Machine agitates & cycles fine. When it reaches spin cycle it just growls & does not spin.
  • 417 Answers
depending on the model, your plastic ujoint union in between the motor and transmission may have cracked and broke, they are replaceable. put the machine on its side and look in between the motor and the transmission for the union, the motor has to come off. also might want to check the drain pump for an obstruction. sometimes baby socks will get sucked into them and will cause that. most drain pump housings are translucent , so you can see the inside. try turning the pump by hand, you should be able to turn it. hopefully one of those ideas will get you going.
J
Posted on Jul 21, 2009
My washing machine won't spin when in a wash cycle but will spin on a spin cycle
???? ITS NOT SUPPOSE TO SPIN WHILE WASHING ? DO U MEAN ITS NOT AGITATING? THEN LOOK AT UR PRESSURE SWITCH AND UR CAM DOGS. MOTOR COUPLER OR BELT. NEXT UR CLUTCH BRAKE ASSEMBLY MAY BE BAD
Jun 09, 2015 | Hotpoint WF430 Front Load Washer
Machine worked fine to start with . Then stopped. Will fill water but drum wont turn on a wash cycle. And wont spin on spin cycle.But Belt seems fine. Can you help.
The pump needs to be replaced. The pump controls the agitation for the wash cycle, also controls the tub for draining & spinning after the wash & rinse cycle. The belt has nothing to do with it. Pump is very simple to remove & replace, and not too expensive, it's plastic.
Jun 03, 2015 | Washing Machines
Maytag Model LA610 - Newton - old style counterweight transmission (mfgd.1981)
check motor coupler, agitator spindle, drive block and shaft, cam dogs and motor windings
Mar 23, 2017 | Washing Machines
Maytage la610 - Newton - old style counterweight transmission (mfgd.1981)
It is possible that the motor may be on it's way out. You might check to see if it has a start capacitor on it that may be getting weak and possibly by pushing the agitator takes the initial load off of the motor. Just a thought.
May 14, 2014 | Washing Machines
I have a Maytag Model A412, series 11 washing machine. After the machine fills with water the machine appears to start its cleaning cycle but the agitator doesn't work. The water starts & the...
if this is a two piece agitator,it should behave like a ratchet turn freely clockwise and catch counter clockwise if it doesn't catch the agitator "dogs " are shot this is a verry inexpencive repair
Jun 08, 2011 | Washing Machines
Agitator wil not move makes a growling sound but all spin cycles still work
Either the transmission is bad, or more likely the agitator dogs are broken. If you pull the top pieces from the agitator you can see the agitator dogs and tell if they are intact or broken. If they are good, the transmission might be bad. The only other thing will depend on if the machine goes through the wash cycle to the rinse and spin without ever agitating, or if you have to manually move it. If you have to manually move it, your timer is probably bad.
Sep 06, 2009 | Washing Machines
Kenmore 80 topload washer agitation cycle noisy and high current
Sounds like a motor problem drawing to many amps dimming lights. Check drain pump to see if pump has obstruction in it causing resistance. Run machine while pump is off to see if light dim.
May 29, 2009 | Kenmore 24032\24036 Top Load Washer
The machine works fine until it reaches the rinse cycle.
The buzzing sound is the cold water inlet valve is getting power but water is not able to enter. You need to have the valve replaced or make sure the cold water is turned on at the sink. Hope that helps, let me know.
http://tclaundryrepair.com/
Feb 28, 2009 | Kenmore 24032\24036 Top Load Washer
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
