How to connect to xfinity wifi emachine et1331g-03w
  • 366 Answers
SOURCE: front bay door wont stay closed
If you mean your cdrom drive wotn stay close, what can happen some times is the actually cdrom unit it self has shifted back inside its rack. try opening case and loosing a few screws here and there and shift it forward. make sure nothing has got stuck inside of door tiny bit of paper or anythign can cause it. hope this helps
Posted on Nov 28, 2009
BearWeb
  • 357 Answers
SOURCE: Emachine ET1331G-03w Documentation
To install an IDE CD rom, you will need to open your computer and you will see an IDE Slot, your computer usually has two of them either directly next to each other or under each other, there is usually one white one and one blue one. IDE Slots look like this:
The white IDE Slot is usually for the Hard Disks and the blue IDE Slot id usually for the CD Roms.
The white IDE Slot is the Primary Slot and the blue is the secondary.
You will need an IDE cable to plug in to your blue IDE Slot then you will need to plug the cable in to your CD Rom and make sure that your CD Rom is set to run/work as the master. If your computer only has one IDE Slot or you do not have an extra IDE Cable you can plug the CD Rom in to the Primary IDE Slot with the Hard Disk assuming you are only using one Hard Disk.
If you are going to use the Primary IDE Slot you will need to make sure that your CD Rom is set to run/work as a slave and it must not be set as the master. The way to change it is by moving the pins at the back of the CD Rom, they are found at the back next to the place where you plug the IDE Cable in to or next to the power input. You will be able to tell if your CD Rom is set as a slave or as a master by checking the image on the top part of the CD Rom, this image will tell you how to set your CD Rom as a master or as a slave.
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Posted on Jan 09, 2010
  • 44 Answers
SOURCE: What are the detailed power supply specs for the
It comes equipped with a 250w power supply. It is a short coming of the computer and must be replaced for any significant upgrades to be preformed. The method of doing which is found here:
As always I recommend that you leave these things to a certified professional. All attempts are done at your own risk.
Posted on Jan 22, 2010
SOURCE: Emachines - ET1331G-03w... amd athlon II x2 core
NO.
Posted on Jan 29, 2010
  • 102 Answers
SOURCE: how do i install an additional sata hard drive on
1.open up the PC, insert the HDD into a free HDD slot, clip/screw it in.
2. plug in data and power cables for new HDD
3. set main HDD jumper to master
4. set new HDD jumper to slave (middle pins)
NOTE: make sure you wear a grounded wrist strap
Posted on Feb 08, 2010
I need the pinout for a 24 pin emachine et1331g-03w
I assume you mean the power supply connector. This is standard ATX.
Mar 17, 2016 | Computers & Internet
IT SHUTS OFF AT BOOT UP
Hi
It seems like Operating System failure. Most probably corrupt system files.
  • Try removing the hard drive and re-connecting it.
  • You can also connect the hard drive to another machine (as a slave) for automatic repair.
  • Or run an Original Windows disk and select 'repair' (R) on first page.
Hope it helps.
Thanks
Feb 08, 2013 | eMachines ET1331G-03w
HDD led flashes non-stop after case swap (emachine et1331g-03w)
it will be next to ur power led or u will find hdd led wrritten on the motherboard
Jun 04, 2010 | E-Machines eMachines Desktop PC
How do i install an additional sata hard drive on my emachines ET1331G-03W computer?
Feb 08, 2010 | E-Machines eMachines Desktop PC
Where do I find instructions to properly burn
Hi there !!!!!
Please check this link and i hope this should help you.
http://www.emachines.com/faq/vista/7515418su128.html
Jan 22, 2010 | Computers & Internet
I just got an emachine Et1331G-03w machine. I
do you have the install disc for te netgear router ?
you have to have one
Jan 17, 2010 | NetGear WPN111 RangeMax Wireless USB 2.0...
ET1331G-03w Multicard reader problem...
I would check all the slots if that is the only slot giving you problems then that slot may be bad.
Jan 04, 2010 | E-Machines eMachines Desktop PC
Computers & Internet Logo
David Payne
David Payne
