Question about Garden
Auger handle won't ret urn to the off position. This on a Troy-built 2860
2 Suggested Answers
SOURCE: I have a Troy Built Storm 5024 the auger is not
I had the same issue. Check the gear box where the drive shaft meets the auger. My problem was the worm gear was missing 3=4 teeth in that assembly
Posted on Nov 01, 2011
I just replaced the auger belt and the auger cable has no tension. What do I do to fix it?
Here's some silly questions: Did you put the belt on the correct side of the Tensioner?
Is it the correct sized belt?
Is there a spring on the cable for the auger that can be lifted up the cable to expose the adjustment nut ?
Feb 08, 2016 | Troy-Bilt Troy Bilt Storm 3090XP Snow...
Not getting spark troy bilt snow blower model 7524
1st disconnect the auger /drive safety kill switch wire , see if it starts ? no? then it's most likely a bad ign modual or ign coil yes? then look at auger/drive control handle , i bet the spring broke and its not moving all the way up to disengauge the auger or drive
reconnect safety wire before using machine
Feb 23, 2015 | Garden
Auger won't stop
Open up plastic cover over belts.There is a pulley that moves against belt to engage front auger.There is a spring that hold it in the off position and when you pull the handle it moves that pulley.Sounds like spring broke or slipped off.
Mar 23, 2014 | Troy-Bilt 179cc 24-in Two-Stage Gas Snow...
Auger
Hi Brenda,
This machine makes use of two levers on the handle. The right controls the drive and the left controls the auger. When both are released, the drive wheels and the auger should stop. The impeller (the part inside that pushes snow up and out of the chute) will run as long as the motor is running and not controlled by the levers.
You said the auger continues to spin even when the lever is released. Both levers are connected by a flexible, thin, steel cable that extends down to a "wheel" or pulley assembly that is held in place by two hex nut bolts to the rear (operator position) corners of the machine. The steel cable should be ON the wheel - not hanging in free air and not wedged between the pulley and pulley support. Loosening the bolts and adjusting the pulley UPWARD should reduce tension / provide SLACK required to disengage the auger when the lever is released (adjust for a *small* amount of slack only). Positioning the pulley DOWNWARD increases tension that reduces the amount travel the lever needs to ENGAGE the auger. The pulley assembly position needs to be adjusted so that when the lever is released, the auger shuts off, and when squeezed, the auger turns on. These same adjustment procedures can be used for the DRIVE lever control, too.
If you are unable to adjust the cable so that there is a little slack, then there is a problem with the cable at the other end - inside the machine. It will require someone who is mechanically inclined - or snow blower serviceman to adjust / repair this for you if you lack the tools and understanding to do the work yourself. It is not likely to be an expensive repair, however. You should ask for an estimate or be given the opportunity to authorize repairs before they are started.
I hope this helps and good luck!
Noma auger wont stop spinning when disengaged
Sounds like either the auger belt is jammed to tight or handle mechanism to engage/disengage is stuck in on position. I would remove belt cover to inspect auger belt and pulley first, then remove bottom cover and inspect auger engage apparatus. I think once you inspect the problem will be self explanatory. Good luck!
Feb 18, 2014 | Garden
I have a Troy Built Storm 5024 the auger is not rotating. I check the shearpins and they are fine, I replace the auger belt still nothing. The impeller is spinning. What am i missing?
Feb 01, 2011 | Troy Bilt 5.5hp Self Propelled Mower
I have a new Troy Bilt Snowblower. My father ran over a large extension cord while blowing snow, which in turned wrapped the cord around the auger shaft ends. I can now only get one side of the auger to...
Your snowblower has 4 shear pins keeping the front auger safe. Use the manual to locate them if you are unsure where they are and how to change them. Since your snowblower is new I am going to assume you have the manual.
Your snowblower came with 2 spare shearpins. Check up by the handles and see if they are still there. If you don''t have them go to your local Lowes, Sears, or MTD repair shop to get new ones. DO NOT USE STANDARD BOLTS!
The drive shaft coming out of the gear box is one, solid piece all the way across the snowthrower so if one side is turning there is a 95% chance it's the shear pins.
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Jan 11, 2011 | Troy Bilt 5.5hp Self Propelled Mower
I have a Troy bilt Storm 9528 snow blower (about 3 years old). This year I am having trouble with the snow discharging. It doesn't seem to take much snow jam it up. At times the auger barely turns when I...
adjust the auger cable so its tight, it most likely got loose. The adjustment is on the back of the machine theres 2 screws just make the auger cable tighter. this should solve your problem
Dec 02, 2010 | Sport & Outdoor - Others
Troy built lawn tractors, belts
You may have a pully that is not spining freely. Or you may have a pully that is not positioned straight. Ariens had a problem with that. so your troy built may have the same.
Apr 19, 2010 | Garden
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
