I'm trying to take apart a Duracraft CZ2200 portable heater and am having trouble getting the case apart as I can't get the top off. Any suggestions?
3 Suggested Answers
protek480
  • 1723 Answers
SOURCE: both togggle switches are broken
Go to the hardware store and match them up, they have toggle switch. Get the heavy duty 20 amp switch.
Posted on Oct 03, 2009
SOURCE: need the switch for the duracraft CZ600 heater
Did you find a switch for this? I have the same problem.
Posted on Jan 03, 2010
Hi, we have a Duracraft Commercial Grade High Velocity fan. When we turn it on it just hums, fixable? thanks, Nancy
Mine does the same when I try to start it on low. If I start it on hi after it gets going I then can turn it to low and works great. Hope this helps.Also you need to take it apart once a year , remove blades, take it outside and air blow the motor out .
Sep 01, 2011 | Duracraft DS-1600 Fan
Have a Duracraft DT-70. It is dirty and filled with cat hairs and grease on the blades. I can't figure out how to get it apart to clean it.
You will need to take this apart and use a good degeasing spray to remove off al the dirt. Use diesel/kerosene to wash well and clean it dry. Use a good paintt brush to wash off all dirt into the hidden areas.
Wipe dry finally to reset.
Sep 13, 2010 | Duracraft Dryers
Our duracraft portable fan is humming and not moving? what is the problem and can it be fixed?
Sounds like the armature needs to be cleaned. Dirt can build up on the ends of the motor shaft that operates the fan and where it is held in place, the dirt can actually stop the fan. I would spray both ends of the motor shaft with WD40 and rotate the fan by hand until it is free. This is the cheapest thing to do in order to try and get the fan running again. The problem may be worse than this, but it is a good place to start.
Sep 06, 2010 | Duracraft DB101 Floor / Box Fan
Hi I have a sharp portable AC unit model CVp 10lc works for 1hour
I have the same problem. I have only used my unit 3 times. It keeps "triping" and shuts off. Also, I smell a plastic burning smell and the plug gets very hot.
Apr 02, 2010 | Sharp CV-P09FX Air Conditioner
Humidifier fan blades stopped turning
Sounds like the brush is completely gone. You might be able to replace just the brush.
Good luck.
Mai
Apr 11, 2017 | Duracraft DCM200 2 Gallon Humidifier
I received a Duracraft model CZ-600 oil Heater. I don't know
I'm in the same boat..are we the only ones who have one?
Nov 22, 2009 | Duracraft DY-012 Tower Fan
Need the switch for the duracraft CZ600 heater
Oct 09, 2009 | Heating & Cooling
Both togggle switches are broken
Oct 03, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
