How do i restart my eg front loader it keeps stoping going into pause mode and the door lock want unlock and it want stop draning
SolutionGuy
  • 331 Answers
SOURCE: Door lock
Run a diagnostic on the door lock system; To place the unit in "service mode", close the door completely then press and hold both the "Delicates" and "Heavy Soils" keys for three seconds. Motor speed will be displayed. Press "rinse" to access the main board output function. Then press "max extract"... this is the test for the door lock. Did it lock? To exit, press "max extract" again and then both "Delicates" and "Heavy Soils" for three seconds. VOLTAGE TESTS AHEAD!!! IF YOU AREN'T SURE YOU CAN DO IT, THEN DON'T! CALL A PROFESSIONAL! If the door did not lock, you'll need a voltmeter and an hour or so. Open the door, remove the screws holding the door hinges, then remove the 2 screws (and shims) opposite the door hinges and close the door (do not take it off). Then grasp the front panel at the top near where it meets the top panel and pull toward you quickly. Lean it forward and remove it from the 2 clips at the bottom. Just below the top panel, now exposed, are the top panel retainers... use a 5/16" to remove the one screw on both sides and remove the retainer clips. Now lift the top panel up just like the hood of a car. You can now see the door latch assy. Remove the 2 wires on the solenoid and insert your meter probes into each one of them (color doesn't matter). Set your meter to read AC Voltage, then re-enter "Service Mode" and follow the steps to door lock test. When you hit the "Max Extract" key, 120 volts should be sent to the meter. If you get 120 volts, your latch assy. has failed and should be replaced. If you don't get 120 volts, your control board output has failed and needs to be replaced. Hope this helps.
Posted on Jul 29, 2007
  • 641 Answers
SOURCE: GE Front Loader Washer - Not washing
It sound like a lid switch issue. If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. Look that the switch is not broken or loose. If all is fine, you should replace the switch. Good luck!
Posted on Aug 27, 2007
  • 5 Answers
SOURCE: GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Posted on Oct 31, 2008
  • 6277 Answers
SOURCE: Problem DWD-WD1132 front washing loader stopped
Sorry- we can only deal through the forum unless you take the option to pay for someone to talk to you ;-0(
In any case I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 08, 2011
Testimonial: "Thank you for your comments and help I opened a drain below on the left side of the machine. Water was drained out the machine Then it works normal. "
michiganfan9
  • 179 Answers
SOURCE: Door won't unlock whirlpool wFs1073dd front loader
If it has water in the the machine, it has a safety feature that will not allow the door to unlock. There is a manual release but you have to take the bottom kick plate off. Unplug the washer. Then reach up on the right side of the washer and you will feel a plastic lever about the size and shape of a nickel pull down on this lever to release the door. If it full of water i would clean the pump first to get rid of the water. you can clean the pump by taking off the kick plate and you will see a pump with a lid with a handle on it. you can unscrew this and it will have a trap attached to the back of the lid. pull the trap out and clean any debris out then screw it back in. make sure to have buckets and towels handy once you unscrew the lid any water in the machine will fly out at you. the easiest way to avoid this is to clamp the hoses that go to the pump.
Posted on Aug 25, 2012
Front loader leaking out the front door as is clothing stuck in it, How can we release the door lock. We've stopped the cycle.
Restart the machine...
On a NEW CYCLE... The first thing the machine
should attempt to do... is to drain itself.
If it does not...
UNPLUG IT... Restart it on a spin cycle ... or regular
wash cycle...
Carnac the Magnificent YZQ7YL
Jan 21, 2017 | Washing Machines
Tip
The front light lit on my Whirlpool dryer is showing control locked
Hi.
If the front light lit is control locked, that means that your Whirlpool electric dryer had been set in control lock mode.
Control lock is a special mode that will prevent user from changing settings or using control until the dryer gets unlocked again.
The machine is set to control lock mode by holding down the CONTROL LOCK/UNLOCK button for several seconds. In the same way you can stop the control lock mode when the machine is already set to Control Lock.
When the dryer is running and Control Locked is on, the dryer can still be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If the front light lit is control locked but the dryer door opens and it does not turn off, then you are probably in this situation. In that case, the door will be opening , but the machine still stays locked.
Disconnecting the machine from power, either unplugging power cord or tripping circuit breaker, won't help. The control lock system is designed to stay on in case of power failure.
If the machine is control locked, try unlocking it with the following procedure.
To unlock: Press and hold the CONTROL LOCK/UNLOCK button for 3 to 5 seconds to turn the control lock feature off.
If that does not work, try disconnecting power for five minutes to reset the machine, and eventually do unlock again. As said, cutting power alone will not cause the machine to unlock.
If the machine is still not responding, the lights stay on all the time, the dryer panel does not respond to control unlock procedure, and the door does not lock anymore, then it may be a defective control board.
If you are in this situation, before replacing the control board more parts, including the door lock must be tested. In that case the best option may be contacting the Whirlpool support number listed on the Dryer use and care manual, usually in the last pages.
In this case try resetting control lock as explained above, as told the dryer is more likely control locked and then stopped.
Regards.
Ginko.
on Feb 01, 2010 | Whirlpool GEW9250 Electric Dryer
I dont have a stop buttom
You're start/pause button should pause the cycle, cancell should completely cancell. After pressing the Start/Pause within a cycle, the door lock may require time to unlock as indicated by the lock light on the panel.
Apr 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
I want to open the door mid cycle and restart it. Instead when I push pause the door remains locked and I can't insert another item without draining the water and starting over.
Yes that is how that style washer works since its very possible if opening the door when water is in the tub that it would spill out when opening the door when water in the tub..all front loaders work ina similar manner where when water is in the tub the door wont unlock
Aug 31, 2011 | Whirlpool Duet GHW9150P Front Load Washer
WASHER TROUBLESHOOTING
My GE front loader keeps stopping in the middle of the cycle. It does it over and over and never completes the cycle. It just started doing this a couple of days ago. It took me all day to do one load of laundry the other day. Tried again today with no luck. I tried it on three different cycles and all the same. It just keeps stopping and going to pause. When I shut it off it takes about 20 minutes for the door to unlock. Is this problem worth fixing or should I junk it?
Aug 07, 2010 | Frigidaire ATF6000ES Front Load Washer
I have a two-year old Frigidaire GLTF2940FSO front loader washer that has stopped in the middle of a load leaving water in the drum and will produce a buzzing sound no matter what cycle you put it on. We...
did you try unplugging it and plugging it back in to see if you can get it to reset? Would it buzz when you try to drain it? Does the door latch lock when it goes into the wash cycle? Usually the door latch locks when it goes into the wash cycle and stays locked. So it filled up, the door latch should lock, then should go into wash cycle. Then you said few minutes later it stops. How did you get the door open? reason i ask is Usually i would see the clothes get stuck inside the washer because the door latch is still locked when it stops. Was the door unlocked when it stoped. If so maybe something going on with the communication from the board to the door latch maybe. Did you try operatin the drain?
Aug 01, 2009 | Frigidaire GLTF2940ES Front Load Washer
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control Lock
Front loader washing machine
This is normal, the unit usually goes into a SD or slow down mode. To stop this press the start pause button and the door will unlock.
Sgt 48
Jun 04, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Door lock
Check for loose wires in the door lock; or replace door lock.
Dec 02, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
