECT phone do you have? There are a number of models. Some require you to set up the answering machine from a handset. Other models have a Menu button on the base station, as well. The entire list of DECT phone manuals are here: http://www.uniden.com/scat/dectphones_mnl . They are listed in alphabetical and numerical order. Ignore any digits after the dash in the model number, that indicates the number of handsets in the original package. My experience with Uniden DECT phones includes systems where the menu is accessed from the base like the D3588, http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D3588om.pdf .
The following directions work for the Uniden systems that I have used to set up the . First make sure that the answering system is on at the base station and the phone is in standby. Next press the Menu/Select button and use the Up/Down arrows to navigate to Answering Setup. Press Menu/Select to enter the submenu. Then navigate to the different options in this menu and press Menu/Select to enter them.
To record a greeting message, navigate to Record Greeting. Press Select and wait for the "Record Greeting" response. Speak your greeting clearly (between 2 and 30 seconds) and press Select to Stop the recording. You'll hear the greeting repeated. Press End (on the handset) or Stop/Cancel on the base to interrupt the playback.
Next press the Phone Book button to go back up to the Answer Setup menu. Select Greeting Options to switch greetings (if your model has a default greeting). Use Select to switch between greetings. (Arrow keys to swap; Select to confirm.) Use the Ring Time option to select how many rings before the unit picks up. If you wish to use the answering system when you are away, make sure to set up a Security code and press Select to confirm the code. Make a note of the code. Press End to exit the menu system.
Note: if you have Voicemail from your telephone provider, you will need to ensure that your Uniden phone picks up before the Voicemail service.
I hope this helps.
Aug 11, 2014 | Uniden DECT 6.0 Cordless Phone
Uniden survaillence system will not pair with this camera but says it will pair with any wireless camera. How do I pair the GE with Uniden
I am not aware that Uniden survellience systems pair with cameras other than a Uniden camera. Please provide model number of your Uniden system to help with a solution to your problem.
I understand that GE Add-On Wireless Digital Color Camera 45256 will work only with a GE security system like Ge 45255
Apr 27, 2014 | GE Add-On Wireless Digital Color Camera...
The red light flashes that I have a message but I can't remember my password and I can't get the messages on the handset can you help with password?
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Jan 03, 2013 | Uniden Cordless Phone
Where can i find ac motor connection diagrams, specifically, single phase forward and reverse, and 415v motor to 240v power diagrams? thanks andy
there is no motor that is single phase with 415 volts only 240 volt or 120volt and you cannot use a 3 phase motor on single phase it will just fail to start buzz and burn it up .single phase motors have capacitors 3 phase motors do not
Jun 15, 2011 | Air Tools & Compressors
I have lost my manual and i dont know how to record a personal message on my answering machine and how to enter the code to retrieve my messages from another phone.
From your handset, you just have to press the mute button, your phone should start telling you the time, date, ect. press the #5 key and then the #8 key and start recording your message. When finished press the # 8 key again. Hope this helps
Mar 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
Lands Phones Logo
42 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
