Question about Kenmore Sewing Machines
The feed dogs on my old Kenmore sewing machine move up and down but are not feeding the fabric thru. How can I fix this myself?
    Top Expert:
  • Kenmore Master
  • 8,375 Answers
ELNA 1000 not moving fabric through.
Have you got a tangle under your fabric? If so, release the fabric and rethread your machine, making sure the foot is up during threading. Otherwise check the feed dog under the foot. There's usually a switch somewhere that brings the feed dog up or down. If it's down the fabric won't feed. Another point, what type of fabric are you sewing. If it's leather or leatherette you'll need to use a roller foot. Hope this helps.
Oct 03, 2017 | Elna Sewing Machines
The fabric doesn't move when I begin sewing
Is your presser foot down? Do your feed dogs go down? If they do move the lever to the up position. The feed dogs are what feeds the fabric thru the machine.
Jul 04, 2017 | Sewing Machines
I have an old Kenmore Convertible 1785 machine. It is working fine except it won't pull fabric thru. Any suggestions on what could be wrong?
Are the feed dogs in the up position? Is your fabric very slippery or silky? If it is you need to use a tear away for the feed dogs to grab on to I order to move the fabric forward.
Nov 26, 2016 | Kenmore Sewing Machines
Why is the needle not moving or feeding fabric but motor is running
the needle only sews,, it's the feed dogs in the needle plate area that feed the fabric thru the machine, if the feed dogs are in the up position then the machine will sew, if the machine is not sewing then the feed dogs need to be checked to see if the feed dog lever is up or down, look in the manual to see where the lever is and check it, if the lever up the then feed dogs will need to be checked to see if there is something's wrong with them at a sewing machine repair shop.
Jul 31, 2014 | Janome Sewing Machines
Viking emerald 116 sewing machine will not feed fabric
Look at the feed dogs (the serrated metal strips on either side of the hole the needle goes down thru). If they aren't moving when you turn the handwheel or not protruding above the sewing surface (needle plate) then 1 of 2 things has likely occurred.
#1 - your machine is equipped with at feed-dog drop selector (drops the dogs down for free-motion sewing) that you have activated (intentionally or not) or
#2 - you have enough lint debris accumlated under the sewing surface to stop the dogs from coming up properly or move all together.
Have the machine professionally serviced. A good servicing will resolve 60% of the problems that sewing machines incur. You should have the machine serviced at least every 100 hrs of sewing, more often if you use cheap thead, cheap fabric or metallic threads. All of these leave a lot of debris inside the machine.
Jan 05, 2014 | Husqvarna Sewing Machines
Does 514 pressure foot move?
what is the name of the machine?
do you want a manual?
the feed dogs are what move the fabric thru the machine, the presser foot only hold the fabric against the feed dogs so the feed dogs can move the fabric
the feed dogs in the needle plate area should be up
May 28, 2012 | Sewing Machines
Cloth does not move . It sews when I pull the cloth myself, but it does not automatically moves the cloth by itself
Make sure your feed dogs are up. Feed dogs are moving metal parts in the needle plate that make the fabric move forward under the presser foot. Open up the shuttle box underneath the needle plate. There is a lever to the right of the the shuttle. Press the lever down and to the left to raise the feed dogs.
Apr 03, 2010 | Kenmore 15358
Kenmore Model (385.15108200) Fabric not moving
hi! there if your feed dog does not move the fabric forward or backward,if this is so try to run machine w/o the fabric check if feed dog move on cycle,the teeth should be moving upward and downward rotation pushing action on your fabric,the teeth should come out to the plate slot of feed dog.if not adjust upward, and adjust also the presser foot of needle.if your feed dog is not moving when machine running,thre is a mechanical disengage or loosen in shuttle assymble and feeder dog mechanism they link together ubder the machine,as the shuttle move on one stroke the feeder also move also with the needle.Chesk the adjustment and link mechanism.in addition to this try to clean feed dogs by brush chips thread and fabrics sometimes stored on mechanism of feed dogs and shuttle.
Mar 19, 2009 | Kenmore 15208 Mechanical Sewing Machine
My kenmore 385 won't feed fabric
hi there check feed dogs are up not down mary h
e
Dec 28, 2008 | Kenmore 16622 Mechanical Sewing Machine
Fabric wil not feed thru machine
adjust your feed dog hight. manual shows u how
Dec 02, 2008 | Kenmore 15218 Mechanical Sewing Machine
Sewing Machines Logo
117 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
