Question about Masterbuilt Grilling
We have the Masterbuilt Elite smoker. We are having trouble with it when we take a reading with the probe or try to adjust the temperature it automatically will shut off. Have to wait about 15 minutes
  • 109 Answers
SOURCE: Need instruction on how to season masterbuilt electric smoker
soak some hickory/ oak / mesquite chips any one of these will do, soak them in water for a couple of hours then put them in the pan and turn it on this will burn out any coating on the metal and flavor the grill for smoking leave it on for a good 2-3 hrs on med then on high mke sure you keep the chips replenished
Posted on Aug 23, 2009
  • 7 Answers
SOURCE: My Masterbuilt electric smoker stopped heating will cooking
I just bought a new Masterbuilt Smoker by default two weeks ago I borrowed a friend’s to smoke about 30lb. of Salmon to then can. Ran the smoker every day for three day. ON my last batch the heating element would not work. Talk about Frustrated! The Smoker was only 2 yrs. old.
Knowing I borrowed I felt I had to replace. So online to Cabelas and I ordered my buddy a new smoker and had it shipped. I then found this website... GOT TO LOVE the internet. I saw many other people had the same problem. Found an Answer...
The Problem was one of the connector to the heating element was poor quality and if you don't clean your smoker on a regular basis. The heat and moister caused the small copper connector to corrode and the wire to come loose. I took a wood chisel and cut off all the rivets on the back. I was then able to pull the back off with no damage and access the small box in the lower back. I found the connector. Went to the hardware store and bought a replacement for .75 cents. A pair of wire crimpers and the problem was fixed. I also bought ½ inch Sheet metal screws to secure the back it was good as new. So I returned the smoker to my buddy and kept the new one. When it arrived I saw Masterbuilt has since fixed the problem and provided an access panel to the element and connectors.
Mike in Alaska
PSU313@yahoo.com
Posted on Jul 03, 2010
heatman101
  • 43501 Answers
SOURCE: can you buy a replacement heating element
Here is a pdf of the smoker book and on page 4 there is a parts list with the cust. service number to order replacement parts...there is an element kit listed there, that is what you need.
http://www.masterbuilt.com/pdf/manuals/Smokehouse%20models%2020070206,%2020070106.pdf
heatman101
Posted on Jul 25, 2010
SOURCE: Where to put the wood chips in my gas smoker
you soaked the wood chips in water for about 30 min. shake excess of water and place them on the flame disk bowl right under the water bowl.
Posted on Aug 15, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Masterbuilt smoker model 20070910 with
Hi and welcome to FixYa, I am Kelly
It is telling you that the temp is below 40 degrees F. All you need to do is warm up the temp probe to 40F and it should work just fine. Use a hand held hair dryer or a warmed up shop vac on b.l.o.w to warm it up.
Happy New Year,
Kelly
Posted on Jan 01, 2011
We bought a new masterbuilt electric smoker. When we power it on, we get the message EAA1 and it shuts off.
Take off the electronic control unit and make sure the probe is still connected (unplugged and check the pins for damage). After reassembling the unit everything should work fine. My guess is that the probe is not properly connected, Once it was properly connected, the actual temperature showed on the display. Hope that helps.
Dec 23, 2017 | Masterbuilt Grilling
I have a shank proportioned ham hickory smoked 11 pounds how long do i smoke this in my smoker I have a Masterbuilt with built-in probe and remote
depends on how smokey you want it to be .if it is already hickory smoked what more do you want or need .
Dec 10, 2015 | Masterbuilt Grilling
Masterbuilt smoker error message EA2
EAA2 means connection to the meat probe is lost. Either a broken, burnt wire or the probe itself. Check the probe wire carefully to spot a break.
Jul 05, 2014 | Masterbuilt 20070411 30" Electric Smoker...
Probe reads to high compared to my other meat thermometers
Thanks for the great question. While I am a avid smoker and outdoors men I can tell you that most of these gauges are not real accurate and only measure ambient air temp. Also the placement of the gauges in the upper portion of the smokers will give a higher reading because heat rises. My best suggestion is that you use a stand alone meat thermometer for guaranteed great smoked meats. You can also measure the temp inside the smoker using a stand alone thermometer and read your guage at the same time. Than you can use adjust the door thermometer by turning the center of the probe on the back with a pair of plier. You should see a nut head or a locking nut that allows you to hold while you turn the face of the thermometer to recalculate it. Some of these may not be adjustable and you can purchase a adjustable replacement online.
I hope this has given you a better perscpective on these gauges and will help solve you problem.
Oct 06, 2013 | Sportsman Elite 40" Vertical Gas Smoker
Masterbuilt electric smoker is brandnew plugged it in runs for about 5 minutes then flashes EAA1 and showing the temp is 32??
Had the exact same problems. I took off the electronic control unit and made sure the probe was still connected (unplugged and checked the pins for damage). After reassembling the unit everything worked fine. My guess is that the probe was not properly connected, therefore it was showing 32 deg all the time. Once it was properly connected, the actual temperature showed on the display. Hope that helps.
Feb 25, 2011 | Masterbuilt 20070106 Electric Smoker
Display is reading EAAF. What does that mean?
If the internal temp is less than 40 F you will get his code. Warm up the heat sensing probe and it should work just fine. If not here is the contact number: MASTERBUILT Customer Service at 1-800-489-1581
Thanks for choosing FixYa,
"Seasons Greetings"
Kelly
Dec 19, 2010 | Masterbuilt 20070106 Electric Smoker
Is there any way to increase the maximum operating temperature on the electric masterbuilt smokers w/ electronic controls?
Unfortunately no. What temperatures are you trying to reach. Most smoking of meat is done at 225-250. What is the maximum you can obtain? Keeping the unit out of the wind and cold, better insulation, stopping any leaks, is about the only way to do it.
Nov 09, 2010 | Masterbuilt 20070206 Smoker
Printout reads eaaf
Hold a warm rag over the end of the thermocouple sticking out of the back, INSIDE the smoker. When the probe gets up to 40F or so the element will turn on and you will be good to go. The computer just doesn't understand whats up when the thermometer gives such a low reading.
Nov 26, 2009 | Masterbuilt 20070106 Electric Smoker
The heating element doesn't come on, the control pad all works and the element ohms out good. where can I get electric parts and a wiring diagram for my 30" Masterbuilt Electric Smokehouse?
Nov 04, 2009 | Masterbuilt 20070106 Electric Smoker
Grilling Logo
67 people viewed this question
Top Masterbuilt Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
