Where is the water valve fuse on a gw711 - Washing Machines
Were can I buy a draining hose for my washing machine in Hamilton.
any appliance place should have them, u can even try appliance repair places they keeps extras all the time
Oct 19, 2014 | Fisher and Paykel Washing Machines
Fisher & Paykel gw711 excellence keeps filling and overflowing
the clear pressure tube is blocked,
you need to blow air down the clear pressure tube hose.
Jan 30, 2013 | Fisher and Paykel GWL11 Top Load Washer
Will not send water through the water solenoid valve and blows fuses in the furnace
Is this a small 3 or 5 amp fuse it is blowing at the furance. My assumption it is. If this fuse is blowing right away, then this is a direct short. The solinoid valve needs to be replaced. The valve has a direct ground to casing short. Replace the valve and the furance will not blow fuses anymore.
Jan 24, 2011 | Aprilaire 550 Humidifier
Fisher & Paykel GWL15 washer stops during wash, beeps, and displays the 3rd, 6th, and 8th lights. The problem began intermittently about a week ago; however, powering off, changing the cycle, and...
Hi just read your posting.Now error code 37 is called pump block error.This means either your drain pump is jammed, or the drain pump is blocked or the pressure switch tube that regulates the water level is kinked or blocked or the motor controller is faulty.Does your machine always drain the water?Please reply and let me know if your machine is draining the water and we can track the fault down.Looking forward to your reply.
Sep 16, 2010 | Fisher Paykel EcoSmart GWL15
Top loader.recently had sesor replaced after machine went off balance. has gone off balance again, now water pumps for a second then stops and sarts then light sequence comes on.
David, exactly what combination of lights come on, top row. There are 8 leds 5 green, 2 orange, 1 red. Show the code with an X for led on & 0 for light off. EG:
0000X00X
This will indicate F9, sizing issue. (Code is actually read Right - L)
Also is model # GW711 What is product code. Both available on back panel or behind control panel.
Aug 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
We have a fisher and paykel gw711 washing machine that continues to fill with water while it is in the rinse and spin cycle
Hi Robbie just read your posting.Now just a couple of questions.Does the machine keep filling and flood?Can you manually select the amount of water for the wash --eg-- low, medium,or high?Or does the machine drain and fill at the same time?Please reply with additional information on the questions and I am sure I can rectify this fault for you.
Jul 16, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fuses keep blowing out
IF water is not going in the drum It sounds like the water valve coil has finally failled , It has been blowing fuses ,because the ccoil on the water valve was getting weak . change this water valve and you sohould be ok , but before doing so chaeck to see if you have the proper voltage going to this valve when It is calling to open ,if the power is there and the water is turned on the valve should be letting water in the machine . you can also take a ohm meater and check the valve for proper resistance . . If the machine is up in years I would change this valve . from the chack I mentioned earlier . hope this helps you
Nov 03, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Fisher & Paykel GW711 Washer
If you brought this machine new, then you should find a service manual under the display panel
You will need to remove the panel, Next to inlet valves you should find a maual in a plastic cover...
Apr 12, 2008 | Washing Machines
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
