Question about Winter Sports
Broken cable on my shock adjuster on my 2007 yamaha apex
How to replace it
2 Suggested Answers
sscullys
  • 984 Answers
SOURCE: Does my 2007 f 150 have a shock sensor that will
Unless you got a Ford Gold remote start, Remote keyless entry & alarm installed, the truck does not have a shock sensor.
Ford offers an OEM unit, which is ( was ? ) the CodeAlarm units.
If the RKE ( Remote Keyless Entry ) fob only has the lock, unlock and horn button, then you have only the factory RKE, no shock sensor. If the RKE fob has the key on it ( for the start ) then it might have an alarm ( this could be the silver remote start & RKE, no alarm ).
Posted on Jan 04, 2010
Yellow light keeps comming on on my 2007 yamaha apex
Hi, Charles it should be noted that the reasons your check engine light constant or flashing, will or will not start, turns over or not conditions varies from the year, make, and model and you should always refer to your owners/service manual for proper diagnostic procedures. It should also be noted that any type of prior work or event IE: adding accessories, electrical curiosity/adventures, laying bike down/crashes, rainstorms/bike washings just before EFI light issues started can be significant hints/aids into tracking down the gremlin, also carry the appropriate jumper wire to access fault codes to reduce the risk of being stranded or towed, that being said the usual suspects are:
1. Faulty Fuel Pump, fuse or system relay switch.
2. Battery starting to fail due to old age/damage, perform a load test.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Faulty switches/sensors: run/off, ignition, clutch lever, neutral, side stand, tip over, fuel, and or their connections.
5. Broken wire or worn insulation exposing wire to a ground situation especially inside wire harness at tight bends around fairing brackets, under dash panels, under fuel tanks over cylinder heads etc. Many harnesses are open on the ends that will allow water to enter and accumulate at v-bends.
6. Check for generated fault codes.
Dielectric grease and contact cleaner are your best friends for wire/cable/harness connectors, look for corroded, broken, or loose pins/sockets.
For more information about your issue please visit the websites below. Good luck and have a nice day.
Yellow warning light comes on apex but nothing else
Check engine symbol Came on with yellow light
06 10 apex service pdf PDF Archive
OEM parts for Yamaha
Yamaha RX10J Owner Manual
Dec 20, 2016 | Yamaha Motorcycles
Yamaha r1 08 engine cuts out when gearing down
Hi, Anonymous and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Air/fuel mixture screw improperly adjusted.
10. Accelerator pump damaged or not working.
11. Water or dirt in the fuel system, carburetor or filter.
12. Restricted, blocked or kinked fuel line.
13. Fuel tank empty.
14. The gas cap is not venting properly or fuel tank venting system blocked.
15. A failed fuel pump, pressure regulator and or fuel injectors.
16. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
17. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you need please click on the links below. Good luck and have a nice day.
http://www.r1-forum.com/forums/105-07-08-r1-mechanical-help/337078-engine-cut-out.html
2007 2008 Yamaha R1 Stalling Problem Fix How to
http://www.lethaladrenalinrydaz.com/index.php/service-manuals/finish/3-service-manuals/6-2007-2008-yamaha-r1-service-manual/0
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Apr 20, 2014 | 2008 Yamaha YZF-R1
Wr250f 04 rear shock needs replacing, will a 07 rear shock fit
Hi, Anonymous after careful deliberation 4 out 5 Yamaha Gods give this one a thumbs up, but just to be on the safe side you should give your local dealer's parts/service department a call to confirm. For more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Specialized FSR XC rear shock replacements BikeRadar Forum
Adjust rear shock spring on MX bike with no special tools Yamaha example
YAMAHA WR250F Owner Service Manual
YAMAHA WR250R Owner Manual
Apr 07, 2014 | 2003 Yamaha WR 250 F
2007 Yamaha Royal Star Tour Deluxe how do you adjust the rear air shock
Hi, Jack for this scenario you will need your service/owners/ manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2006 venture air shocks
Yamaha 1300 Tourer Yamaha 1300 Tourer Fansite
http://vstar1300.pbworks.com/w/file/fetch/94628933/1300VStarServiceManual.pdf
http://www.starmotorcycles.com/assets/service/manuals/1998/lit-11626-11-18_140.pdf
Oct 26, 2013 | 2007 Yamaha Royal Star Tour Deluxe
2007 yamaha v star 1300 idle is to high and fuel mixture to rich
Hi, Brian you may have a stuck choke and the usual suspects are:
1. Throttle cables improperly adjusted, pinched or need lubrication.
2. Idle adjusting screw needs to be backed off.
4. Air fuel mixture adjusted too lean start with 2 full turns.
5. Intake system air leak.
6. Fast idle choke ramp is not releasing.
7. Broken throttle return spring.
8. Damaged diaphragm or slide.
9. Faulty MAP, TPS, ATS, O2, sensors or wiring/connector
10. Multi carburetors not in sync.
Running rich
Erratic idle so confused Yamaha Star Forum
YAMAHA XVS1300A Owner Manual
Yamaha XVS1300A 2007 Service Manual
Oct 27, 2012 | 2007 Yamaha V Star 1300 Tourer
I have a 2007 vstar tourer and it is sputtering..puting out black smoke and stalls out
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a "LOAD" test if necessary.
6. Failed ignition coil, stator, magneto, points/condenser ignition/electronic module.
14. Fuel tank contaminated with ethanol sludge.
15. The gas cap is not venting properly or fuel tank venting system blocked.
For more information about your issue and valuable "FREE" downloads that you need please click on the blue links below. Good luck and have a wonderful day.
http://www.starbikeforums.com/forums/49-v-star/9084-v-star-acting-very-sluggish-sputtering.html
http://pnwriders.com/threads/need-help-bike-boggs-down-and-dies.173024
Yamaha 2007 XVS1300AW Owner Manual
May 21, 2012 | 2007 Yamaha V Star 1300 Tourer
I have a 07 Yamaha R1 and it shuts off when I'm riding. Ive changed the Ecu, the fuel pump, tilt sensor, new battery... I get codes 33,34,35,36 ignition coils. Bike had to sit for about 20- 30...
Hi, Tom and the usual suspects are:
Engine Cutting Out While Riding
engine cut out and other problems
Yamaha R1 YZFR1 2007 2008 Service Repair Manual Download Download Manuals...
May 28, 2011 | 2007 Yamaha YZF-R1
How do you adjust the rear spring on a 2007 v star classic 650
Hi, Wainscottbre for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Star rear shock Preload adjustment 650CCND COM
How To Adjust Your Rear Shock On 650 Star
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
http://www.starmotorcycles.com/assets/service/manuals/2003/LIT-11626-16-05_22.pdf
Aug 25, 2010 | 2007 Yamaha V Star Classic
Sticky throttle cabel
idle cable out of adjustment and or throttle cable needs adjusting also and they always need to be lubed at 5000 miles adjust throttle cable with wheel striaght forward idle cable to all the way right lock and 2-3mm free play on throttle grip
Mar 03, 2010 | 2007 Yamaha V Star Custom
Winter Sports Logo
91 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
