Question about Dishwashers
Calcium defiency what the signs of calcium defiency
    Top Expert:
  • Dishwashers Master
  • 47,827 Answers
Talk with a doctor about the problem
one indication is bones that break easily and that is only evident on breaking a bone from a minor incident
doctors can do a bone density test and that will indicate a problem
remedy is simple but talk with your doctor
Posted on Dec 18, 2016
)would like a safe alternative to alendironic acid ( to maximise absorption of calcium) Thank you
I have studied about nutritional supplements ... a lot. What kind of calcium are you talking about? Is it calcium CITRATE, which is one of a VERY FEW TYPES that the human body can actually absorb? Are you battling osteoarthritis?
https://www.google.com/search?newwindow=1&safe=active&site=&source=hp&q=White+Rotary+sewing+machine+1913+Serial+number+FR2629029&oq=White+Rotary+sewing+machine+1913+Serial+number+FR2629029#newwindow=1&safe=active&q=calcium+citrate+absorption
May 16, 2017 | Pool & Spa
Is milk bad for you by causing osteoperousis
Osteoporosis is a weakening of the bones as they lose calcium and other minerals with age or affliciton. Milk, which is high in calcium, will not strip the minerals from your bones and, therefore if consumed in moderation throughout your life milk is not bad for you in that regard. However, calcium is an essential nutrient for body / muscle function and regular intake of foods or supplements providing calcium so that the body does not need to strip that calcium from the bones appears more important.
From hsp.Harvard.edu
"Adequate, lifelong dietary calcium intake is necessary to reduce the risk of osteoporosis. Consuming adequate calcium and vitamin D and performing regular, weight-bearing exercise are also important to build maximum bone density and strength. After age 30, these factors help slow bone loss, although they cannot completely prevent bone loss due to aging.
Milk and dairy products are a convenient source of calcium for many people. They are also a good source of protein and are fortified with vitamins D and A. At this time, however, the optimal intake of calcium is not clear, nor is the optimal source or sources of calcium."
Calcium and Milk Whats Best for Your Bones and Health
Oct 30, 2014 | Home
I pushed the button down to start the jets and it got stuck all the way down and won't come up
When an air button does not come up after being pressed down it is a classic sign that the button needs to be changed.This happens when one of a couple things happen:
  1. The bellows in the air button have broken and therefor cannot push the button back up.
  2. There is calcium built up on the inside of the button
  3. You can clean up the calcium deposits with emery cloth
Rod
US Parts Center
Apr 03, 2013 | American Standard 1748.102 Colony 5.5' x...
Are there different types of calcium supplements?
Yes. There are actually two different forms of calcium supplement: calcium carbonate and calcium citrate. Calcium carbonate is the cheaper one of the two and should be taken with food. Calcium citrate can be taken on an empty stomach and is absorbed well for people who have low levels of stomach acid.
Feb 04, 2013 | Health & Beauty
Do I need a calcium reactor in order to keep hard corals?
Actually you don't have to own a calcium reactor for keeping hard corals. However, it is very helpful. If you do not have a calcium reactor, check your calcium level and carbonate hardness on a very regular basis. You will have to add calcium and carbonates often.
Aug 02, 2012 | Fish
Ice cubes come out with particals in them. What can I do?
It’s calcium deposits from the water. It’s a sign of hard water, and it can clog up your appliances & small water pipes. To stop this from happening you will need to hook up a soft water system avalible at most home repair stores
Aug 14, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Calcium build up removal????? Our water has a lot of calcium. Lately, my dishes are not getting cleaned and it appears there is a lot of calcium built up. What is the best way to remove it?
add dishwasher salt if you live in a hard-water area to prevent calcium build up, and try adding a litre of pure lemon juice to remove the initial crusting, as the calcium is highly alkaline, and the lemon juice, being acidic, neutralises it.
Nov 06, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
How do I clean the calc from my tefal express generator iron. I have the equipment but not instructions. liz
You can use a product such as CLR (stands for Calcium, Lime & Rust) (can be found at Target, Walgreens, CVS, Walmart, etc.) in order to remove calcium from your iron. To prevent calcium from appearing on/in your iron in the first place, use distilled water in your iron instead of tap water. I buy bottles of distilled water for ironing only and calcium never appears on my irons.
May 15, 2009 | Irons
Dishwashers Logo
Top Dishwashers Experts
