Question about Cameras
The on and of button won t turn on put in new batteries and nothing happens
poolseman
  • 206 Answers
SOURCE: nothing works
Remove batteries and clean contacts both inside the battery chamber and on the chamber lid/cover.( use something slightly abrasive ). If this doesnt help replace fire fuse situated on the main pc board ( underneeth rear cover ).
Posted on Aug 27, 2007
SOURCE: Aiptek won't turn on
Try taking the battery out and putting it back in. I don't know why, but it worked for me. Good luck!
Posted on Jan 16, 2009
BillB-SA
  • 2761 Answers
SOURCE: put in new batteris and nothing happens. They are
First, make sure that the "new" batteries have a full charge. If you don't have a meter to check them with, try using them to power something else. Also, if using rechargeable batteries, make sure that they are the correct type for the camera. NiCd batteries will not work well in a camera that calls for Ni-MH batteries.
If the batteries are OK, your problem may be due to corrosion on the battery connections inside the camera. Remove the batteries and wipe the camera contacts with a clean soft cloth (heavy corrosion may require cleaning with a fine wire brush, steel wool, or fine sandpaper). Remove any specks that may have fallen into the battery compartment during cleaning, then clean and reinstall the batteries.
The above clears about 90% of power-up problems, and I hope it works for you. If not, your camera may have a more serious problem that requires repair by a camera shop or the manufacturer.
Posted on Aug 23, 2009
rickyrt441
  • 4399 Answers
SOURCE: Put new battery in a
Well you don't have no power from the battery. If it is new, make sure that is charged. Make sure all both terminals are cleaned and on tight. If the ends are loose, they will need put back on. You may need new ones. Check all wires to the charging system. Make sure the ground on the battery is correctly grounded. Make sure all wires are correctly installed and all grounds are grounded. Your problem is you have no connection with the battery. Start with the terminals. Replace them if necessary. Clean the post and terminals. Make sure you have a good charge. When you touch the terminal and battery post, it should spark. If so, make sure they are correct. If it doesn't spark, check your wires for damage or loose connections.
Posted on Mar 04, 2011
SOURCE: Bike won't start, won't turn over, lights
Changed the FOB battery in mine andf it was the problem, try it!!!
Posted on Jan 23, 2012
Brand new wildgame innovations model m6b does not work
Sounds like it's broken. If it's new, I'd return it if you can. Even if it's something you can get past on your own it may indicate other problems and you don't want to risk it going out when you need it.
Nov 16, 2014 | Cameras
New unlocked cell phone won't turn on
Hey, same problem. Push and hold the hangup button. It will prompt to insert sim , but I only have one. The phone works. The website and the manual are useless. Just gotta play with it, I guess.
Mar 06, 2013 | Cell Phones
Pentax optio w80 waterproof digital camera won't turn on
I had the same problem. I checked the voltage first to ensure it was greater than 3.7V (some batteries were not). I left the door open and pushed the battery down and pressed the button and it powered up. Seems to be a problem with the contacts. I put about 6 layers of duct tape on top of the battery to cause the door to push it down and now it works.
Feb 21, 2013 | Avianne & Co Pentax Optio W80 Waterproof...
'Kodak AF 3x Optical Aspheric Lens' won't turn on ...
Hello Bernard, There seems to be a lot of this going around !! Possible bad battery contacts or a faulty main switch. you will need to have it looked at by a tech.
Best Regards, Russell
Dec 24, 2012 | Kodak Easyshare C813 Digital Camera
Won't work or re-set
i remember holding a paperclip in the reset button for about 30secs it should introduce its self then
Jan 04, 2012 | Tiger Electronics FURBY Interactive...
Polaroid A500 digital camera pressed ON button, nothing happened with new AA batteries and SD card
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Nov 25, 2011 | Polaroid Cameras
1982 Suzuki GS 650GL won't start. I've purchased a
Well the good news is the click indicates the switch is working, when you press the switch the 2poles on the solenoide are joined together alowing the current to the starter,bridge the wires at the solenoide this should put power directly to the starter you wont need to press the start switch, if the engine does not turn over check the connections to both the battery and starter motor,
Jul 25, 2011 | 1982 Suzuki Gs 550 L
Reset button ?
Sometimes there is a reset button and sometimes you have to reset it through a menu. Of course, if it won't turn on, then you can't get to the menus.
May I ask, what is you Toshiba camcorder's model #?
Jul 31, 2010 | Toshiba Video Cameras
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
