Question about Refrigerators
My indicator on the pur faucet mount is blinking red and I just changed the filter
2 Suggested Answers
  • 937 Answers
SOURCE: Get light on pur water filter to resume blinking
Is this what you are talking about or a filter inside the water dispenser for a refrigerator? If fridge, make & model
Posted on Jan 06, 2015
How do you fix the light in a Pur faucet filter
It could be mineralized, try soaking it in vinegar or scale remover.
Mar 03, 2017 | Refrigerators
Low Water pressure from the unfiltered spout on the Pur wat?r filter rf-9999. Plenty of pressure in the line.
Check out the nozzle screen for clogging. And if that does not do it then the cartridge inside your faucet is not operating properly. And those cartridges can usually be replaced. If faucet is a Moen it has a lifetime warranty and all you do is call them and they send to your home a brand new replacement cartridge. Do U have a Moen?
Mar 04, 2016 | Plumbing
Why is my Pur faucet filter so slow? It was not before
You either need to clean the the screen filters prior to as they may be blocked. The filter cartridge itself my need to be changed as you don't say how old it is.
Aug 29, 2013 | PUR 3-Stage Vertical Faucet Mount Gray...
Touch sinking fix
It sounds like you may have a built in filter in the faucet. The red may indicate that it is time to change the filter, but more than likely it is an indicator for low batteries which are located in the cabinet below the sink. Either change the filter, or change the batteries.
Jul 27, 2013 | Plumbing
PUR Faucet Mount Water Filter indicator light does not work
Take it loose from the faucet and flip the lever down on the filter in the on position. Take the cap off and remove the filter. Blow hard through it. You should hear a whirling noise of a gear, like a windmill. If not, I use a water dental pic to pulsate into it and clean it out. This is what makes the light work and when flow goes down, the light changes color. It's all mechanical. No battery. Just free up the gear so it turns freely to work the light. If standing in front of a mirror, you can actually see the light come on. PUR doesn't tell you this because they want you to purchase another one.
Dec 17, 2011 | Buck Plumbing
Two led water purity monitor problem
The LED monitor should light up as Green when the membrane is producing the proper water quality (80%+ TDS rejection). If the LED light stays Red this indicates the RO membrane is bad, all the filters (including membrane) should be changed and system sanitized. The batteries in the TDS monitor should be changed yearly also. Don't have a lot of faith in that indicator light. The best way to test for TDS rejection is with a digital TDS meter which indicates the amount of rejection. Compare the incoming water to the product water of the RO.
Jul 17, 2009 | Culligan Under Sink Water Filter
Which glue to reattach chromed plastic to plastic?
Use old fashioned model cement. Not the child safe type. The old type will melt the styrene to the styrene. The new stuff only fills the gap but never really makes a good bond.
Mar 10, 2009 | PUR (FM-9500) Air Purifier
Red led light on constantly
electronic circuit needs replacement
Feb 01, 2009 | PUR (FM-9500) Air Purifier
Can't remove the filter from my Pur Flavor Options faucet mount water filter
When mine gets stuck I stick the handle of a fork or spoon into the hole where the water comes out and use that to unscrew it. Works like a charm every time.
Aug 04, 2008 | PUR (FM-9500) Air Purifier
Red Light on front of Filter Queen Defender
When the red light is blinking, press and hold both up and down arrows until the red light blinks RAPIDLY, release both for a second or two, and press and hold both again until it stops blinking. It cured my problem.
Mar 06, 2007 | Filter Queen Defender Air Purifier
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
