Question about Garden
I have a Stihl 011 AVT w / new oil pump and line and this thing pours excessive amount of oil from port ??? I have taken it apart and cleaned pump . Where can I find an exploded view of oil system ?
  • 2692 Answers
SOURCE: i have taken my hp apart and i need an exploded view of assembly
See if their is any help here:〈=en&cc=us
Posted on Jan 16, 2009
SOURCE: Chain Saw, Stihl Model 011, cutting off
I've been messin with my poulan 2150 that was doing the same thing. Good, fresh gas, good spark,etc. I noticed whenever I loosened the fuel cap it would literally spray gas out! alas, I removed the muiffler assy and the darn thing fired up the first pull! I've got the muffler parts soaking in gas right now and I'm sure this the problem. It just makes sense especially if you use the same 'mixed fuel' can for weed eater, blower,etc. Check your's out, it could very well be your problem too! GOOD LUCK
Posted on Apr 29, 2009
  • 155 Answers
SOURCE: need to see exploded view of mtd 753-1255 carb
Hi what model is it you can try this site its called pats small engines
Posted on Jul 26, 2009
  • 12 Answers
SOURCE: I need to rebuild the carburetor on a Stihl model
I don't have a diagram or the part numbers to the minor and major repair kits, but a Stihl dealer should be able to help. Tell him you need a kit for a ZAMA C1Q type carb. The exploded view should be with the kit.
Posted on Jun 13, 2010
  • 1378 Answers
SOURCE: pump was clogged it was
10 wt. non-detergent/non-foaming oil.
Posted on Feb 28, 2011
I haves Sthil 010 AV chainsaw. It has no carburetor. How do I know which is the right one
Hello, here is the website with the correct part for you:
Stihl 009 010AV 011 AVT Chainsaw Parts
Please rate my answer, thk you.
Nov 15, 2015 | Garden
I have a stihl ms 192 tc it runs great while running it freely but when I cut in to a limb it losses an excessive amount of power an sounds like the break is on
Hi Kevin
Assuming it's a 2 stroke with oil in the fuel so the engine is not overheating & seizing? 25:1 Mix
Check the Sprocket bearing on the front of the bar. Is it seizing because of lack of oil or even damaged.
Take the chain off and test.
Apr 02, 2015 | Stihl Garden
Oil is not getting to the chain with a stihl 012av chainsaw.
I'm almost sure you have to remove the oil tank and then the oiler
Nov 26, 2014 | Stihl Garden
Stihl 011 AVT goes to full throttle when started.
Check throttle linkage it may be sticking.
Oct 06, 2014 | Garden
How do I adjust the oiler for my Stihl 011 avt?
I can't speak specifically to a Stihl, but I've had Homelite, Poulan, and currently a Remington electric. They've all either put out too much oil or they leak to empty when I'm not using them. The only control I've found is to store them blade up so the oil reservoir is down. That keeps them from leaking but doesn't help controlling the oil output. In all three of the above machines, the oil runs through a little plastic tube from the reservoir to the opening at the chain. There is no gate or valve to control the flow which is gravity fed from the reservoir.
I fixed the problem by letting the reservoir drain dry and never refilled it. I now keep a small pump oil can with my Remington and I put a little squirt on the chain when I start cutting and another squirt after each two or three minutes of operation. It's a bit more trouble but it's a lot more effective and a lot less wasteful and messy.
The is probably the most common complaint I hear from friends with chain saws and it's been going on a long, long time. I can't conceive of why the manufacturers have not resolved this problem. A thumbscrew clamp on the little hose could easily be designed into virtually any chainsaw and should not impact the price at all.
Apr 28, 2014 | Garden
No pilcoming through 009 stihl chainsaw
Check to make sure the pick up line in the tank hasn't come lose. Then check the port under the bar and cover is free and clear of debris. If that's not it you probably need a new pump.
Jan 29, 2014 | Stihl Garden
Stihl parts manual
Hi Chris
The rod or the housing may be enlarged or worn and not allowing it to pump oil as normal.
I would recommend that you replace the oiler rod and housing
Oct 21, 2013 | Garden
I have a Stihl 16" 012 AVT chainsaw. I cannot get
First thing I would try is wash out the oil tank with a little bit of diesel fuel then run some thinner oil thru it to see if it gets better . I usually leave bar and chain off when I do this.. or if it is oiling but not going down the bar check the bar oil holes.
May 10, 2017 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
