Question about Vizio Televison & Video
Can I get instructions on a Vizio remote lost mine?
My wave cable hd dta remote will not turn offandontv...repair guy said to ask vizio
Use the following instructions and code list to program your VIZIO Universal Remote Control. Press the TV (or device) button and hold for 5 seconds until the LED flashes twice. LED will remain lit. Find the programming code for your TV (or device) in the code list and enter it using the Number Buttons.
try a universal remote and program it, from the manual.
3 Digit Universal Remote Codes For TV Codes For Universal Remotes
4 digit GE universal remote control codes with code entering instructions
http://www.remotecodelist.com/
http://cdn.vizio.com/documents/downloads/vizio-universal-remote-codes.pdf
Feb 03, 2016 | Vizio P50HDTV10A 50 in. Plasma HDTV
Need code for my vizio tv i bought a ihip remote control for my tv
The instructions on letting the Hipi remote to seach for the code that came with my remote are not correct. I used the instructions from HOWTO.COM and printed below. There are two changes from the printed instructions. The first is to push the <TV> button after the <Code Search> button. The second is that the <Enter> button saved the code not the <MUTE> button.
Instructions
Turn on the Vizio TV.
Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
Press the "TV" button at the top of the Jumbo Universal Remote.
Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. (This took only a few tries for my Vizio TV)
5
Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6
Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
Nov 15, 2011 | Vizio VA26L 26 in. LCD HDTV
We gave lost the remote for our Vizio 42" HDTV.
By manual I guess you mean the buttons on the TV and not switching the actual cables. my recommendation is to get a good new universal remote. My personal preference for my Vizio TV is the Logitech 650. Just know that you program it on a computer. It controls up to 6 devices (TV, DVD, Cable box, audio and more), is easy to program with no codes to enter. I am sure it is easier to get then a new Vizio remote though a little pricey at $60.
Hope this helps,
Cullen
May 19, 2011 | Vizio 42 in. LCD TV
I have a Vizio 210 soundbar and the remote control is junk! I want the code the woeks on my Comcast universal remote control.
After much research, here is a step-by-step for getting your Vizio Soundbar to work with the Comcast remote using EFC codes (mine is the newer charcoal grey one, works great!)
Aux - Setup (2 blinks) - 11144 (2 blinks)
Aux - Setup (2 blinks) - 994 - Setup - 00169 - Vol Up - Should get 2 blinks
Aux - Setup (2 blinks) - 994 - Setup - 00168 - Vol Down - Should get 2 blinks
Aux - Setup (2 blinks) - 994 - Setup - 00037 - Mute - Should get 2 blinks
Aux - Setup (2 blinks) - 994 - Setup - 00165 - Power - Should get 2 blinks
Aux - Setup (2 blinks) - 994 - Setup - 00164 - Input - Should get 2 blinks
These are optional, I didn't use them:
Aux - Setup (2 blinks) - 994 - Setup - 00036 - <button to use for TVOL> - Should get 2 blinks
Aux - Setup (2 blinks) - 994 - Setup - 00101 - <button to use for TSHD> - Should get 2 blinks
Then set the volume control on the remote and other settings according to the Remote's manual.
ENJOY!! Hope this helps someone...
Nov 14, 2010 | Vizio High Definition Sound Bar
Lost a tv remote in a fire. Bought a universal remote but cannot fine a code to program it.
read the directions at the part where it says manually program, you have to do certian functions then push the channel up and down until tv responds then its programmed, this is actually finding the code as you go, instructions will explain it all because ech universal is just a little diff in its manual process.
Dec 18, 2009 | Vizio L32 32 in. LCD HDTV
Code for vizio tv
If you mean the code for this brand that you need to program a remote control, you will need to check the instructions that came with the remote. Device codes are assigned by the remote manufacturer, not by the TV maker. The code for a brand of TV won't always be the same from one remote to another. If you've lost your instructions, you can usually find them at the manufacturer's website, or get the information from your cable company if it's the cable box remote.
Mar 20, 2009 | Vizio L32 32 in. LCD HDTV
RCA RCR 451 universal remote codes
1204/1207, now help me, how do I imput codes, I lost mine
Dec 15, 2008 | RCA Universal Remote Control
No codes
I have found several places that claim Vizio TV's use the same codes as Samsung, so you might try those. You could also try the remote control's code search feature. In case you have lost your intructions, here is the link to Sentry's site where you can download a copy:
http://www.sentryindustries.com/pdf/instructions/RMC10_Instructions.pdf
Dec 14, 2008 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
