Question about Tablets & eReaders
Does marqis tablet use sim? - Tablets & eReaders
How do I insert a sim card into a MID 7 Tablet No Sim slot !!
If the tablet does not have a SIM slot, then the tablet does not support Mobile connectivity through a SIM card. This will mean that you need to use WIFI to connect to the internet.
Feb 20, 2017 | Tablets & eReaders
Sim card for Samsung Galaxy tablet 4?
A SIM card is for 4G LTE internet service, so if you have a Samsung Tab 4 ensure it is 4G capable before trying to insert a SIM card. If you try to insert a SIM card into a SD Card slot you may damage the card reader.
That being said, I believe it is located on the right side of the tablet. Sometimes the SD Card slot and the Sim card slot are right next to each other. Once you open the cover that reveals the slots there should be small icons for the SD Card and the Sim card. Normally, the SIM card slot will have a little notch on the icon. Attached are guides with pictures.
http://www.samsung.com/us/support/answer/ANS00030415
SIM card Samsung Galaxy Tab 4
Oct 22, 2016 | Samsung Tablets & eReaders
How do i put sim card in sprint tablet powered by android
Depends on the model of tablet. Some require you use a paper clip to release the Sim card door. Check the owners manual or sprints website for model specific info
Oct 13, 2016 | Tablets & eReaders
My SAMSUNG tablet SIM Base is faulty, hence I am not having any internet connectivity via my SIM service provider which is Airtel. What can I do?
Had a problem very similar to this. I took it to my local servicing agent and they found the SIM Base to be defective. They replaced the section but charged 75 USD (it was out of warranty) then they reinitialized the SIM and all was well.
Best wishes,
Joe
Aug 25, 2016 | Samsung Galaxy Tab 101 Tablet...
Does insignia 10 inch tablet use sim card
Of all the Insignia tablets, there is only one that will use a SIM card. It is specifically called out in the model number as an LTE capable unit.
The model numbers are the NS-15T7LTE and the NS-15T8LTE.
No other INSIGNIA tablet will have a SIM card slot available.
Mar 06, 2015 | Insignia - Flex 8 inch Tablet with 8GB...
Removing cover to access sim
If you really don't have the skills to repair modern electronics, please don't try to open the tablet. You won't be able to open it in the first plase, without damaging the tablet. I think a technician, should be able to remove the sim, if it can be opened, with a pair of fine tweezers. But again, please don't try this yourself.
Jul 28, 2014 | Huawei mediapad 7 s7 931u tablet
Pin no. set in error on this tablet now we can't access the tablet at all because we ca't get past the pin no. Please help or advise how to restore to factor settings.
Do you mean that the PIN of the SIM card is locked?
The PIN is needed to access the SIM card.
If you remove the SIM card the tablet will not ask for a PIN.
You do not need to change anything in the tablet.
(If you would insert your SIM card in a phone, the same would happen when you launch the phone.)
I hope this helps.
May 11, 2014 | Tablets & eReaders
My tablet sim function is not working
Remove sim card and reinsert ,make sure it's all the way in.
Oct 03, 2017 | Tablets & eReaders
Tablets & eReaders Logo
29 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
