Question about Hobart Food Mixers
Hobart H 600 manual bowl lift wont turn. It seems to be jammed. Not sure where to check. Any guesses?
  • 73 Answers
SOURCE: We have a hobart d300
https://feg.hobartcorp.com/resourcecenter/Discontinued%20Product%20Documentation/F3492.pdf
click link above for Owners Manual.
https://feg.hobartcorp.com/resourcecenter/Discontinued%20Product%20Documentation/F-3492-N.pdf
clink link above for parts Manual.
hope that helped
Posted on May 23, 2009
  • 109 Answers
SOURCE: Hobart Mixer bowl won't go up
If the worm screw is turning but not lifting the bowl, the bowl lift nut is stripped.
H600 part number is 24198.
To change it, you need to undo the screws down the right side yoke slide to release the yoke. You will need to lift the yoke to reach some of them. If you have some wood place it under the yoke and over the legs to protect the paint. On top of the yoke are two blots holding the keeper plate over the nut. One is the stop screw for bowl height. Don't loose this setting. remove the slide, edge the yoke forward a bit to free the worm. Run the old nut down the worm and off the bottom. When you run the new nut on, all the excess grease and metal shavings will start to build up. Clean as you go, or better still, brush with solvent or similar to clean the worm threads . relubricate, run the nut up above the yoke, reload the yoke and attach keeper plate, reload slide.
To adjust slide, snug screw near bottom keeping slide close to yoke, run yoke to top and tighten top screw just enough to hold slide in place, lower yoke to bottom, gently tap top of slide in a 1/16" and tighten top screw. Run yoke to top of slide. It should start to bind slightly in the last 2 inches of travel, which will stop the bowl from dropping in use. Tighten remaining screws.
Posted on Aug 08, 2009
  • 119 Answers
SOURCE: our hobart HL 600,no display
If you have 24 VAC to the timer board and still have no display, then you need a new timer board.
Posted on Aug 06, 2010
  • 130 Answers
SOURCE: KitchenAid® Professional 600? 6-qt. Bowl-Lift
nice machine!! enjoy using it. I assume you have no problems with it since no problems are described!!
Posted on Feb 23, 2011
  • 185 Answers
SOURCE: service manual for kitchenaid professional 600 575 watts bowl lift stand mixer
go to mending shed . com and you can find it on their home page for download in pdf format
Posted on Apr 18, 2013
Why wont my mixer speed up to full gear, why is all the tork in the mixer gone, what is the common part that breaks or wears out thus causes this
why are you over loading the machine against the user manual advice
contact hobart for spares or advice on the problem
cut back on the quantity of ingredients in use and make the mixture to the right consistency according to the recipe
if you still have a problem .take it to a hobart authorized repair shop and have it fixed
Dec 13, 2016 | Hobart Food Mixers
HOW DO I MANUALLY LOWER BOWL IF MIXER WILL NOT START?
Trina you might be better off to contact Hobart or an authorised Hobart service agent about this. The lack of answers probably indicates resident hobart experts are absent.
May 06, 2015 | Hobart 140 qt Mixer Model V-1401 Used Mint...
RESET A HOBART 140 QT MIXER
The V-1401 has a power bowl lift that is belt driven by the same motor that is used to mix. Remove top cover to check the belt. If belt is good and not slipping, is the operator handle working on /in the bowl lift gear box? If not, could be broken shear pin on handle or worn out parts in gear box. Next thing to check is the output shaft of the bowl lift gear box. If it is turning when the operator handle is engaged and the bowl lift jack shaft is not turning there is a broken shear pin between the output shaft and jack shaft. If everything is good to this point the bowl lift yoke has a large brass nut on back side of it that the jack shaft goes through. If the nut is worn the bowl lift yoke will slip, fall and/or jam. to unstick and lower the bowl , one can turn the jack shaft by hand. WARNNING : if the nut is worn enough the yoke can drop suddenly and it is very heavy.
D300t hobart floor mixer
best contact Hobart we have not fixed on here
Oct 09, 2017 | Food Mixers
Hi, I have a used Hobart A200T and the bowl yoke piece moves up and down slightly, even under a light load. It makes an annoying clanking noise. It's as if a spring somewhere is looser than it should be....
You may be correct about a loose spring. Check this:
Carefully lay the mixer on its back side to access the bottom of the mixer. Remove the cover screen covering the opening in the bottom of the mixer. Using an extension and appropriate socket, be sure the nut of the bowl lift rod is snug, slightly compressing the spring of the bowl lift rod.
Jan 26, 2011 | Hobart A200 Stand Mixer
My h 600 will only run when i hold the start button as soon as i let go it stops
If it has a bowl guard on it then the problem could be either the bowl height switch or the side switch on the contactor. If it does not have a bowl guard then the side switch on the contactor is the problem. If it has a bowl guard, make sure the bowl lift is operating the bowl height switch. The bowl must be all the way up to operate the bowl height switch.
Jun 09, 2010 | Hobart H600 Stand Mixer
Bowl lift on H660T will not raise bowl. The pinion gear turns the threaded rod, however; the screw just turns in the threaded block on the bowl yolk, without raising the bowl
The brass nut threads are worn.You have to remove the bowl yolk from the slides to get to the nut.I'm a hobart tech and repair these units often,any questions let me know----Tony.
Nov 23, 2009 | Hobart Food Mixers
May 13, 2009 | Hobart H600 Stand Mixer
H-600 Turn Handle slips, bowl does not go back down
Does the handle seem to move easier?there is a shear pin on the handle and if it breaks the bowl wont move.Another thing to check is remove the silver plateon the front of the mixer there are 2 possibly 4 screws,when you remove this plate you will see a long screw about 3 feet long.turn the handle if the screw doesnt turn that pin may be broken.let me know.
Mar 18, 2008 | Hobart H600 Stand Mixer
Food Mixers Logo
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
