My k100 sounds all garbled, what causes this?
Toshiba tv, model cf32c50 has a garbled sound issue.
distorted sound sometimes accompanied by buzzing is caused by detuned circuit in the SIF amplifier and sound detector circuit. a distorted sound alone is caused by a breakdown in AF amplifier circuit so try to change the sound ic since its the only options left. good luck!
Jul 27, 2010 | Toshiba Televison & Video
How to troubleshoot speaker
Hello sir, Hi!, the garble is caused by two things, 1. a bad speaker, 2. a bad power amplifier IC.
To test the Speaker,
Remove the speaker out from the TV, (this needs disassembly stuff) test it using any available portable amplifier. or radio, OR replace the speaker with the same size.
If this does not solve the garble sound, replace the power amp IC. (this really needs skills in electronics.) thats it.
Apr 27, 2010 | Televison & Video
Our 37" series 4 (450) LCD TV sound "garbles"
Hi my name is Roety,
I can help you with your issue ,
Make sure you have the latest firmware upgrade from Samsungs website!
Also weak signal can cause this if using air signal raise or connect a better antenna
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Nov 29, 2009 | Samsung LA37A450 37 in. HD-Ready LCD TV
Garbled sound as the system accesses something. Disk light pops up at same frequency as garbled sound appears. The Windows startup and shut down sound also is garbled. Using Windows XP on an ASUS K8V...
1. check the cable to the DVD or CD to the sound card it may not be connected properly.
2. remove the sound card from the motherboard and do "shutdown" then restart without the sound card.
3. Shutdown again reinstall the sound card and reinstall the drivers for the sound card.
4. check the the manufacturer website for any firmware upgrade drivers
Sep 21, 2009 | ASUS Computers & Internet
Magellan Maestro 4210 no audio or garbled sound
I suggest you take it back to the seloloer before the warranty expires
Jul 20, 2009 | Magellan Maestro 4210 Car GPS Receiver
Nuvi 350 Garbled voice
How is the other sound? Like MP3 sound? Is it garbled there? Try using headphones. If the sound is good there, then your internal speaker is bad.
Email me at ks3r at sharc dot net if you are interested in me fixing this for you.
- Jim
Sep 10, 2008 | Garmin Touch Screen GPS Receiver
Garbled text
Did you just install it ? Sounds like a driver issue.
The only other thing I have seen cause that is software corruption.You can do a NVRAM reset from the screen.
But I would try restarting the machine first. Then go to the Xerox.com site and download a new driver before resetting the NVRAM memory.
It sounds like either the program you are trying to print from of the driver is the issue.
I bet you are printing out code.
Jan 29, 2008 | Xerox Phaser 8550DP Printer
Countinous Garbled Sound
Probably a DIGITAL/ENCRYPTED talkgroup that you cant get on the 246T
Nov 26, 2007 | Uniden BC246T Handheld Scanner
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
