Question about Dryers
Good evening I have a ceiling fan remote programmed for ceiling fan two, but remote one is missing is there anyway to reprogram the fan to the remote since the remote has no programmable keys?
  • 51 Answers
SOURCE: Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Posted on Jul 25, 2007
  • 8 Answers
SOURCE: Program codes for tv and satelite.
https://fjallfoss.fcc.gov/prod/oet/forms/blobs/retrieve.cgi?attachment_id=305485&native_or_pdf=pdf
The manual
Posted on May 25, 2008
  • 2841 Answers
SOURCE: remote control will not turn on/off fan or light.
The transmitter is the remote. The receiver is located inside the fan mounting bracket next to the ceiling. If you replace it make sure to set the dip settings on the new receiver exactly as they are on the old one. Wire the new receiver exactly as the old one is wired if it was working before.
Posted on Nov 07, 2009
SOURCE: I NEED CODES TO MY WIRLESS CEILING FAN REMOTE
What codes? There are 4 dip switches (see DIP switch wikipedia) inside the remote control and 4 inside the sensor that is inside the fan. They have to be in the same position. If you don't feel like messing with the one inside the fan, keep changing the ones inside the remote. U= Up, D = Down
U-U-U-U, U-U-U-D, U-U-D-U, U-D-U-U, D-U-U-U, U-U-D-D, U-D-U-D, ... D-D-D-D (*There are 16 possible arrangements*) On e of these arrangements will work (has to work) if the remote components are not damaged.
Posted on Dec 22, 2009
  • 3 Answers
SOURCE: remote missing on old dominator garage door opener
This is the most complicated way I know of coding a remote and I am a tech. who does this all the time.
Turn power off. Wait 3 sec's & turn back on. Quickly press program button on back of box twice. Lights will flash, bottom light will stay on. Press program button twice, & No. 3 light will start flashing. Press and hold your remote button until light stops flashing. Code will be accepted.
Posted on Feb 08, 2010
My harbor breeze ceiling fan remote has dip switches inside, but no reset or program switch. How do I attempt to reprogram?
The dip switches in the remote must match the dip switches it the receiver inside the fan motor. You can set them anyway you like as long as both are the same.
Sep 26, 2015 | Dryers
Remote for my hamton bay ceiling fan 70 inch model DL-4109S-01 won't work. How can I get it to work?
first off see if the remote is working
if it is a point in the fan direction is is probably infred operation. to check turn on the camera of your mobile phone and point the remote at the lens
if it is working then a white light will appear on the screen of the phone when you press on the remote on button and disappear when the off button is pressed
if that works then it will be in the receiver in the fan
Sep 05, 2015 | Hampton Bay Dryers
Harbor breeze fan remote unit does not allow the ceiling cap to be replaced
That's a cheap store brand fan. I won't even install one anymore because they're missing parts half the time & they don't give good air flow. If you have the receiver all the way in the hanging bracket, the canapy cover should fit. Is the electricial box even with the ceiling or is it up higher?
Mar 15, 2014 | Dryers
Need to program Hampton Bay Ceiling fan remote control CHO88T7030T, HELP!
Change the battery. This is the first step when troubleshooting a ceiling fan remote. The easiest fix to any remote control problem begins with battery replacement. A 9-volt battery is needed to operate all Hampton Bay ceiling fan remotes.
Check the light switch used for the ceiling fan. The light switch found on the wall must be in the "on" position. This allows the ceiling fan to be operated by remote control
Re-program your remote. If battery replacement fails to get your remote working again, try to reprogram the remote. Open the battery cover you will see 4 dip switches. These switches must be set to the same position as the receiver on the fan. Use the screw driver to move the dip switches either up or down.
Follow the previous step to change the frequency if the ceiling fan is randomly turning on or off. Other electronic devices such as garage door openers can interfere with the ceiling fans receiver, causing it to randomly turn on or off.
Sep 10, 2011 | Televison & Video
I have a Hampton Bay Remote Ceiling Fan but Remote is missing. Where can I get one.
1. try ebay
2. stores sell universal remotes that can work most ceiling fans.
Apr 13, 2011 | Universal Remote Control Hampton Bay...
Remote for Ceiling Fan (Model: AC 552 AL) no longer works. I changed out batteries and still does not work
Maybe it needs to be reprogrammed after new batteries. What is the model number on the remote, please?
Jul 12, 2010 | Hunter 52" Ceiling Fan With Light And...
I have a quoram 73000 remote that the previous owner of this home uses to control a ceiling fan as well as the canned dimmer lights above the fan.I hink I just need to reprogram the remote because it...
I will assume you checked the batteries? These units have sequence matched signals. The only way to confirm neither has changed is to check both. It works like a garage door opener. 4 pins must match each other. On the remote, this is usually found where the battery goes. You will see the 4 pins. Up or down is the only option for each pin. That was easy. The hard part is getting to the receiver in the fan. At the ceiling there is a cover for the wires. 2 to 4 screws hold it in place. Remove the cover and you will see the receiver unit...probably stuffed in there very tight. Carefully remove the receiver to expose the pins. Check that they match the remote sequence. If they do not match correct to match and all should be good. If they match and the battereis are fresh, the remote or the receiver went bad. In which case you can get a universal, even by Hunter Fans at Home Depot or Lowes will work. Color match the wires if you are a DIY'r. Feedback is appreciated if this helped or not.
Jun 30, 2010 | Quorum 73000 Remote Control
Power went out and now ceiling fan won't work
Before you try all of that try the on/off switch, I tried holding down the light switch on the remote and turning the on/off back and forth several times and then the light came on... it is very tricky, but I knew my battery was good, and the fan worked before the power went out and the dip switches did not need reset or changed. I tried many different combinations so I am not sure what tripped it up, but try that before changing anything or pulling the fan cover off. Best of Luck
Sep 07, 2009 | Hampton Bay Dryers
Reprograming Ceiling fan remotes
You need to find the dip switches or jumper blocks on posts on the remote and on the fan. As for the receiver, usually they are in a separate unit that slides into the hanger bracket that attaches to the ceiling inside the decorative canopy cover, otherwise they should be visible if you are looking down onto the top of the motor without having to open any kind of access. And as for the remote, you should be able to access them through the battery compartment. just make sure the codes match.
Sep 05, 2009 | Hunter 52" Ceiling Fan With Light And...
Minka aire concept II flushmount
try buying a wall mount remote. it must be made to be able to be programed
Jun 13, 2008 | Minka Concept II Flush 44 Ceiling Fan by...
Dryers Logo
24 people viewed this question
Top Dryers Experts
