SOURCE: Samsung HT-DS610 System Problem
I found this online. Don't know if it helps you guys or not?
Samsung HT-DS610
1. Remove any discs from the tray
2. Flash the RAM (disconnect from the mains for 30 seconds)
3. Plug it back in, switch on from the remote
4. Wait for "No disc" message
5. Press Enter.
6. Press 8,4,2,6,9 slowly.
7. Press Enter.
You may need to repeat steps 4 through 6 before the try is open.
SOURCE: rear check message on HT-TXQ120 samsung home theatre
Looks like it is to do with the rear wireless speaker. Now, my problem is over. Its gone. I first turned the reciever on and then turned on the rear speaker wirel less on. No rear chk in problem now. Hope this helps. R.
SOURCE: Protection Problem on Samsung Digital Home Theater
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal
fault is the natural cause for protect mode. If all the above did not
work, then the problem is a blown component or an internal fault. In
this case the unit must be taken apart , tested and repaired by an
experienced person.
If the unit is less than one year old, or if you
want to get service, call Sony at the phone number listed on the
product documentation.
Regards.
SOURCE: display reads OPEN LOCK when I try to open dvd tray.
Samsung Home Theater Systems
have a Dealer Lock or
Tray Lock Function that prevents
the disc tray from being opened.
There are four procedures
for turning off the Dealer
Lock function. Try one, then
the other, to see which works
on your system.
Unlocking Procedure 1
To turn off the Dealer
Lock function, follow these
steps:
Note: Repeating
the two steps above turns
the dealer lock on again.
Unlocking Procedure 2
steps
Note: Repeating
Unlocking Procedure 3
steps
Note: Repeating
the two steps above turns Dealer Lock on again.
Unlocking Procedure 4
steps
The Dealer Lock feature
is mainly used by retailers
to ensure that the display
discs are not removed. However,
parents of young children
may find this feature very useful
as well.
SOURCE: v ipod mode in Samsung HT-Z420 home theater system not working
Plug a yellow video cable into the TV (IN) and the Sound system (Out) then go onto AV1 on the TV or which ever port you plugged the cable into and play a movie and u can see it. A menu doesnt come up like the A ipod funtion so it comes up no signal until u play an actual movie on the ipod. If u dont have a yellow video cable i think u can use the white or red audio ones.
