Question about Refrigerators
Doors lights flashing and ice dispenser keeps flapping. I ordered a new control board. But how do I keep the compressor running until the new control board comes? Don't want all the food to spoil!!
PABLOCSA
  • 1124 Answers
SOURCE: Ice and water dispensing problem; compressor shuts off when paddle pressed but dispensing is sporadic
The ice remains stuck between the dispenser and the top of feeding ice. This respond to a broke rubber on the last section where the ice must be delivered. Replace the rubber will fixed the problem. It is a common problem on this kind of devices. To remove the ice simply move the stuck ice from the bottom oro yu can try putting some warm water from the top. Before to do nothing, unplugg your refrigerator first.
Posted on Oct 11, 2008
SOURCE: blinking board and flapping ice dispenser.
We called Maytag customer service and they resolved our problem and is sending us a new control board and sending out a technican to our home to install at no charge! What great service! Thank you Maytag!
Posted on Jun 12, 2009
SOURCE: The lights on the Ice and Water Dispenser flash
On left top side of door, remove cap and disconnect wire. This will turn off the control board on front of fridge and fridge will still run. Then follow this link - http://www.liny.net/MaytagIce2O.htm - click on frig picture at right and you will get step by step instructions with parts and tools you may need costing around $20.00 for a do it yourself fix.
Posted on Aug 19, 2009
Sea Breeze
  • 4654 Answers
SOURCE: My control panel lights are flashing on and off
Terri You have a control board or the keyboard going out and I will need the model number to be able to get the service manual to you ant we can solve this without having to Call the Maytag man in. If that is what you want. If the door is flapping I believe it is there at the dispenser. Contact me if you can find the model numberso I can send you a copy of the manual and We will discuss this then, Sea Breeze
Amana numbers look like this Amana ABB1927DE
Posted on Dec 31, 2009
What does it mean when lights on control panel keep flashing and ice dispenser flap keeps opening and closing?
Ours started the same thing today. Called the 800- Maytag service number. They said it is a "known quality issue" with the controller and scheduled maintenace call. If gone unfixed, the controller will probably eventually fail and the frig will quit working all together. From what the lady said, this will be a free fix even though it's passed the warranty period.<!-- from fixya rte -->
Aug 11, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
My control panel lights are flashing on and off and the ice maker dispenser flat keeps flapping and we have tried unplugging and replugging and it quits but starts again.
Dec 31, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Aug 19, 2009 | Maytag MFI2568AE Side by Side French Door...
Refrig Ice is freezing up on the door dispenser
Most likely the defrost timer or Adaptive defrost. Yours has the defrost timer. I want you to open the fresh food compartment and find a small opening through the control panel. The opening may have a plastic plug covering the hole to hid it. Remove plug and turn timer clockwise slowly until the compressor stops running. The compressor should remain off for about 25 minutes. If it does not turn itself back on then turn the timer slowly again to the right/clockwise until it does. If you need to restart the compressor. this way the timer will need replaced.Defrost timer is part number 482493 Keep me informed on your progress, Sea Breeze
SITE=> http://servicepartstec.blogspot.com/
SITE2=> http://appliancepartseast.blogspot.com/
Jul 11, 2009 | Kenmore Refrigerators
Blinking board and flapping ice dispenser.
Jun 11, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag mfd2561 water dispencer and ice maker issues
ther first refrig id have to see for better idea of problem but hte second with the flaps open and closing is going to need a high voltage board part num(12920710)---thats the part number i get wehn i look it up with the model MFI2568AEW. dont know where you got 12002608(that to is a h.v. board. which ever itssan easy enough repair to do yourself, its mounted on the rear of refrig and comes with programming instructions in the box
Mar 12, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
THE ICE DOOR PROBLEM
Budd, if you want to stop the flapping until service shows up to replace the high voltage board do the following: remove the drip tray, remove the 2 screws under the drip tray. From the bottom, where you removed the screws, pull out and up. The whole disp cover lifts off. Unplug the 2 harness going to the board on the dispenser. The refrigerator will still operate normally minus the dispenser. Catriver.
Dec 25, 2007 | Maytag MFI2568AES Stainless Steel Bottom...
Ice and water dispenser for Maytag H20 not working
You need a new high voltage control board. Ive had at least 10 do this.
Oct 05, 2007 | Maytag MFI2568AE Side by Side French Door...
GE GSH25JSRFSS REfrigerator not working
I had the same problem as do thousands of people with this same fridge. The mother board is bad and needs to be replaced. It is easy to do yourself and the part costs less than a service call.: Unplug the cord from the wall, remove the panel from the back of the fridge (it is about the size of a small shoe box lid) You will see the mother board (ice, water, light, and compressor control unit). It is an electronic circuit board. There are about 5 or so plugs going into the board. Remove the plugs and the retaining screws and search Ebay for the part#WR55x10552 GE Power Control Board. I found one for $74, popped it in, and everything works better than new!
Sep 03, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
