Question about Samsung BlackJack Smartphone
There is no display. Phone works, but can not see who is calling, can't view contacts, or any other views.
  • flhoss2000 Jul 21, 2009
    No display at all on Samsung BlackJack. Still can call out and receive calls, but can not view anything on display. I have removed the battery several times, left it out over nite and nothing changed.
  • 6,784 Answers
HI, this is a possible severed LCD screen ribbon connector. the soldered contacts inside the mini connector tip may be defective. this will cause the screen to go blank. This can also be caused by a corrupted program in the main board core script as well.
Here's is a fail safe procedure that will expose the actual issue you are having.
Step one.
Carefully power off the unit and remove the battery and Sim card. Once you have removed these two devices, let the phone sit for approximately 3 minutes without the sim card and battery. this will drain all power and, reset the core program, allowing it to re-initialize itself.
Step Two.
After the 3 minutes are up, re-install the Sim and battery carefully back into the unit and power up the phone. It should take a few secs to initialize the core program and, start up.
Step Three.
Once the phone is powered up again, monitor the progress. pay close attention to how long the load time is for the screen to show graphics. there should be normal latency in this case.
Ok, if the unit shows the blank screen once more after the core reset and, it is not operational, this will confirm a serious issue that concern the main core script or, program that is installed at the factory on the main board. in this case, this unit will need ot be serviced at your local Samsung cell provider service station or, you can send it in to Samsung for the reprogramming of the main board.
NOw, if the phone is operational and able to make calls after the resets and, the only abnormality is that the screen is blank, this will confirm a LCD contact ribbon failure. you will need to replace the LCD screen in this cass.
Contact you local provider or, Samsung for these repairs.
Posted on Jul 21, 2009
  • Samsung Master
  • 1,606 Answers
Unfortunately it is most likely the display needs to be replaced.
If you take the phone and look at the display from the side you may see a slight ghost image of what should be there. That will mean the back light has gone out. If you do not see anything then the problem is either the display or the hardware to generate the images.
If the phone is new perhaps you can get warranty. If not you can try and find replacement parts and try to fix it. Phones are not fun to fix mainly as they are such a pain to get apart in a nice way. I've not fixed this model for this problem before but the symptoms are typical of display failure of some sort. Wish I had a better quick fix for you.
    President:
  • 2,777 Answers
Absolutely no display on the phone whatsoever? The first thing to try would be to take out the battery from the phone completely, leave it out for a good two minutes and put it back in. If this does not reset the display then it has failed. You will need to contact the service provider (probably AT&T?) and have them replace the phone. It's probably still under warranty so this will be free for you to do.
Thanks
Tim
How to view blocked numbers on iphone
In general, goto phone, then almost on the bottom you find blocked.
There you can add, delete or view the numbers.
Jul 05, 2014 | Lands Phones
I want to copy contacts from sim mto phone memmory
go to menu and click on contacts then on that press options then click on settings. now on that see there is a option like view contacts on . now select it as sim. then press ok . now exit and again go to contacts.Now the contacts on your sim card will be displayed now go to options on the contacs and click on the option " Copy to phone" On that option click multiple then when it ask to select the contacs click on the first option which is select all then now press ok .Now your contacts will be copied to your phone. now change the contacts view in to phone.
simple guide:
1)Menu->contacts-> contact settings-> view contacts on-> Sim card-> ok->exit
2)menu->contacs-> Copy to phone->multiple->select All-> ok.
3)Menu->contacts-> contact settings-> view contacts on-> Phone-> ok->exit
Jun 20, 2011 | Samsung Galaxy S GTI9000 Smartphone
My contacts wont show up until i search for them what can i do to be able to view them it just keeps saying no contacts to view
It sounds like you have some sort of incorrect setting for displaying your contacts. Try this to change it:
- Go to your App Drawer and tap the "Contacts App"
- Press the menu key (with four lines)
- Tap Display Options
Try unchecking "Only contacts with phones" if you want to be able to see a contact even if they don't have a phone number.
Then you can click on each account you have sync'd to the phone, and choose which contacts from that account you want to display in the app. Checked items will display.
Hope that helps!
Mar 07, 2011 | LG Ally Cell Phone
Hoe to get lost contacts from mobile
If you didn't save your contacts to the sim card or to software, then there is no way to get the contacts back. You may want to look on your online account and view phone numbers that you text and called or view phone numbers that sent you a text or called you. Then write down those phone numbers. You'll have some of your contacts.
Feb 03, 2011 | Cell Phones
Contact names not displaying whilie making outgoing or receive incoming
From the menu of your phone, go to your contact and press, scroll down to settings in the contact and press, scroll down to contact view and press, you will see varieties of option there, select the one you want, maybe it should display name and number while calling or just name alone.
Any option you select, press it and it will b save. you can now call, the option you select is what it display while calling or receiving call.
Take care.
Apr 20, 2010 | Nokia 3100
Can not view caller ID with call waiting service
The Meridian 9516 is not a visual call waiting (VCW) phone...meaning that you will not see the caller name and number of the second caller when you are on the line..you must purchase a separate call display box (around $10) if you can still find them., but make sure that box is visual call display capable.
Sep 24, 2008 | NorStar Meridian 9516 Corded Phone
My phone contacts are not displaying
just format using code *#7370# and if it doesnt works u hav to reinstall software... or u have to flash it
Aug 31, 2008 | Nokia 7610
Nokia N95 8gb ~ no names appear when someone calls
Try copying the sim contacts to the phone memory contact.
Jun 26, 2008 | Nokia N95 Cellular Phone
Display names
Select Menu > Contacts > Settings and from the available
options:
Contacts view
—To select how the names and phone numbers
are shown.
When you view the Details of a contact with
Contacts view set to Name list or Name only.
Jan 21, 2008 | Nokia 1600 Cellular Phone
Displaying contacts
There are two views in the Treo 650's Contacts application. The first view is by a 'Last Name, First Name' view, while the second is by a 'Company, Last Name' view. Just press on the menu button on your Treo 650 smartphone, go under 'Options' and look for 'Preferences'. Under the 'List By' section, just select 'Company, Last Name' and the contacts will be arranged accoring to that scheme.
Sep 12, 2005 | Palm Treo 650 Handheld
Samsung BlackJack Smartphone Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
