Question about Radio Communications
If the blue tooth speker is flashing red and blue what should I do Nothing or something else if I cant get it to work
4 Suggested Answers
SOURCE: hi help plz
What type of phone do you have? When you try pairing with your phone are you sure you have activated the option? If not, here's what to do. Hold the call button on the H500 until the blue light stays on, then with your phone go to the bluetooth option and select search for devices. It should be able to find it then.
Posted on Sep 21, 2007
justaplumber
  • 98 Answers
SOURCE: dont know how to work my blue tooth to my phone
You have to get the phone to recognise the bluetooth headset first. The manual should tell you how to do this. Normally you have to go into the bluetooth menu on the phone and get the phone to detect the headset, and then type in the pin code, normally 0000.
Posted on Jan 11, 2008
casouzaj
  • 1118 Answers
SOURCE: SUDDENLY THS MORNING THE BLUE
I think your car kit has lost its pairing data. Blue and red lights flashing alternately means it is in pairing mode. On your phone (or the device it was paired with), delete the partnership with your car kit, and make it search for new devices again. After a little while, your car kit should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey, or passcode) is requested, enter '0000' (four zeros).
By the way, detailed instructions on how to pair it with your phone (illustrated with pictures) can be found on its user guide; In case yours happens to be missing, you'll still be able to find it here.
Hope you are able to sort your problems out soon.
Please, let me know if I can help you any further.
Regards, Carlos
Posted on Nov 12, 2010
I have a dell latitude D810 and the spekers dont work
try installing this audio driver. ftp://ftp.dell.com/audio/R99254.EXE
get back to me if that doesnt work
Feb 01, 2014 | Computers & Internet
How do I fix iPhone microphone Problems with headset and Bluetooth?
Go to the settings on your I phone select search for blue tooth device and at the same time hold down the large button on your blue tooth device until it flashes blue and red keep it pressed until it stays blue then your phone will be pared to you're blue tooth device.
Mar 15, 2013 | iPhone Apps
I am having a problem with my bluetooth it is the EM227 it seems i cant get it on my phone and i have been trying for 3hrs could you help me
Hi ,
Its pretty Simpal , Try that Blue Tooth with other phone .
If it work's . Then you have to Check your phone blue tooth opetion . Should something missing . If you cants find , just reset your Cell phone .
It should Work .If not then pleas let me know.
Shahzad - IT
DUBAI - U.A.E
Mar 12, 2011 | Emerson EM227 Bluetooth Headset
Bluetooth not working in sony W580i phone
HOW TOCONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
After attempting on this process, if doesn't work,that means thee blue tooth is corrupted and to restore bluetooth, you will to flash the phone. Flashing the phone will restore back blue tooth.
You can use this links to see how to flash your phone.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
Take care.
Jul 03, 2010 | Sony Ericsson w580i Cellular Phone
I am having problems connecting my plantronics explorer 390 to my black berry curve
First turn your Blue Tooth setting to "ON" on your Black Berry Curve, as it searches for a Blue Tooth Device, Push and hold on the middle button of the Blue Tooth until you see a flashing "blue light & red light." It's important that you see both flashing lights.
May 19, 2010 | Plantronics Explorer 390 Bluetooth Headset
On my ps3 bluetooth scanning for a ps3 headset its
Make sure that your blue tooth is in pairing mode when the sysytem is scanning.(refer to blue tooth headset manual for intrustions)
I hope i have helped and I hope it works!!
Jan 07, 2010 | Sony Playstation 3 (PS3) Console
Setup for trueblue/bluetooth, Tb20el
start in the off position press and hold the talk button and you will hear a tone continue to hold for another 7 seconds (10 seconds total) then the light should be flashing blue then red it is now in discovery mode now take the divice you are trying to pair it with and do a search for blue tooth devices. once it is found you may need a password it is 0000 as is the default password for all blue tooth devices hope this helps.
Apr 30, 2009 | Radio Communications
My Samsung Spex 210 phone is telling bluetooth not found. Can you help?
Have You Put The Blue Tooth In Find Mode?
This Can Be Done By Holding The Button On The Blue Tooth Until It Flash's Red And Blue Or Stays Solid.
If This Doesn't Help Please Provide The Model Number Of The Blue Tooth.
Sincerely,
Michael Scott
Jan 30, 2009 | Radio Communications
Syncing the HFBLU-10K with the iphone
for iphone : set your phone to scan for wireless device
1 unlock
2 settings icon
3 general
4 bluetooth ON
the hold the big button on the blue tooth once it flashes blue DO NOT LET GO! keep holding it till it flashs red and blue red and blue then let go and it should find it instantly then press on the BK-600 word and enter the 0000 code and you should be all set.
Jan 06, 2009 | Cellular Innovations HFBLU-CX1 Wireless...
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
