Question about Garden
My western plow motor runs , but won't lift or turn and it has a isarmatic mark 111a pump on it
  • 55 Answers
SOURCE: 2006 snow bear plow,
Yes, Check where strap or chain is mounted to winch. It could be loose or have dirt or oil on it something to make it slip.On mine there's a brass piece that raps around the shaft, It got lose and dirty so I cleaned and tightened it. If you pull motor off winch to check gears [don't use gear] when reassembling it's too thick when it's cold. I used white spray lube. Hope it helps!
Posted on Jan 22, 2011
emissionwiz
  • 75077 Answers
SOURCE: curtis plow will not lift can hear pump running
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems related to factory installed systems not add on aftermarket systems.
This post can't be removed or moved, please re-post the question in the correct product category. Thanks
Posted on Oct 13, 2012
  • 9 Answers
SOURCE: I have a 93 chevy
If you have a Western Plow ISARMATIC pump, a very common problem is ice forming on your pump pickup screen. This will cause intermittent up/down AND left/right functions. Western recommends the fluid be changed annually and I agree. Here's what it looks like after dirt and moisture form on the pump screen. Thats an ice chunk below the screen that appears to be a hump in the case. Be sure to verify that the pump motor is actually spinning before you suspect the pump screen. b7cfa544-07c8-441e-a344-3d5d97b0b2b0.jpg
Posted on Jan 31, 2014
SOURCE: I can hear my fisher plow motor but the plow will not lift or angle
Check/replace under hood motor relay. Spend the extra $2 and get the fisher part. Do not even bother with NAPA junk.
Posted on Feb 02, 2015
  • 33294 Answers
SOURCE: I have a hydraulic Western Plow. I just purchased it from a guy that sells used plows for Western plow, and hooked it up. It will lift, lower and turn right. When it turn right, it goes up.
Take this issue up with the "guy (who) sells used plows for Western".
Posted on Dec 10, 2016
Western plow will not go left
There is a hydraulic block/valve. Replace it.
Jan 03, 2017 | Cars & Trucks
My western snow plow will not lift, it will turn left and right but will not lift ?
check for air in cylinder may have to bleed the line and cylinder
Dec 20, 2016 | Cars & Trucks
Boss v plow won't lift. Replaced motor and valve control. Lifted twice and quit. Now what do I do?
Check electrical connections to the Lift Pump. I'm not impressed with Boss's wiring
Jan 13, 2016 | Boss V-XT Poly Snow Plow
There solinoids on pump. Check wiring and grounds. Make sure all small wires are intact and in good condition. But most likely there's a loose corroded or green wire causing issue
Jan 09, 2015 | Cars & Trucks
When i try to lift or angle my plow all i get is a clicking sound when i push the lift button and when i let up on the button the moter on the hydrolic unit will click but will not move the plow. minute...
Not familiar with model, but valves click at the same time motor is suppose to run. Check power and ground to motor (or try running it with jumper cables, but don't be where plow can angle and squish you. If good power but won't spin, clean brushes/commutator/check bearings in motor.
Aug 15, 2014 | Cars & Trucks
I have a 93 chevy with a western unimount. was plowing and now the motor runs,but wont lift or angle. possibly something sheared off in the pump? fluid is full,and no visible leaks.
Mar 08, 2011 | Chevrolet 1500 Cars & Trucks
I have a 2003 f-250 with a curtis sno-pro 3000 hitch n run plow system. when i go to lift plow or go left or right it kills the truck. the light shut off and every thing else as soon as i hit any of the...
I think you have a problem with the plow motor grounding out. when you raise or turn plow in either direction you have to run the plow motor which is grounded out. ( as in hooking the ground and positive together directly ) the plow is on a gravity drop when you let it down by the weight itself and does not require the motor for the plow to operate. It's your plow motor or the positive feed to selonoids.
Feb 05, 2011 | 2003 Ford F250 Super Duty Crew Cab
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
