Question about Sony VAIO A260 Notebook
Vaio wireless lan switch repeatedly restarts windows
I have a Sony Vaio vgn-a260. It is about 5 years old and I just put a new hard drive in it. I bought the Sony created Recovery discs and they seem to have worked fine. However, when I switch on the wireless lan, the computer immediately flashes a blue screen with text, too fast to read and then restarts itself and then tries to setup again. Then when it gets to the searching for an internet connection screen it flashes the blue screen and restarts again. Over and over.
  • 1,606 Answers
Thats sounds like the wrong drivers for the network card. Some models can have different models or brands of cards so you can get the wrong one in there. You should be able to boot up in safe mode (F8) and then go under control panel - system- hardware manager-network adapters. Find the card that is causing the problems highlight and delete it. Then reboot. This takes the card out of the system and it will be detected as a new hardware next startup. Then try another driver.
You might want to go to the Sony website and check under support to see what other drivers you can get to try for your model. There might be 2-3 to try. Usually the oem disks are right but the replacements don't always get things right.
If this were hardware you shouldn't get the bluescreen of death (BSOD). That usually means software or drivers.
Posted on Jul 21, 2009
    President:
  • 828 Answers
Its not your wireless lan is the problem, try to identify the problem in blue screen, you can read it... that's all we need to know what is that blue screen, came from
Sony Vaio VGN-SZ18GP Windows 7 shutdown problem .... when I shut down .... it gets stuck on the screen of shutdown but the "loading circle" is still running
This can be a sign of a memory failure, either the RAM is not clearing or the hard drive is on its' way out. Hold the power button down for 6 seconds for a "hard shutdown". Then restart and see if the problem persists.
Oct 13, 2013 | Sony VAIO VGN-SZ18GP/C, VAIO VGN-SZ420NB,...
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
I want to disable sata mode on my sony vaio vgn-fs742/w, please help because i cant reinstall xp on the system and the lan and wireless in not working when i install windows 7 on it.
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Jun 29, 2011 | Sony VAIO VGN-FS742/W Notebook
How much memory can a ASUS K501P accomodate?
ASUS K50IP vs SONY VAIO Sony Vaio VGN-SZ44GN? Sony: Processor Speed: 1,800 MHz
Hard Drive Capacity: 100 GB
Memory (RAM): 1,000 MB
Chip Type: Intel Core 2 Duo
Primary Drive: DVD+/-RW
Laptop Size: 13 inches
Features: 10/100 LAN Card, Firewire, Modem, USB, Wireless Network Card
ASUS:
Processor Speed: 2,200 MHz
Hard Drive Capacity: 320 GB
Memory (RAM): 2,000 MB
Chip Type: Intel Pentium Core 2 Duo
Primary Drive: Dual Layer DVD
Laptop Size: 15.6 inches
Features: 10/100 LAN Card, Carrying Case, Modem, Operating System, USB, Wireless Network Card
Mar 19, 2011 | Computers & Internet
Blue tooth and wireless LAN does not install after installing windows XP sp3
Problem with a Sony Vaio. It seems one of the updates put entries in my registry to start a Vaio Lan Manager with Windows.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
Check these keys to see if any kind of a 3rd party Lan Manager is running. If so, delete the entries and reboot.
Feb 28, 2011 | Sony VGN-TX670P/B: VGN-TX670 PM...
VAIO VGN-NS190J/S 15.4-Inch Notebook PC (2.0GHz Intel Core 2 Duo Processor T5800, 4GB RAM, 250G: The wifi light won't turn on when I put the switch...
They issue is due to the corrupted SmartWi Connection Utility Software in the Computer.
You will need to re-install the Wireless LAN Driver, Updates, and the SmartWi Connection Utilities in the Computer to fix the issue with the Wireless.
You can download the Wireless LAN Driver, Updates and the SmartWi Connection Utility from Sony Support Site.
Below are the links.
Wireless LAN Driver
Wireless LAN Driver Update 1
Wireless LAN Driver Update 2
  1. Please download and save each file on the Desktop.
  2. After that double click on the Original Wireless LAN Driver to begin the installation.
  3. Please follow the onscreen instructions to complete the installation.
  4. After that, restart the Computer for the settings to take the effect.
  5. After restarting the Computer, please install the Updates.
  6. Make sure that you restart the Computer after each installation.
  7. Then, please re-install the "SmartWi Connection Utility in the Computer.
You can download the SmartWi Connection Utility from here.
  1. Download and install the SmartWi Connection Utility in the Computer.
  2. after the installation, please turn ON the Wireless Adapter using the SmartWi Connection Utility.
  3. Please click "Start", "All Programs" and SmartWi Connection Utility to open the Program and turn ON the Wireless Adapter.
  4. After that, please re-configure the Wireless Network connection in the Computer.
  5. This should fix the issue with the Wireless Network connection.
May 18, 2010 | Sony VAIO VGN-NS190J/S Notebook PC
Restored my os and there is 2 accounts admin and other and they both have passwords? I didn't use any passwords
maybe someone put a password on your accounts
the last option is to format the harddrive and bring it back to factory settings
  1. restart the computer
  2. when you see the VAIO logo, press the f10 key repeatedly until you see loading files or edit boot option
  3. if you see edit boot options, press enter
  4. it will load Vaio recovery center
  5. choose restore c: drive
  6. disconnect any devices and turn off the wireless switch before starting the recovery
  7. process may take 45 mins to 1 hour with random restarts
Feb 09, 2010 | Sony VAIO VGN-N325E Notebook
Sony Vaio Laptop PCG 9U1M
PCG-K415B is the correct model number the label is possibly the service tage or something.
Here are the specifications of your laptop
  • Intel Celeron D Processor 345 3.06GHz / 533MHz FSB
  • 512MB DDR SDRAM - Low cost double memory Offer - call for details
  • 40GB Hard Drive
  • DVD Dual Layer Drive - To read DVDs and CDs and write CDs, DVD+, DVD- and large Dual Layer DVD
  • 15.4" XGA xblacklogo.jpg Widescreen TFT Screen
  • ATI Mobility Radeon 345M 64MB shared graphics
  • Integrated wireless 802.11b/g LAN - Call for advice on Wireless networking
  • Integrated 3-in-1 card reader –Memory Stick, Memory Stick Pro, Memory Stick Duo
  • Operating System: Windows XP Home Edition
  • Includes Sony Software Bundle
My guess is that the laptop is around 1 or 1and half year old as the celeron 3.06GHz is a relatively new processor.
May 26, 2009 | Sony VAIO VGN-AR230G Notebook
VGN-S150 wireless LAN switch
You don't need a new computer, a wireless card maybe. The problem is either a wireless driver glitch or the wireless card has failed. Start by uninstalling the wireless drivers from the device manager, then reboot. The machine will find the wireless card and reinstall the drivers. If this doesn't work, then take the card out (located under a panel on the bottom of the machine), clean the card, the slot, and the connectors on the two leads/wires. Sometimes a little dirt or corrosion build up will cause this. At this point, if the problem persists, then the card has malfunctioned and needs to be replaced.
Jul 22, 2008 | Sony VAIO VGN-S150 Notebook
Sony VAIO A260 Notebook Logo
926 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
