LG60PA6500UA plasma TV picture goes black, sometimes after the TV is on for 15 min, Sometimes after the TV is on for many hours, sometimes the picture does not go out at all, sound always stays on.
TV is four years old. No bulging capacitors. No pattern as to when the picture goes out. Can turn the TV off for a while then turn back on and picture is back on.
ser71
  • 818 Answers
SOURCE: Monitor goes black - green light stays on
My screen is black, why do I not have a picture?
Answer Antenna is not hooked up to television.
  • Make sure that the antenna cable is correctly connected to the television. If it doesn't work there appears to be no signal.
Problem is caused by television broadcast
  1. Push 'INFO' button.
  2. If the screen shows channel number (1, 2, 3, etc) try another channel. Not all channels broadcast at all times.
  3. You may have a signal problem. Contact cable provider or local broadcaster regarding the specific channel.
Television is in EXT or SIDE mode, and there is no external source provided, so screen mute (black screen) is activated.
  1. Push NEXT SOURCE button on the remote.
  2. On the screen appears all sorces.
  3. Press the UP button to switch to the TV mode.
If you are using an accessory device (DVD, DVR, or VCR), be sure the device is on and running.
Blank screen when connecting to the accessory (DVD, STB, PC) device via HDMI to HDMI.
Answer
  • Make sure the cable is well connected .
  • To check which connection is selected, Press the i+ button on the remote control.
  1. When you see Blue mute / blank screen and the i+ display does not indicate any video resolution indication then there is no valid signal detected.
    • Make sure the HDMI output of the accessory is valid by changing the video output resolution to a resolution which the TV can handle.
  2. When you see a blank screen and the i+ display shows a video resolution indication then the connection is correct.
    • The blank screen is caused by the accessory device and not by the TV.
    • To detect and remedy the problem caused by the accessory device, check the instruction manual of this device.
  3. If the problem remains : reselect the HDMI external source input by changing to the other HDMI input and back to the connected HDMI :
    1. Press AV on the remote
    2. Press up and then ok
    3. Press AV again
    4. Press down and ok
    5. The compatibility check process between TV and accessory device will start over again.
  4. Reset (switch off and back on) the TV and also reset the accessory device.
Posted on Mar 05, 2008
cactus bob
  • 267 Answers
SOURCE: Picture on 15 year old Trintron comes on briefly then goes black
if the sound goes out its not a tube problem . a bad tube would have no effect on the sound .you problem (my guess) is in the power supply . a modern tv power supply has parts of it that stay on all the time unpluging it is not the problem its when you plug it in ! the power supply gets a JOLT . you might get away with it ,you might not . thats why we install surge arrestors on power plugs and with expensive tvs i recomend a UPS a power unit that keeps the tv powered even wnen the line power is out . thats keeps everthing in the sets nice and even ,so the tv lasts longer ... a modern tv turned off uses about 1.40 in electric a YEAR in standby mode , so what are you saveing if you send you set to the landfill early and have to buy a new one ? over 1.40 in electric ? . turn down you water heater or something else simple dont be blowing out you electronics for the sake of a few cents ..... good luck .... if this answer helped please rate a 3 or 4 , this high rateing will hepl keep me in the paid answer department . thank you
Posted on Apr 19, 2009
  • 668 Answers
SOURCE: TV screen goes black, sometimes for hours
This model series had a odd problem that caused this. It was the Hoizonal wire connctors for the yoke. If my memory serves me right, the Yoke wire harness went from Yoke to Yoke and plugged in at the casing of each yoke. What I found is the solder connection on the small board of each Yoke was intermitent. Please be careful if you choose to tackle this. It is in a HV Area.
Hope this helps,
Skyassoc
Posted on Jun 19, 2009
  • 175 Answers
SOURCE: Picture goes black, sound OK
is it under warranty, it could be the ysus or the panel
Posted on Apr 27, 2010
SOURCE: My Sharp LC-42SB45U takes 15 min to an hour to turn on. Also, sometimes picture blacks out for 10-15 seconds. Any suggestions? Pat Courson
Have same problem. Not the proper fix though I found that taking the back off and heating it up with a heat gun for 30 seconds to 1 minute and tv works fine till you shut it off over night.Maybe someone can offer a solution with that in mind. Pretty strange
Posted on Sep 23, 2012
I have a 50 HItachi Plasma tv, after awhile the picture goes black but the sound is ok. It won't come back on until we unplug the tv then plug it back up. Sometimes the tv will stay on for an hour...
Your fluorescent tube or the board driving it is bad. Have the tube checked out before you spend a lot of money on a circuit board, this is not something you should do yourself especially if you are not a TV service technician.
Feb 02, 2018 | Hitachi P50H401 50 in. Plasma HDTV
Sep 17, 2012 | Sharp LC42SB45U 42 in. LCD TV
MY philips 42 inch plasma TV model 42pf3320/10 screen goes black after a few mins sometimes. what can i do to fix it???
Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 01, 2012 | Philips Televison & Video
Screen lower half goes black/blank
The lower "Y Buffer" board is defective. Best repaired by a technician, or contact Phillips support for the part if you think you are able to replace a small circuit board on your own.
May 19, 2009 | Philips 42FD9954 42 in. Plasma HDTV
Tv powers off after 15 mins to 2 hours
what is the model # and brand
May 02, 2008 | Televison & Video
Audio ok, but Video goes from color to black.
the tv turns on fine, but after 5 - 30 min or so, "sometimes MORE " the picture all of a sudden go's black. Sound is ok it is 100% loose contact problem. 1 please check for any connector or print for loose. 2 in signal processor ic there might be loose. remember there is no component failure.
Sep 24, 2007 | JVC AV-32D305 32" TV
Televison & Video Logo
Top Televison & Video Experts
