Question about Stoves Ovens
I have a kitchen aid range model kgst307hbs6, the oven and broiler will not light, I have replaced the gas valve/ regulator assembly. I am getting 3.0 v on the broiler side, and 2.4 v on the oven side
The gas valve has a rating of 3.03-3.3 volts, are both of my igniters bad? thanks, steve
  • 725 Answers
SOURCE: oven will not light
If your husband is handy and it is Igniter.. this is a job he can do. remove the burner cover and them the burner baffle and unscrew the igniter cover and pull the igniter out remove the wire nuts and replace with igniter part number WB02X9154 let me know how it works out for you.
Posted on Nov 18, 2007
  • 78 Answers
SOURCE: Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
Posted on Dec 10, 2008
SOURCE: hotpoint oven glowbar not working
My oven glowbar stopped working christmas morning. Yesterday we bought a whirlpool brand (igntr-oven #4342528) because it is twenty something dollars cheaper then GE. My husband installed it today. The only difference is you have to splice the wires (it comes with everthing you need) The first time he put it in it did not work because he had the wires backwards. He switched the wires and now its working fine.
My oven is two years old also.
Posted on Dec 27, 2008
  • 3361 Answers
SOURCE: Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Posted on Feb 25, 2009
SOURCE: Maytag gas oven slow to ignite,makes poof sound
sounds like the safety valve gas regulator (its where the main gas line attaches in the bottom back)
Posted on Mar 28, 2009
My broil HAS NEVER WORKED. top element does not heat up even after the control panel was changed.
Search Results
    Gas Oven Broilers - Do Any Really Work? - Chowhound
    Nov 8, 2013 - but do want to say that I broil in my Breville Smart Oven and it's great.... I have never had a gas stove in any home I've ever lived in, always ...
    Kitchen Basics: How To Use Your Broiler ' The Kitchn
    Apartment Therapy's The KitchnMar 31, 2010 - Every oven that we've ever come across has some kind of broiler - it's the same device as heats your oven for baking or roasting, after all.
    I have a Kenmore electric range; model 920/9285*. The ... > Manage My Life > Questions
    The oven and broiler on my stove won't heat up. Was working ... Having a Oven not working can be rather disappointing as well quite a concern. I have taken the ...
    Top or Bottom Broiler? [Archive] - Community > ... > Food > Popular Threads Archive
    Sep 3, 2002 - 24 posts - ‎7 authors
Jan 27, 2016 | Stoves Ovens
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
May 26, 2010 | Ovens
My gas oven turns on and starts to heat up but will not stay on. ANy ideas?
your oven gas pressure regulator valve needs to be replaced. it is a brass colored metal can attached to the oven broiler burner. you can get it at:
May 18, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
DCS gas oven and broiler that pulses
This sounds a lot like a defective pressure regulator. If you do not have one externally connected, then the internal regulator is faulty. If internal, it shouldn't be too difficult to DIY. Just make sure the pressure rating is the same as the one that has failed.
Mar 24, 2010 | New World G60m Gas Single Oven
When I heat up the oven i get a strong smell of gas and it fills
Ok, your mixture is to rich at this time. you will need to access the gas pressure regulator and adjust the air to fuel mixture. add a bit more air and back off of the fuel a bit. this will correct this issue.
depending on the model, this may or may not be an option so, if you cant access the regulator and the burner assembly is not accessible as well, i recommend calling the local gas utility service tech to preform this adjustment. This rich mixture is very dangerous for you and your family and i suggest that this be corrected asap for you safety.
Please rate and god bless:)
May 13, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Mar 25, 2009 | Maytag CWG3100A Gas Single Oven
Broiler works, as do burners. The oven will not come on. Gas whirlpool range 2003 year. Model SF367LEKB
jdelvecchio5Does the igniter (glow bar) come on whenever the bake function is selected.?
If the glow bar does not come on the safety valve will not open - no bake burner. check the electrical harness first then Try changing the igniter (glow bar first) before changing the safety valve/regulator.
Dec 02, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Sf195lehz5 free standing gas oven,
Check both gas valve solonoids for 216 ohms [blue broiler wire to the orange common and red oven wire to orange common] both must be ok.
Check oven temp sensor for 1080 ohms.
If above are ok then the problem is either the spark module or the control board.
Since the gas valve was not opening and there was not ignitor sound I replaced the spark module for about $90. You have a 50-50 chance of being right.
My range is relitively new and I'm haveing an oven light problem which I traced to the control board so I may replaced this board to for about $200.
Oct 05, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool oven model sf315peew Super cap 465
try the broiler if it lights then replace the oven ignighter in the bottom under the bottom plate of the oven cavity reply if the broiler doesn't light
Jan 30, 2008 | Ovens
Open Questions:
Ovens Logo
32 people viewed this question
Top Stoves Ovens Experts
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
