Question about Vizio Televison & Video
I'm trying to get Xfinity remote to work on a Vizio TV how do I do that?
  • 17130 Answers
SOURCE: channel up/down button on remote for 37" vizio tv
It is possible that the pads are worn out or there is damage on the main board, possible carbon track failure . you might need to reform the tracks or use a remote control repair kit to retrack. Also in some cases the controller IC can be defective as it fails to detect the selected port.
Please try this link for some tips:
Posted on Oct 04, 2011
SD Tech
  • 14553 Answers
SOURCE: cable remote AND vizio tv remote will not turn on the tv
We will presume you do not have two bad remotes---the fact you can operate the set manually with the buttons there suggests a problem with the remote receiver====there is a tiny infrared receiver in the front of the set that receives the signals from the remote and sends them inside the set where the correct action is taken.
Make sure if you see it (usually small black area on frame of set) it is not blocked or dirty.
Failing that you may have a bad receiver for the remote---shop repair.
Posted on Mar 16, 2012
SD Tech
  • 14553 Answers
SOURCE: vizio vl370m remote control
If remotes have been ruled out the only way to test the remote infrared receiver is with the set apart/ and a schematic measure voltage at the receiver when the remote is used---most of the time since the part is rather small this is just replaced to see if it is or is not the problem; some receivers will fail where if the remote is held very close they work--always the receiver in that case.
Posted on Apr 12, 2012
  • 75017 Answers
SOURCE: I need code for my 46 inch Element TV so I can use Xfinity TV Digital Set Top Box
Just visit this site fore more details. Type in 'electronicshelponline' in your browsers' search box. This is an electronic equipments service help site, have more than 300 posts in it. A purely technical site. a blogspot site in English language. Try it. You might get details you want. Pull out older posts there.
Posted on Jun 21, 2012
SOURCE: nuvision tv remote codes for xfinity remote
NVU55FX10LS use 10690 Comcast / Xfinity SILVER Remote with RED enter button
Posted on Jul 20, 2013
What is the code for xfinity cable xr2 remote control?
Your XFINITY remote can be paired with XFINITY X1 TV boxes, allowing you to control the TV box even when it is placed out of sight, such as in an entertainment center or in another room (up to 50 feet away). XFINITY remotes can be identified by the model number on the back panel or within the battery compartment of the remote.
Note: Once your remote is successfully paired with a TV box, it will not control any other TV box until paired with the other TV box. XFINITY remotes can only be paired with one TV box at a time.
To Pair an XFINITY Remote Note: These instructions apply to XR2, XR5 and XR11 model remotes only.Make sure the remote batteries are installed and your TV and TV box are powered on.Set the TV input to the input connected to the TV box.Press the Setup button on your remote until the LED at the top changes from red to green.Press the xfinity button on the remote. The LED will begin flashing green. (Note: When pairing an XR2 or XR5 remote to a DTA, you may need to press the xfinity button up to five times).Follow the instructions by entering the three-digit, on-screen pairing code.
Once the on-screen pairing code is correctly entered, your remote is paired with the TV box. Note: If you do not see on-screen pairing instructions after pressing the xfinity button in step four, press the xfinity button again. You may need to press the xfinity button multiple times if there is more than one TV box in range.
how4474_072816_01-kmuj4sm5av3gyijxunj5wf5e-1-0.png NOTE THE BELOW CODES ARE FOR THE SAMSUNG SMART TV's ONLY
Type in the 4-digit or 5-digit code listed below using the number buttons. Additional codes may be found in the remote manual.
Most likely code
Others to try
11632, 10702, 10060, 11959, 10766, 11903, 11060, 10587, 10329, 10482, 10650, 10814, 10032, 10178, 10030, 10019, 11575, 11597, 10427, 10408, 10217, 10056, 11581 for more info on what device you are trying to pair it with the codes are available here > Just select the Remote and the device and continue and the page will display the most common codes for that Device you are trying to pair it with.
Apr 26, 2017 | Televison & Video
When connected to cable box will not let cable box change channels with tv on but with tv off cable box works fine
Cable box not changing channels on VIZIO TV - Comcast Help and ...
Apr 3, 2013 - I was able to connect my cable box and activate it without an issue. ... My problem lies in that the cable box will not change channels. Channel 8 comes in ..... I just unplugged the DTA ( you already did) and I let it sit for a while. No Audio with cable tv
Nov 15, 2012
remote not working cable box
Oct 13, 2012
Cable box not responding to remote (sporadic)
May 29, 2012
Remote doesn't want to work for the cable box
Oct 19, 2011
More results from
Connecting Cable Service, Satellite Service, or Antenna ...
Mar 10, 2015 - If you are connecting your cable or satellite box using an HDMI cordyou will ... You just need to change the input of your TV then scan for channels. ... Except the Vizio TV will not receive a channel that all the other TVs get.
Jan 11, 2016 | Televison & Video
My remote does not work
Remote Code for LCD Coby TV model TFTV2425 - Comcast Help and ...
Apr 14, 2011 - Remote Code for LCD Coby TV model TFTV2425 ... If your home entertainment device does not respond to the remote control after trying all of the codes listed for your ... I just changed to an hd box andcodes given by comcast did not work. Looked at my old remote notes and that is what I found and it works. Comcast DVR remote won't "select" an input from th...
May 26, 2011
Remote code for coby tvs
Feb 7, 2011
Comcast remote code for Coby tv/dvd
Mar 20, 2010
More results from
Coby tv remote doesn t work Questions & Answers - Fixya > Forum > Tags > tv remote doesn t work
Dec 15, 2015 | Coby TFDVD2274 22 in. LCD TV
Neeed to program xfinity remote to a Vizio HDTV
Are the batterys in the remote good? Have you tried programming it for another device you have?
Feb 16, 2015 | Vision HDV-42P2 Television
Vizio led tv ,xfinity remote doesnt control audio?
Set it up with an other code said for vizio. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts. Search the sites by type in the brand name to your device, in its search box. It will help you to find the document easily.
Sep 28, 2014 | Vizio Televison & Video
How do I hook up tivo,Vizio,Xfinity together?
You need a cable box from xfinity that does not have a DVR built in and then you need to see whether the Tivo can control it. You will need an ir blaster cable from here:
Then connect the Tivo to the cable box and the TiVo to the TV.
Nov 06, 2013 | Televison & Video
Nuvision tv remote codes for xfinity remote
Jun 16, 2012 | Televison & Video
No Signal
Reboot ur DirectTv box.By unplug,replug it and hour later to let the box upgrade it solfware.Go to ur tv menu setup rescan it again for all the channels.It should work now.
Mar 14, 2010 | Vizio VO47L 47 in. LCD TV
Televison & Video Logo
29 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
