Question about Refrigerators
Frigidaire side by side refridge
The panel between the freezer door and the refrige door is very hot to the touch. freezer is working and the refridge is cooling fine so far. why is it so hot to the touch between the doors on that panel?
  • 213 Answers
Pull the kick plate off under the doors. if you look in behind the kick plate youll see alot of dust build up. this area needs to be cleaned once a year to keep air flowing properly over the condenser coils. if the dust build up is minimal then remove back panel of refrigerator and make sure the fan is running behind the refrigerator. if not, or if running real slow replace the fan motor. the heat is the because the condenser is getting too hot. it needs to be fix or the compressor life will be greatly shortend
Posted on Nov 20, 2007
Whirlpool refrige side by side doors refridge not cooling frezzer works fine when freezer door opens cool air goes into refrige colse freezer door air stops
The air return is clogged or obstructed. At the bottom part of the unit, left side wall of the refer section is a port, this is the air return and you will need to make sure to check this and clear all obstruction. If its ice, it will need to be removed. DON'T USE A KNIFE OR AN ICE PICK!!! You can do more damage than needed to correct this problem. I use a steam machine but, you could use a blow dryer if you careful with the heat as it can melt plastic. If you can unplug the unit during this cleaning process. If this is too difficult, unplug unit and leave the doors open to dray out for 24 hours or so, this will fix the problem you have also. Good luck
Mar 07, 2015 | Whirlpool Refrigerators
it should not be the compressor as the bottom is only not cooling.
Jun 23, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
GE Profile TFX22PR side by side. Freezer works fine, but Refridge side is not holding cold temp and the door gasket is quite warm to the touch.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Sep 02, 2010 | Refrigerators
Side by side refridge was dirty and I cleaned
I would pull the refrig out , and remove the back panel , covering the compressor and fan motor . Check to see if the fan is working . Fan not working , causes the divider panel , to get very hot . Also , fan not working , causes the compressor to over heat and cut off on the overload .
Sep 29, 2009 | GE Refrigerators
Swan fridge freezer-freezer dones,nt get down to temperature but fridge is working fine.if you turn up the thermostat the fridge acts like a freezer
There is a damper door that opens and closes when you move the thermostat. I would bet the door is functioning incorrectly. All the cooling of a refrig comes from the freezer and gets blown into the refrigerator compartment. If that damper door is open too far it will have constant freezer air blowing in....and if it's not open enough obviously the refrig will not get cool. Look at the upper left corner of your refrigerator, the center rear wall of the refrig or just feel around for a vent will cool air blowing out of it......Then take it apart and see if anything is broken.
Sep 09, 2009 | Refrigerators
Mod# GS6SHEXNLOO Ser# GF827090B Strip between side by side doors is hot to touch, not luke warm. Fan in back is working but not cooling.
The fan which cools the compressor ? You cannot hear the fan that cools the compressor . Have to visually look , If you hear a fan , it has to be the freezer fan you are hearing .Remove the rear panel behind refrig to see compressor fan .
Aug 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool side by side (106.56692501). Refrig was not cooling but freezer is. Freezer is slowly heating up though. Unit is still running. It just isn't blowing air into the refrigerator.
You have ice in freezer fins. You need to remove back panel inside of freezer, melt all the ice replace panel, plug refridge back in. The ice causes bad airflow to the refridge side, causing to heat up.
Jul 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Black strip on front of wall between frig and freezer really hot
not supposed to be hot to touch, try pulling out refrig and vaccuming the coils, your probably FULL of dust and debris, also remove the kickplate from front and clean under there as well
Sep 29, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Compressor constantly on too hot to touch
hi have you cleaned the matrix best done by blowing with air but a soft brush can work,make sure that all the cooling vanes are clear
hope this helps ian
Jul 21, 2008 | LG LRTN22324 Top Freezer Refrigerator
Kitchenaid ksrj25cnst refrig does not cool but freezer is fine
sounds like you have a defrosting iss\ue here, ther is aduct on the left sideof refig wall perhaps 3/4 the way down usually behind one of the crispers its frozen over with ice not allpwing fresh food air to properly circulate, l;ook to the bottom of your freezer on the back wall is there ice on the panel?? if so your not deforsting properly there satech sheet underthe kickplate showing basic wiring and trouble shoooting guide as well
Apr 06, 2008 | KitchenAid KSRD22FKBT / KSRD22FKWH /...
Refrigerators Logo
287 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
