Question about GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator
Amana refridgerator model arb1917csl bottom freezer unit the freezer froze up two days ago, we thought the door had not been shut good and just frosted over. now everything is melted, refridgerator and freezer are not cooling or freezing at all
    President:
  • 744 Answers
Hello, with the limited information I have on this there could be one of a couple of problems here, First and most common is the defrost timer. When the defrost timer activates the defrost system the compressor shuts down for about 15 minutes..does it's thing and then starts the compressor up again to continue the cooling proccess. When the defrost timer gets stuck on defrost cycle it shut's the compressor off and won't start again. the defrost timer is located in the console where the cold control/light is located inside the fridge. your going to need to find it. once you find the defrost timer there is a small dial on the front that will allow you to advance it. Advance the timer and see if the compressor kicks in, if after a few minutes the compressor kicks in replace the timer. the other problem would be with the compressor and that you should leave to a proffesional...please feel free to comment again if you have any other questions, Good Luck!!!! mike
Posted on Jul 21, 2009
How to get my Amana fridge to stop leaking water from the freezer to the refridgerator?
These Amanda units appear prone to this problem. The fix is use of a drain kit. Your drainage spout is freezing over. The regular spillage is related to the defrost cycle of the fridge. Here is a page listing the kit:
Refrigerator Parts
Dec 09, 2017 | Amana ATB2135HR Top Freezer Refrigerator
Model # bx2255w Amana Refridgerator bottom freezer works but refridge isn't cooling any more. Is it time to retire our approx 15 year old fridge or is there an easy fix?
If you have high humidity or the door gets opened a lot, the evaporator coil may need a good defrosting. There are defrosting devices in the unit like the timer, heating coils, thermostats that could be bad. There should also be a small fan in the freezer that transfers the air to the refrigerator section. If that's not spinning only the freezer will work.
If you find the fan and it's working you can do a thorough manual defrost by removing the food, unplugging the unit and letting it set for a day with the doors wide open. Have some big towels handy :)
After a day, plug it in and see what it does (don't add food, yet). If it cools down then you will know that the compressor is still good and it's worthwhile to fix.
Easy fixes: Timer and fan.
Moderate fix (cheap part - more labor) - Defrost thermosat
Pain in the **** fix: Defrost heaters.
Ed
May 22, 2011 | Amana Refrigerators
Used armana bottom freezer fridge, not cooling?
yes leave it on for another 24 hours its probably the settings on the refridgerator
Jul 13, 2010 | Amana ARB2517CC / ARB2517CB / ARB2517CW...
We have a amana BX21VW bottom freezer refridgerator. The fan behind the back plate in the freezer section makes a very loud vibrating noise. If we put pressure on it it is quite. How can we fix it?
Good day,
There is no repair possible. You could try changing the blade only, but the best repair is replacing the motor and blade as a unit.
However, it is your choice on the blade only approach.
Feb 25, 2010 | Amana Refrigerators
Amana Freezer DeepFreeze AFU2067BW 19.6 Cu. Ft. ice in bottom
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Feb 20, 2010 | Amana Freezer DeepFreeze AFU2067BW 19.6...
Refridgerator door sags
Its a two person job. One person has to looses up the two hidges holding the door just slightly while the other person holds the door in place. Once in place tighten the screw/bolts for the hidges back up and check. If not aligned, redo it again until it is aligned and seals properly..
Good Luck!
Sep 15, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Amana Refridgerator Freezer, French Doors
Most side-by-sides have a length of hose at the bottom of the freezer that send the water to the ice maker and water dispenser. take the back off so you can see this hose, there may be a kink in it, or a clog.
May 30, 2008 | Amana ACD2232HR Side by Side Refrigerator
GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator Logo
312 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
