Question about Jenn-Air Ovens
After a local power outage when power was restored the Jenn-Air double oven model W256W display appears dead also lights off in oven acts like no power to the oven circuit breakers fine. Any ideas?
Jenn-Air model W256W troubleshooting
catriver
  • 878 Answers
SOURCE: my older jenn air double wall oven
shooter, F1 is usually the touchpad failure. You can try disconnecting the touchpad ribbon from the control and cleaning the ends with an eraser. See if the F1 stops. Catriver.
Posted on May 24, 2007
textonor
  • 130 Answers
SOURCE: Thermador SC302T clicking noise, locked door after power outage
iodine, open the upper oven, look thru the grill below the control panel on the right side and there is your model number. The issue here is that when the power came back on the oven run thru a test and your lower lock motor has failed. It will need to be replaced. Yes the only way to stop this is to shut off the breaker.
Posted on Feb 03, 2008
SOURCE: Problems with Jenn-Air Electric Double-Wall Oven
Try changing the clock assembly --
http://www.partselect.com/ModelFrames.aspx?ModelID=221346&ModelNum=WW30430P&mfgModelNum=&ManufactureID=1&Selected=51238&Position=1&mfg=Maytag&Type=&Mark=1
here is a link to the diagram.
PS120923
Electronic Clock Assembly (Series 10)
Help with series numbers
here is the part number.
Posted on Feb 17, 2008
localwonder
  • 6784 Answers
SOURCE: My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
Posted on May 22, 2009
SOURCE: Jenn-air Oven Model W256W
how do I replace the door gasket?
Posted on Aug 19, 2009
After electical outage my Jenn air JJW9230dds is dead?
Check the Main electrical Box for a fuse or circuit breaker that turned off.
Jan 07, 2014 | Jenn-Air JJW9230DDS Stainless Steel...
I have a problem with my jenn-air oven model w256w. On the touch appear F8 alarm. What can I do?
Hello- The code described- F8 indicates a failure in the clock, or control that operates oven. There is no simple 'fix' to this problem. "Self- clean" is the usual cause of board failure. Find a good tech to check it out on site Get an estimate before repair, and remember- Avoid "self-destruct" feature in the future. --Please reply if this info helps- have more if needed.  Thanks- Ed
Mar 18, 2010 | Jenn-Air Ovens
The control panel display light is completely dark but the oven still seems to function ok. Jenn Air Model WW30430P double wall oven.
A lot of ovens use a gas-filled vacuum flourescent display module that takes a higher voltage to drive it. The modules can get damaged or the power supply for the higher voltage (usually around 50 volts) may have failed.
Chances are the thing is only sold as an assembly...While the displays are common in auto speedometers that have digital display, those for these ovens are special with wpecial characters and background.
Jan 31, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn air oven
More then likely your electronic clock control board is going bad. After turning the power off, you can also try cleaning the connectors on the clock board and make sure the connectors are tight.
Mar 23, 2009 | Jenn-Air JJW8230D Electric Double Oven
Jenn Air JMW8530CAB time/temperature light don't work
We own a Jenn-Aire model W27400W oven. The display module has gradually gone dim over a period of several months prior to the end of the warranty, and the display is no longer visible. It is apparent that several Jenn-Aire oven models use the same display. Does Anyone else have the same problem, and If so, are they willing to join a class-action suit against Jenn-Aire with us?
Steve Patterson
303-256-8494
stevieb4019@comcast.net
Nov 18, 2008 | Jenn-Air JMW8530C Electric Double Oven
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Replace doors on jenn air oven with stainless
It is possible but usually costs more than the oven is worth. Call Marcone appliance parts in St. Louis for pricing.
Jun 19, 2008 | Ovens
Jenn- Air Model W256W
hi Randy
first try to unplug the unit, let it sit for a while then plug it back in, if you still get the code look on the back of the unit there should be an envelope that has a paper inside it, that paper should list what the code means.
Apr 01, 2008 | Ovens
just scroll down on this e mail and in the comment box you can answer my question
Feb 14, 2008 | Jenn-Air JGW8130A Electric Single Oven
Ovens Logo
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
