Question about Plumbing
I have a KWC Systema kitchen faucet that drips or a short time after use. Is this normal for this faucet?
  • 21 Answers
SOURCE: My Moen Caldwell 87888 continues to run and drip
This sounds like there might be some dust in the cartridge have you pulled the cartridge and looked for dust.
Posted on Jun 21, 2009
  • 17 Answers
SOURCE: Sticking of KWC DOMO model faucet.
I would definitely take it apart to find out what is causing it to bind, that is not normal. Make sure that you turn your water supply lines off under the sink, via angle/strait stops. From under the faucet there is one or two nuts fastening the faucet to the counter, they are usually screwed on just a little more than hand tight. The problem may not be fixable, so be prepared to replace the faucet.
Posted on Mar 19, 2010
motor1258
  • 6674 Answers
SOURCE: We have a Moen 87315C kitchen faucet and it is
If it's leaking at sprayer, and not the base where connected to hose, try this. Buy a bottle or jug of CLR. (calcium, lime, rust ) from hardware store, and pour enough in a bowl that will submerse sprayer in it. When you go to bed, or out for a few hours, turn off both taps (obviously) and relieve all pressure as well from sprayer. Now wrap an elastic around the handle of the sprayer so that lever is depressed, and submerse it in the bowl of CLR, and let it work overnight or at least for a few hours. Next Day, or Later, remove elastic from sprayer, and try it a few times and see if leak has stopped. Quite often you get calcium build up on internal washer/seal, and this will clean it off. If no CLR, you can try vinegar as well, but I find CLR better. If it appears better but not stopped completely, give it another treatment.
Posted on Apr 13, 2010
Just received the new part for the domo. My model is older and is chrome with black. I have removed the top screw and need to know what is the next step in taking apart the rest of the faucet so I can replace the new part # k.32.60.00
Thank you, Stuart
Posted on May 29, 2010
  • 67 Answers
SOURCE: dripping faucet
Very nice kitchen faucet. I like Price Pfister's products. To repair it you will need a phillips screwdriver to remove the handles and crescent wrench to remove the cartridges. If it is dripping then one of the faucet cartridges need to be replaced. Its best to replace both cartridges as inevitably the other one will start to leak after you've replaced the troublesome one. Your local hardware store or plumbing supply store should have a replacement cartridge for this model. Remove one of the cartridges and take it with you to ensure you get the correct part. There is an exploded diagram of your faucet on the Price Pfister site at that shows the part number for the cartridge. Good luck and let me know how it turns out.http://www.pricepfister.com/www/ImageAssets/mirror/model/kitchen/savannah/savf8h6-85/ex-036-01.pdf
Posted on Jul 26, 2010
New kwc domo leaking under (alot) sink
mixing chamber of the faucet may be cracked
Aug 14, 2014 | Plumbing
Sticking of KWC Suprimo faucet
My bathroom faucet handle (not same brand as yours) was so hard to turn that it pulled the base around with it on the vanity when I jerked it. I used an Allen wrench to take out one of the set screws holding the handle on, put the tiny straw of a WD40 can in the set screw hole, squirted WD40 inside the handle, replaced the setscrew, and worked the handle to and fro a few times to lubricate the inside. No more sticking!
Feb 22, 2014 | KWC 10.271.333.700 Suprimo Kitchen Faucets
Kwc kitchen faucet
Usually you need to use a hex key to unscrew.
Could you take a photo of the faucet and show us?
Feb 03, 2014 | Plumbing
Remove flow restrictor on KWC Faucet
We have a KWC 10.501.012.000 - Systema kitchen faucet and after installation the water pressure was much lower, even after adjusting the faucet's limiter screw to "minimum". We ultimately decided that the reduced flow was unusable and called back the plumber service. They sent out a different guy this time and he knew where to find and how to remove another of the faucet's built-in limiters (it has three, apparently).
I saved the removed water limiter parts. I hope this picture of them can you or anyone else with this same problem remove the limiter and get strong flowing water again...
Jul 02, 2012 | Dmm Plumbing
I have a KWC K24.41.61.000C06 and I live in a drought region. How can I limit the flow on the main faucet?
This faucet is designed to run full open and has no adjustments for lowering the flow. I would put something around the handle to keep the lever from opening completely maybe some pipe insulation or tape. Now you could get into the hose connection where the filter screen is and make a small washer type deal with a small hole in it to restrict the flow.
Feb 09, 2011 | Dmm KWC K.24.41.60.000C28 Gastro Kitchen...
KWC Domo single handle faucet is sticky...how do I fix that? Do I have to replace a cartridge?
Have the same issue. No one seems to have an answer, including KWC (except to buy a new $90.00 cartridge).
Nov 09, 2010 | Danze D403412 Melrose Single Handle...
Thank you, Stuart
May 11, 2010 | Delta Model 470: Signature Kitchen...
Mar 19, 2010 | Delta Model 470: Signature Kitchen...
KWC Domo faucet sprayer won't switch between spray and stream
Having installed and fixed kwc domo faucets for years I'd probably take the spray head off of the hose, then look into the bottom of the spray head and see if the check valve is still there. It probably is. I used to use a thin screwdriver to pry the check valve out out.It will come out. You need to work at it a bit but these hold back a lot of water pressure and catch any crud coming down the water lines.
TL
Mar 17, 2010 | Plumbing
Faucet installed 9/94 and still looks like new. But in past few days have begun seeing slow drip running down from one of the inner metal flexible hoses when faucet is on and for maybe 5-10 min after water...
Try tighten the hoses, if this don't work the seal in hose connectors may need replaced, very simple and cheap to replace. over time the hot water will wear down the seal it will go bad with pressure and water period. It's a good thing to change these all while you are there.
Jan 18, 2010 | Kohler K-12176-PB Fairfax Single Handle...
Plumbing Logo
144 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
