Question about Hannstar I-Inc TW-191D Monitor
Same thing noise + no visual wtf
Monitor wont turn on makes this crackling noise also
  • 41 Answers
Well u need to first check the power leeds for the monitor .......
if it okie then i think that u need to get in touch with the harware tech for the monitor and they will repair the things for you as they would open the monitor and manualy check the setting for the same
Posted on Jul 22, 2009
Blackberry phone wont start but makes humming noise when charging
Pull the power cell out and replace. For testing, take it to the phone store and have them run a continuity test to see if any of the other components were damegaed.
Mar 21, 2014 | RIM BlackBerry Curve 8310 Smartphone
Sennheiser HD 205 crackle when listening to music
If the crackling occurs only when opening windows or another program, the crackling is not due to the headphones but to a lack of CPU resources in your computer settings.
If you are in Windows 7,
  1. click the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, and then click Control Panel. In the search box, type Performance Information and Tools, and then, in the list of results, click Performance Information and Tools.
  2. Click Adjust visual effects. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Click the Visual Effects tab, click Adjust for best performance, and then click OK.
May 23, 2012 | Sennheiser HD 205 Professional Headphones
What do i do when my monitor keeps making crackling noises?
There may be near by interference, example flouresant tube. Move the monitor in different locations to see if there an improvement.
Mar 09, 2012 | Summer Infant Day and Night Handheld Video...
The monitor keeps making crackling noises
Try relocating the monitor to rule out external interference, if no the monitor will need to be checked for bad connections such as bad solder joints.
Mar 09, 2012 | Summer Infant 02100 2.5 inch Color Hand...
Htc evo makes crackling noises and vibrates lights up but wont turn on all the way
you either have a defective battery or a mainboard fault inside the phone.
Mar 08, 2012 | HTC EVO 4G Smartphone
My HP w22 Monitor started to make a crackling sound and than all the sudden turned off, or something. It wont come back on. The computer works just not the monitor. Any ideas on how to fix the problem?
Try checking your Cable connections to the Monitor to the Computer and from the Monitor to the wall outlet.The crackling sound maybe normal.Most Monitors make that sound.
Jul 31, 2010 | HP W22 LCD Monitor
I have a crate PA 8 and it makes a crackling noise when I play through it. I hooked the speakers to my other amp and they sound good, I hooked the PA to my marshall cab and it still has the noise, so I...
Hi
The problem is with the amplifier itself. Crackling is usually capacitor related and you will need to have the amp checked over to properly identify the cause.
Some amps are also prone to pick up static from other electrical items which can also cause these problems. I had a crackling issue with an old Crate amp of mine which turned out it was due to being too near a computer/monitor so it is worth eliminating these things as a possible cause before having the amp checked.
Hope this helps. Thanks for using FixYa.
Oct 28, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Monitor lost contrast
The crackling noise will be the the inverter section cooking itself.
The power board is a BenQ manufactured part and this is common to a lot of LCD's.
Inside there are several small 8 pin IC's, one or 2 of these has possibly shorted out and died.
An easy repair, if you know what you are doing. If you are not familiar with the internals of an LCD though, I suggest you take it to a repair centre. The voltages inside can kill (even when it has been turned off)
Mar 05, 2008 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Computer making noise
Monitor clicks, pops, or makes other noises. Issue: Monitor clicks, pops, or makes other noises.
Cause: This issue could be caused by any of the below possibilities:
  1. Monitor degaussing.
  2. Monitor changing resolution.
  3. Monitor syncing with the video card.
  4. Monitor warming up.
Solution: Noise when turned on or off It is normal for standard computer CRT monitors to make a click, pop, crackle, hum, buzz, or other type of noises when they are first turned on or turned off.
Noise when monitor goes into standby mode When the monitor enters a "standby mode" or "power savings mode" this is similar to the monitor being turned off. It is completely normal for the monitor to make a noise when the monitor enters this mode.
Noise when opening Microsoft Windows or other operating system or when opening a game When a computer opens its operating system, for example, a computer opening Microsoft Windows or when a user runs a computer game it is very common that the monitor will need to switch its resolution of the operating system or game. When switching resolutions it is normal for the computer monitor to make some type of noise and/or for the computer monitor to flick or flash.
Noise during normal operation If the computer monitor click, pops, or flashes while it is being used this is not normal operation. It is very likely that the monitor may be failing or a component within the monitor has already failed and could also potentially be a fire hazard. We highly recommend that the monitor be repaired, replaced, and/or looked at by a qualified technician.
Additional information:
  • See document CH000302 for additional information and other noises that may come from
Jan 16, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Crackling Sound From Subwoofer
Check any wiring coming or going to the subwoofer. It sounds like it could be a loose connection.  Is there a LFE or bass boost knob on your subwoofer? Does turning that up/down cause the crackling (if it exists). If so, you could use some tuner cleaner to clean the contacts on the potentiometer knob.
If the crackling is on the subwoofer only, it might be damaged from bottoming out.  See if you can remove the baffle or grille covering the woofer and inspect for visual problems. You can also try to lighly push in and out on the subwoofer to hear if it makes any scraping sounds. If so, it is definitely damaged and the driver will have to be replaced.
Mike
Jan 21, 2007 | Altec Lansing 221 Computer Speakers
Hannstar I-Inc TW-191D Monitor Logo
128 people viewed this question
Top Hannstar Computers & Internet Experts
 Russ Hill
Russ Hill
memman
memman
Level 1 Expert
Are you a Hannstar Computer and Internet Expert? Answer questions, earn points and help others
