Question about Kitchen Ranges
Wolf electric stovetop 5 burners- all three burners in back are working. Two burners in front are not working although the control panel appears to respond
SOURCE: Blinking oven and heating Lights
for no reason the cleaning light went on, even though the oven was not on. The oven light and heating light were alternating each blinking 5 times. The door locked up, too. It seemed to think it was in a cleaning cycle. Any way, problem solved by throwing off the main breaker and all is working fine since... except now, for no reason the oven fan, not the exhaust fan, stays on all the time!
Posted on Jan 03, 2008
jyackle5
  • 8197 Answers
SOURCE: kenmore range control panel not working
sounds like the control board blew on you replace it.
Posted on Dec 16, 2008
SOURCE: Frigidaire Range control panel DEAD
We tested the EOC and it will indeed need a replacement. Also, just a couple weeks prior we ran the "clean" mode on the oven as did another poster who experienced the "pop" and loss of the control board/oven function, but still had stove top function.
Posted on Dec 17, 2008
  • 1214 Answers
SOURCE: LG Electric Range Oven Keeps Shutting Off
When you say "Just shut off" do you mean the circuit breakers would trip, or fuses would blow? If so, I would have an electrician check that the circuit is properly fused/breakered and wire sized for the amount of power required by the oven. If the installation directions say it needs a 50 amp service, it better be a 50 amp service.
If shutting off is just something within the oven, then get LG back out again, and let us know of what they say is wrong.
Posted on Jan 24, 2009
jumptrout51
  • 3361 Answers
SOURCE: electric igniters dont shut off
Remember to turn the control knob past the "LITE" setting once the burner fires.
If that is not the issue you have one or more defective spark switches.
Each valve has its own switch wired in series with the others.
Posted on Mar 12, 2009
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
How do I plug back in the GE stove top burners after unplugging them?
The two leads from the burner fit into a socket in the stove top. It's a bit tricky to get it in just right. If the three metal "legs" on the burner fit snugly into the three slots on the stovetop you did it right.
Aug 26, 2012 | General Electric Ge Stove / Oven / Range...
Frigidaire Gallery Range (New). When plugged in, get a PF20 (power failure). Clock works fine. Both ovens work fine. Stovetop does not work. No heat in burners. No display over burner.
When it doesn't heat up,
We have a Frigidaire Range model PLEF398CCC and, as many others here have mentioned, we saw the puff of smoke and the oven nor the front left burner works. The repairman has to replace a EOC on the back of the control panel and another one in the back on the bottom. The total cost for parts alone is $438 then add in the service call cost. THIS IS THE SECOND TIME we've had an EOC go bad for big bucks. The unit is about 5 years old. We're thinking of filling the landfill with it.
Use this for troublshooting:
(home-electrical.suite101.com/article.cfm/troubleshooting_an_electric_range)
another testimony to help,
Had the same problem. This solved it for me:
(lazerangle.com/sanna/index.php?option=com_content&view=section&layout=blog&id=6&Itemid=63.).
Take care.
Jul 12, 2010 | Frigidaire Gallery GLEFM397DS Electric...
I need to replace the glass cooktop on my Maytag electric stove
  1. Open oven door and remove two screws that secure top.
  2. Lift up front and slide forward about 8 inches so that you can disconnect two wire couplings.
  3. Place on table upside down(I put newspaper down to catch the broken shards of glass) and remove burner unit (1piece, 4 screws).
  4. Place old burners on new stovetop in the same position as original.
  5. Remove 4 white plastic shims (round) from old stovetop and put on new stovetop.
  6. Tighten all screws and then sit it back on stove (two front tabs fit into slots) and then insert screws into holes and tighten.
  7. Took about 20 minutes, including vacuuming broken glass from inside burners and cleaning grease form crevices between burners and old stovetop.
  8. Wrap old stovetop in the newspapers that are underneath it and place it all in a plastic garbage bag to avoid any broken glass from falling out.
Jan 21, 2010 | Maytag MER5775Q Electric Kitchen Range
Electric igniters dont shut off
Mar 12, 2009 | Wolf Manufacturing Gas Kitchen Range
Jan 24, 2009 | LG 30 in Kitchen Series Dual Convection...
Wolf electric induction stovetop
I had that happen once and it went off after a day. I'd suggest maybe turning off the breaker and wait a few minutes and turn it back on. But here's my problem for you. I got the 30" model in March, 2008. The problem I've had is that the induction units cool down and start cycling when I'm cooking something like bacon, or pork chops etc., ie. where you're trying to brown something or sear. They cycle up and down every couple of minutes, so its really annoying. They work fine if I'm boiling water for pasta or sauces, etc. Have you experienced this. I've been working with the dealer and the company and they say its a "software" problem, but they've haven't taken them off the market. I use All-Clad stainless steel pans so that's not the issue. Thanks for your comments.
Aug 16, 2008 | LG 30" Built-In Electric Induction Cooktop...
F7? What is it?
http://www.appliancepartsdepot.com/Repair/BookLinks/viewer.asp?ch=7&apptype=5
Jan 28, 2008 | Magic Chef CER3740 Electric Kitchen Range
Jenn-Air Electric stovetop / oven range SCE4340B - Fuse blown ? ? ?
Andy, sounds like you lost a leg of power. Check the breaker box first. Maybe the contractors tapped an existing breaker instead of adding one for the burner/broiler. You would have to check the terminal block on the range. Should read 120V from each end to center and 220V across the two outer terminals. If you don't have this, something got messed up with the contractors. Catriver..post back
Mar 04, 2007 | Jenn-Air JED8430 Electric Cooktop
Kitchen Ranges Logo
29 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
